Camera page - http://fujifilm-x.com/en/gfx/
PR
The company will release mirrorless digital camera FUJIFILM GFX 50S which features the FUJIFILM G Format 43.8 × 32.9mm sensor with 51.4 megapixels and six lenses that will be introduced under the new FUJINON GF Lens series of interchangeable lenses after early 2017 sequentially for professional photographers and photo enthusiasts. The new series deliver the highest image quality Fujifilm offers as well as outstanding expandability and functionality as a camera system.
Over the course of its proud history that extends over 80 years, Fujifilm has developed and manufactured photographic films with advanced image resolution and outstanding color and tone reproduction to meet the needs of professional photographers and photo enthusiasts, an extensive range of professional cameras under the consistent philosophy that “a camera is a tool for producing artwork,” and high quality FUJINON lenses which forms an indispensable part of camera systems. All these technologies have been amassed to develop the GFX, which uses a medium-format sensor to achieve the highest level of image quality and a completely new type of mirrorless system, and its companion FUJINON GF lenses.
As a long-term manufacturer of photographic films and medium-format film cameras, Fujifilm was always aware of the impact which different format sizes have on photographic expressions. Using a larger format gives ultimate enhancement to a camera’s ability to capture “texture quality,” “stereoscopic effect” and “aerial feeling,” which cannot be attained even by substantially increasing the sensor’s pixel count. Since the launch of the X Series, an increasing number of professional photographers and photo enthusiasts expressed their desire to achieve the ultimate world of photographic expression with the X Series’ signature color reproduction. The GFX camera system with “G Format” is Fujifilm’s response to their desire.
Obtaining the ultimate in photo image quality
Since the introduction of the X100 in 2011, Fujifilm has strived to achieve the best image quality possible with its X Series of cameras. The latest and the most advanced addition is the new medium-format mirrorless camera GFX. It uses the new large-diameter “G Mount” and incorporates a large 43.8 × 32.9mm CMOS sensor. Boasting the effective pixel count of 51.4 million, the camera delivers superior sharpness and image quality that will satisfy professional photographers shooting commercial, fashion or fine-art landscapes. The sensor’s 51.4 megapixels can be adapted to various aspect ratios, including 4:3 (default), 3:2, 1:1, 4:5, 6:7 and 6:17, which were available in film cameras of the large- and medium-formats. The camera uses the “X-Processor Pro” imaging processor, which provides Fujifilm’s outstanding color and tone reproduction at an extremely high level. The result is the ultimate capability in photographic expressions that only Fujifilm can deliver thanks to its extensive knowledge in medium-format cameras and large-format films.
Mirrorless camera system with a large sized sensor
The GFX is an all-new mirrorless camera system that revolutionizes the concept of medium-format cameras. Compared to conventional medium-format digital SLR cameras, the GFX is lighter weight, achieving a far more compact form factor. With regards to functionality, the camera follows in the footsteps of the X Series by featuring numerous physical buttons and dials, and is designed with an ergonomic grip, shaped carefully and optimized for the camera body and lenses. This model becomes Fujifilm’s first model to use a detachable electronic viewfinder, which you can remove when using an external monitor or wanting to make the system even lighter. In addition, an optional adapter makes it possible to fit the EVF in any angle, giving greater freedom in the choice of shooting angle. Other optional accessories that will be released at the same time, include the Vertical Battery Grip, which enhances functionality when shooting in the portrait orientation. The camera also supports tethered shooting, which has become an essential part of the professional photographers’ workflow, and will be compatible with various RAW conversion application software.
New lenses with a new lens mount for added descriptive performance
A new lineup of FUJINON GF lenses, designed specifically for the GFX, supports the new G Mount. Taking advantage of the mirrorless system’s structure, the G Mount has the short flange back distance of just 26.7mm to shorten the back focus distance as much as possible. This prevents vignetting to achieve edge-to-edge sharpness of the world’s highest level. The initial lineup on launch is to include the following six lenses:
- Standard prime “GF63mmF2.8 R WR” (equivalent to 50mm in the 35mm format)
 - Wide-angle standard zoom “GF32-64mmF4 R LM WR” (equivalent to 25-51mm in the 35mm format)
 - Mid-telephoto macro 1:0.5 “GF120mmF4 Macro R LM OIS WR” (equivalent to 95mm in the 35mm format)
 - Fast aperture mid-telephoto “GF110mmF2 R LM WR” (equivalent to 87mm in the 35mm format)
 - Ultra wide “GF23mmF4 R LM WR” (equivalent to 18mm in the 35mm format)
 - Wide “GF45mmF2.8 R WR” (equivalent to 35mm in the 35mm format)
 The lenses feature an aperture ring, a popular feature in the X Series, and have the new C (Command) Position on the ring to enable aperture adjustments with the Command Dial on the camera body. All the lenses feature dust and weather resistant construction that withstands operation at temperatures as low as minus 10 degrees Celsius, allowing you to take them outdoors with peace of mind. This gives these lenses a strong potential, suitable for professional use in tough conditions.
More of the same
The FX50s body with EVF will be priced $6,499, announcement January 19.
Next rounds of announcement (now it is all multistage ala GH5)
Release date of the camera will be the 23rd of February 2017 with an RRP of £7600 in UK.
Fuji GFX 50S is priced at US$6,500 body-only in the US market.
New PR
Valhalla, N.Y., January 19, 2017 – As the leader in innovation for photographers, FUJIFILM North America Corporation today announces the FUJIFILM GFX 50S medium format mirrorless digital camera that will launch late February, 2017 with an initial selection of three FUJINON lenses - the GF63mmF2.8 R WR, the GF32-64mmF4 R LM WR, and the GF120mmF4 R LM OIS WR Macro. These lenses encapsulate the design philosophy of FUJINON lenses that are renowned by photographers around the world.
