Added more specs and photo.
What are some improvements over Mk1?
Mostly the addition of a "II" at the end. :P
I'd hope that they the new one is sharper than the MK1. Gotta' wait for some samples to start floating around for review to find out.
Looks longer.... I love the mk1
I'm ok with mk1 as well and I don't see anything new with this one.
It is usually improved optics, better coatings, slightly better OIS and slightly better AF.
In addition to the new EOS 5D Mark IV DSLR, Canon is also introducing two EF-Series L-series lenses as well as a variety of EOS accessories. The new EF 16-35mm f/2.8L III USM Ultra-Wide Zoom Lens features a large diameter GMO dual surface aspherical lens and ground aspherical lens, f/2.8 aperture throughout the entire zoom range, fluorine coating, improved durability and is dust and water resistant. The new EF 24-105mm f/4L IS II USM Standard Zoom lens features an improved four-stop image stabilization as well as ghosting and flare reduction with air sphere coating. The Canon EF 16-35mm f/2.8L III USM Ultra-Wide Zoom Lens is scheduled to be available late in October for an estimated retail price of $2,199.00 and the EF 24-105mm f/4L IS II USM Standard Zoom Lens is scheduled to be available in late October for an estimated retail price of $1,099.00.
Optical Construction and MTF
Separate retail lens will be shipped only in December.
Review
This lens doesn't have perfect image quality, but the Canon EF 24-105mm f/4L IS II USM Lens is one of the best general purpose lenses available. It has an extremely useful range of focal lengths in a very-well constructed body that is ready for professional-duty use. It is nicely sized and has a weight that will not quickly wear you down. Excellent image stabilization system will make a dramatic difference in some low light situations.
http://www.the-digital-picture.com/Reviews/Canon-EF-24-105mm-f-4L-IS-II-USM-Lens.aspx
Review
Buyers of this lens should be happy with the improvements to the AF and stabilization systems, both of which should make it easier to obtain sharp, correctly-focused shots in a wide variety of situations.
http://www.photoreview.com.au/reviews/lenses/full-frame/canon-ef-24-105mm-f-4l-is-ii-usm-lens
Another measurements with same results
https://www.lensrentals.com/blog/2016/11/canon-24-105-f4-is-mk-ii-mtf-results/
DXOmark review
https://www.dxomark.com/Reviews/Canon-EF-24-105mm-F4L-IS-II-USM-lens-review-Updating-a-classic
Samples
https://www.dpreview.com/samples/4604076757/got-focal-range-canon-24-105mm-f4l-ii-sample-gallery
Ive been looking at a lens in this range for my a6500 and have somewhat concluded to go with a Nikon 24-120mm f4. I'll be using a focal reducer.
Review
Sharpness at 24mm
Sharpness at 105mm
https://www.ephotozine.com/article/canon-ef-24-105mm-f-4-is-ii-usm-lens-review--30572
Review
24mm
105mm
https://www.focus-numerique.com/zoom/tests/canon-ef-24-105mm-f-4-l-is-ii-usm-3029.html
Issues notice
We have determined that some EF 24-105mm f/4L IS II USM lenses exhibit an AF operation-related malfunction. The details of the phenomenon and Canon’s service policy are described below.
We would like to offer our sincere apologies to users who have been inconvenienced by this issue. Going forward, we will spare no effort in our quality management to make sure our customers can use our products with confidence.
Phenomenon
At the wide-angle end, focus is not achieved properly when a peripheral AF points are selected, regardless of the AF area selection mode.
Affected Lenses
If the first two digits in the serial number (see the image below) of your lens are ”48”, ”49”, ”50” or ”51”, then your lens MAY POSSIBLY be affected.
