I fixed link
Bought! Sweet deal, was looking for a small recorder to use with my Mix Pre D, now to find a bag for it all...
Did they fix the issue that recording stops if you pull out USB power?? This makes both the DR-60D and DR-70D unusable for me with external power :( Am getting an external power set up for my Sound Devices 552 however.
Yes they fixed it make sure firmware is up to date.
In for one. Use it for travel.
Scot, pull out the USB power pack and then plug back in again.... does it pop up with an option asking to select USB power or not?
Also which model is this, DR-60D mk1/mk2 or DR-70D?
The Model is DR 70D. If you are not recording yes it will ask. If you are recording it will tell you power was unplugged and revert to internal batteries. If while still recording you replug in the external usb battery it will show the symbol on the display but not otherwise ask you about external power. I suppose I should add that if you stop recording it will than ask if you want to use external power again.
New low record
Tascam DR-70D 4-Channel Audio Recorder for DSLR Cameras for $200
Coupon code - 6986645213
Good offer.
Crazy prices, mine arrived today. My beloved dr-100mk2 just didn't have enough channels! I hope this unit will be as amazing! (Mind you the dr-100mk2 was super picky about SD cards)
Regarding the increased noise for limiter mode- does anyone know if that is fixed in newest firmware? Looks like tascam are at least a bit interested in fixing bugs with this unit! Thinking about doing the opamp hack.
I've had this unit for a few months so here are my impressions:
The Good: small, lightweight, sounds good
The bad: stupid battery design, cheesy USB power connector, buggy firmware.
This is a real deal for the price. Note that the pres are not exactly the same as in the eight channel, on paper, they have a higher noise figure. However, noise is not really a factor in this design.
The converters and preamps are excellent, I prefer them to the SD. Compared to the Fostex FR2LE, the are a touch brighter and a touch clearer. The same applies to the DR 680, but the difference is smaller. There's plenty of gain.
The converter chip is a Cirrus Logic CS42L52-CNZ, which is not exactly the top of the line, but it's very good. I'm guessing the chip is circa 2013, and almost all of the functions of the 70D are coded into the chip, so the box is sort of an interface for the chip.
The TRS jacks on my unit do not pass the phantom power. This could be an annoyance in the fielod, but it isn't a deal breaker and could even come in handy at times. Unlike many other recorders, the P48 is switchable for each channel.
The battery indicator is worse than useless. A major flaw. Also, the recording times are overrated. You will chew through batteries with decent, phantom loving mics. You can, however, set the P48 to 24 volts to drive, for example, a Schoeps CMC6.
For $11 you can get a thin, rectangular power bar that fits very well with tape or velcro or whatever.
I bought one, and it gives you some serious battery, maybe not 20,000 mah but I recorded for about 8 hours.
http://www.ebay.com/itm/20000mAh-UltraThin-Dual-USB-Portable-Power-Bank-External-Battery-Backup-Charger-/331541674213
If you yank out the plug while recording, and you have batteries, it will still keep recording.
On my unit, little bugs kept cropping up, like it kept asking me to set the time and date, and the rotten battery meter, etc.
Level indicators are hard to work with. Takes some getting used to. The are "fast" which is good, but it is hard to get a reading sometimes.
The battery door is kind of cheesy. But, you can access it from the side. Sort of.
The pots for gain: there are four, which is OK, but there is a dead spot at the bottom. The lock button locks the gain.
Also, it is picky about cards. I'm using a PNY 64gb, so far, no issues. We will see. It's really stupid that the firmware/design does not allocate the buffer properly. Four channels of audio just does not need a fast card--after all, I can use a turtle card on my 680 to record 8 channels. So, Tascam, you are stupid. Don't blame the card.
Online, ppl talk endlessly about premps, preamp noise, take measurements, etc. This is all totally BS. You have to plug it in to a bunch of mics--like Neumanns that draw a lot of juice and have no self noise--and listen. The pres are clear and quiet.
Now, if you wanted better slew rates from your op amps, the chips are really hard to get to. But you could swap out the op amps for some better ones and swap out the caps
LME49720MA op amps
Wima MKP-2 poly caps
The chips on the back of the PCB AFAIK are for the output. So you could get away with just modding the input.
There is a plate to attach stuff to the top of the unit, and so you could hook it up to a camera, a light, or some mics. Decent rig connectivity.
There's a new firmware out today, I'll report on it later. Update: I'm not sure what the new firmware does, but the battery meter is till messed up. It could be that if you are using Eneloops you need to set the meter to Alkaline. On ongoing problem.
Pet peeves:
There's no way to set the input gain to the same level precisely, or gang the channels.  The gain knobs are tiny and easy to bump into another setting (although you can lock the gain with the lock button).
When you turn it on, it asks you for each Phantom power channel if you really want phantom power. I just want to get to the gig, turn it on and hit the record button.