The innovative GFX system utilizes a Fujifilm exclusive 43.8 x 32.9mm (FUJIFILM G Format) 51.4MP CMOS sensor. The GFX 50S combines the heritage of over 80 years of imaging and the innovative award-winning functional design of our X Series digital camera system in the relentless pursuit of image quality.
The FUJIFILM GFX 50S Revealed
The FUJIFILM GFX 50S mirrorless digital camera uses the new 51.4MP FUJIFILM G Format 43.8 x 32.9mm sensor with approximately 1.7x the area of a 35mm sensor. In addition to the camera are three new FUJINON GF Lenses that will be followed by three additional lenses later in 2017.
The GFX 50S 51.4MP sensor shows its true potential when making large format prints, capturing majestic landscape photos or reproducing historical documents. Compared to a full size sensor with equivalent megapixels, both resolution and sensitivity are dramatically better due to the larger size of each pixel. As a result, the sensor captures great textures and subtlety of tone that is unique to large size sensors. The texture and tone combine to give a unique three-dimensional effect creating extremely high quality photography. Images captured can be reproduced down to the smallest detail, conveying the texture of the subject, a three-dimensional feeling, and the atmosphere of the scene.
For flash photography in the studio or outdoors during the day, the GFX 50S sensor has a native ISO of 100. The sensor can also be adapted to various aspect ratios, including 4:3, 3:2, 16:9, 1:1, 65:24, 5:4, 7:6, all of which are available in large and medium format film cameras.
The FUJIFILM GFX 50S uses the X Processor Pro (also used in the X-Pro2 and X-T2 cameras) and allows photographers to use Fujifilm's proprietary Film Simulations with a Medium Format sensor. The camera supports Full HD recording at 29.97p/25p/24p/23.98p. Users can enjoy high quality video with no post-processing required by using Film Simulation modes just like they would with a still image. The GFX 50S introduces a new Color Chrome Effect feature that reproduces subtle tones in highly saturated subjects.
Ultimate Performance in a Compact Body
With a compact and lightweight body constructed from magnesium alloy, the FUJIFILM GFX 50S weighs approximately 43 ounces when paired with the FUJINON GF63mmF2.8 R WR, and weighs approximately 60% of a medium format DSLR camera equipped with a sensor of the same size. When compared to a full frame, the weight is almost identical. Overall camera body height and width have also been minimized for maximum flexibility, overturning the common perceptions regarding the mobility of medium format digital cameras.
Bright, Crystal Clear Viewfinder and Large Touchscreen
The FUJIFILM GFX 50S gives users a 3.69M dot organic EL electronic viewfinder and 2.36M dot touchscreen LCD back panel for easy viewing. The EVF is detachable to allow for flexible operation. Users can attach the accessory EVF-TL1 EVF tilt adapter (sold separately) to allow the finder to be tilted to 90° vertically and swung ±45°. A 3.2 inch, 2.36M dot touch panel is used for the rear monitor, with touch operation for the menu, focusing points and image playback. A three-directional tilting LCD screen improves operability and makes viewing images and checking focus even easier.
FUJINON Lenses Guarantee Image Perfection
As part of the GFX system, Fujifilm is launching newly developed, ultra-high resolution FUJINON GF lenses. Taking advantage of the mirrorless system’s structure, the G Mount has a short flange back distance of just 26.7mm that reduces the back focus distance as much as possible. This prevents vignetting and achieves edge-to-edge sharpness. All FUJINON GF Lenses have been designed to support sensors of over 100MP.
GFX lens barrels feature an aperture ring in the same manner as FUJINON XF lenses, for intuitive operation. A new C (Command) Position has been added to the aperture ring, allowing users to change the aperture with the camera’s command dial. The A (Auto) Position and C Position feature a locking button installed on the aperture ring that must be disabled to implement changes.
Built for the Professional, and the Enthusiast
Just as with the flagship X Series models, the FUJIFILM GFX 50S features dedicated dials to independently set aperture, shutter speed, and ISO, the important factors in determining exposure.
Aperture and ISO feature a C (Command) and the shutter speed dial has a T (Time) Position. Setting the dial to this position allows the user to change exposure settings using the command dials on the front and rear of the camera body. The user can choose between these two operation methods according to their preference, ease of use, and the shooting environment.
The GFX 50S is equipped with a 1.28 inch LCD sub monitor on the top of the body. Important exposure data such as aperture and shutter speed is displayed on this screen. This display is extremely useful when shooting on a tripod or tethered to a computer.
A 117-point (9 x 13 / maximum of 425 points when miniaturized) contrast AF system is used on the GFX 50S. High-precision AF on the imaging sensor dramatically improves focusing accuracy with the shallow depth of field produced by medium format lenses. First adopted in the FUJIFILM X-Pro2, focus point selection can be performed by using the Focus Lever, which allows intuitive movement of the focus point. Alternatively, users can select the focus point from the touch panel LCD screen.
Hands-ons
First and last impressions
Last impression after sinking $6500 body.
https://petapixel.com/2017/01/20/fujifilm-medium-format-gfx-50s-first-impressions/
She is still hungry waiting for next tester
http://www.photographyblog.com/previews/fujifilm_gfx_50s_photos/
Noise samples have been removed by the request of Fuji.
More samples
https://www.dpreview.com/samples/1149460223/cp-2017-updated-fujifilm-gfx-50s-sample-gallery
