Working with a friend who has a film project's footage on a hard drive. Hard drive hasn't been used in 1-2 years. He used the wrong power cord to turn it on, and after turning on, it turned off and light went out. He then connected it to the correct power cord but the hard drive won't turn on. Does anyone have an idea of what the problem may be? Also, any suggestions on how to recover the footage that is stored on this drive. Thank you.
Thanks hoss
oops. double post on the dock, here's a SATA HD bay
https://www.amazon.com/StarTech-com-5-25in-Trayless-Mobile-3-5in/dp/B000KS8S9W
Thank you.
These are handy when using bare drives, if you don't need an external enclosure, just plug in...
https://www.amazon.com/Thermaltake-Sata-HDD-Docking-Station/dp/B0012Z3MKW
Thanks for advice guys.
First of all, if you take it out of the enclosure, be very careful as some of these are designed in such a way that they break easily.
If it's toast, you can send it out to be scraped, or you can roll the dice with a PCB swap. You need to carefully remove the PCB with a torx driver, then send it out to be swapped (you can't swap it yourself, the firmware needs to be transferred). The PCB swap runs $50-$60; if it doesn't work, then you are looking at a scrape which is expensive. It could involve replacing the head assembly, etc., in a cleanroom. Hopefully it's just a fuse in the external box, but, sadly, it's more than likely the PCB. Odds are with a power surge it can be fixed with a PCB swap, but you never know. I really don't recommend opening the drive itself, ever. When hard drives fail; it's a bummer.
Yes, just take the drive out of the enclosure and connect it to a computer.
If it's an External hard drive, check to see if there is a reset button. The actual hard drive may be OK, but the power supply might be fried. You could remove the bare hard drive and connect it directly to the computer or put in another enclosure.