There's no way to record more than 4 hours (or maybe a certain file size) without starting a new file. Most recorders have this problem, but it is stupid. OTOH, some DAWs can't handle really long files.
"Recommended" card: https://www.amazon.com/SanDisk-Extreme-SDSDXPA-064G-X46-Flash-Memory/dp/B007NDL54C
Price changed shortly after post.
You need to go to checkout now and also apply code - 1ZOOMLENS1
I've been using this for a bit now, so good for stacking under the camera on a monopod to keep discreet at live performances. This is internal mics mixed with a rode video mic into the stereo input really easy to manage.
Having used this unit for a while now, I can say that I absolutely love it.
The battery is annoying, but quickly fixed with external battery pack!
Make sure to upgrade to newest firmware.
Only really annoying thing is that unit takes a few seconds (about 15) to switch on.
I love having 4 inputs available at all times. I also purchased chip upgrade, but just need a spare hour to swap.
@alcomposer where did you get the chip upgrade I assume that's a preamp upgrade? ,I've got to send mine in to fix the headphone port I think I put it under too much strain! if it's a worthwhile upgrade I might see if I can get that done at the same time do you have any details?
thaks
Mark
I assume this upgrade would be a 3rd party upgrade, a pre-amp upgrade I guess? As that is a common choice of mods.
In addition to my previous comments, this is my final review:
Serious flaws render this unit unusable for live recording or professional use. In addition, quality control is sub-par, raising questions about intermittent problems. It's small, it's reasonably well built, the converters and AD conversion are fine, however, the persistent problems with the device basically means your recording is at risk, and the metering is simply unacceptable.
I'm a big fan of Tascam (and Teac) products, dating back decades to the tape era. As a professional audio engineer and videographer, on our broadcast stations, we have used the DR 680 many times. So when this compact, four-channel unit came out, we thought it would be ideal for mobile audio and video recordings. On paper, it looked great.
The first unit had a number of problems. The battery meter did not work, the unit would freeze on startup, it would forget the time and date, it would forget to turn on the Phantom power (for the mics) and other issues. So, out of the box, problems. We sent in the unit (at our own expense) and received a replacement. The new unit works OK, but still has the defective battery meter. This means, basically, that when you are on batteries, you have absolutely no idea when the recorder will shut down without warning. This is unacceptable from TASCAM. In addition, I would have appreciated the service department either sending me a working unit or a note of explanation that the battery meter does not work, rather than waste my time.
Other minor issues include spotty and inaccurate audio metering, a poorly conceived and poorly marked battery compartment, tiny, fussy controls and menus and flimsy plastic buttons. Headphone output is only so-so in quality. The actual recording quality, if you can get everything to work, is good.
The recorder is overly picky about media, and TASCAM is slow to update its approved media list. The fact is, a four channel audio recorder does not need special or fast media, it needs a well-designed buffer system: TASCAM dropped the ball here--how is it that the DR 680 can record 8 channels on standard media but the 70D requires a special card for half the data? The only explanation is software design or that the company simply did not put enough internal buffer in the device--I hope the former is the case and these issues can be resolved with a firmware update. Incidentally, the manual does not contain instructions on how to perform the firmware updates.
The recorder has a dual recording feature which allows you to make a alternate, two-channel recording at a different gain level. Although this looks good on paper, the overload stage of the gain can be exceeded before the data is written, owing to the way the device is configured. Nonetheless, this is a very handy feature for live recording and video recording. I must reiterate, however, that the idea of a "safety backup" is rendered moot by the reliability of the product as a whole. If the battery gives out unexpectedly--and there is no way to know when that will be--your recording and your backup will be equally useless.
Tascam does not provide a power supply. This is just cheap. We are starting to see more and more of this "find your own USB power" to save a dollar or two, and it really is not in tune with the needs of musicians. Tascam should have provided a reliable power supply, especially since battery power is unreliable as an option. Most users go and a buy a big USB brick, which works, but defeats the whole idea of small and light. As far as the sound goes, it is perfectly good, and, if it worked reliably, it would be recommended. Sadly, this is not the case.
It can not only come from lack of buffer, it can also come from very poor software.
As the old times it could be written by experienced developers and now it can be partly just outsourced to some Indian firm. Writing file to SD while doing many other things (LCD display, polling of controls, etc) is not so easy as it seems.
Yeah--I am more willing to believe it is poor software. I just can't believe that people say, Oh, you need a fast, exotic card from batch X made in Country Y for the audio recorder to work for 4 channels, when the DR 680 will write to the absolute slowest card in my studio with twice as many channels.
By idea it must work with any cheapest Class 4 cards.
Again action at Adorama, $179 after rebate
Price is showing $259.99, $229.99 after rebate?
