Available at https://www.amazon.com/Sony-70-300mm-F4-5-5-6-OSS-Lens/dp/B01DLMD7DK/
Sony’s longest reaching E-mount lens to date, the new FE 70-300mm F4.5 – 5.6 G OSS telephoto zoom lens (model SEL70300G) features a state-of-the-art optical design including four aspherical glass elements, two ED (Extra-low Dispersion) glass elements and Sony’s Nano AR coating, which all work together to effectively suppress spherical aberration, distortion, and chromatic aberration. This ensures beautiful high-resolution results for both still and video shooting.
The new telephoto zoom lens also features class-leading close-up performance, with a minimum focusing distance of less than 3 feet (0.9m) and a maximum magnification of 0.31x, making it an ideal choice for tele-macro photography. This outstanding close-up performance also factors into the lens’ excellent corner-to-corner sharpness.
The versatile zoom lens includes built-in Optical SteadyShot image stabilization that helps to reduce camera shake, making it easier to capture clear images when shooting handheld. Additionally, the new SEL70300G model has a linear actuator that allows it to achieve fast, smooth and quiet autofocus and is also dust and moisture resistant1 to ensure reliable operation in harsh outdoor conditions.
The new FE 70-300mm F4.5 – 5.6 G OSS telephoto zoom lens will be available in May for about $1,200 US and $1,700 CA, respectively.
Review
The Sony FE 70-300mm f/4.5-5.6 G OSS makes a solid case for itself by offering a useful focal range incorporating the longest reach of any E-mount lens, and all in a relatively compact package. Sony’s FE 70-200 mm F4 G OSS remains the more pro-focused choice, but the FE 70-300mm is very capable alternative if you need the extra reach and less bulk.
Lens in reasonable sharp. Sony FE 70-300mm f/4.5-5.6 G OSS has rounded 9-blade diaphragm and it produces fairly smooth bokeh. Sony’s in-camera lens correction automatically and effectively compensates distortions.
http://www.photographyblog.com/reviews/sony_fe_70_300mm_f4_5_5_6_g_oss_review/
70mm
300mm
Sharpness is quite good at 70mm, but situation at 300mm is much worse. Already dark lens much be significantly stopped down to get good performance. Sony lens in this regard is similar to cheapest alternatives.
https://www.ephotozine.com/article/sony-fe-70-300mm-f-4-5-5-6-g-oss-lens-review-29555
Review
Sony FE 70-300mm f/4.5-5.6 G OSS disappointed us a little. You are buying such lenses primarily for its potential at the very long end of the range which is where the performance may not be bad but it certainly doesn't reflect the promises of a G-class lens nor its high price tag.
Review
http://photoreview.com.au/reviews/lenses/other-ilc/sony-fe-70-300mm-f-4.5-5.6-g-oss-sel70300g-lens
