Specs:
Olympus management looking for aliens to come and save them
Review
https://www.thephoblographer.com/2017/12/01/review-olympus-12-100mm-f4-pro-is-micro-four-thirds/
Thanks bjarne! Currently weighing up the pros and cons of this lens on g7 vs buying a fz2000.
I'm really interested in this for video with F4 constant and IBIS, especially with the clutch mechanism.
However, I have the olymus 12-40 and use ex-tele on a g7 , and while the clutch mechanism is great in theory for using with a follow focus, the focus throw is only 90 degrees, and for documentary/event, 80% of the time you will be in the last 20 degrees of that throw which makes focusing pretty tricky. (To mitigate, I can change to smallest focus gear I have and add a 110mm focus ring but this makes it a pain to get on and off a rails system for lens changes).
Long story short, does anyone know what the focus throw on the barrel is and if its less sensitive than the 12-40mm due to it being more telephoto at the long end?
Review made after selling baby to get the lens
Measurement
https://www.camerastuffreview.com/nl/olympus-lenstest/test-olympus-12-100mm
Review
It's not perfect lens. Both centre and edge sharpness are very high throughout most of its focal length range, but performance drops off a little at the 100mm focal length, where you need to stop down to get acceptable results.
http://www.photographyblog.com/reviews/olympus_m_zuiko_digital_ed_12_100mm_f_4_is_pro_review/
