Here are the simple instructions.
It is pointless to post results on cheap USB 2.0 reader.
Get good, fast USB 3.0 reader and do proper tests.
Transcend 32GB Class 10.
USB3 Card Reader.
Not too shabby, 38€ for 32GB @ 136Mbps it's up there to my previous Samsung 16GB Extreme Speed.
@humpman: The tool you linked isn't very interesting. It tests write speed from the beginning to the end of the device (which doesn't make sense in this case since a flash device will always write at the same speed independent of the location of the sector).
The same card I presented earlier was steadily writing at 18.4MBs in that tool (HD_Speed) before I ended the test which would I believe would take over 15m to run.
is HD_Speed reliable test for GH2 usage? My card writes 5GB file from HDD to Transcend SD card with speed of 17MB/s, that equals around 135Mbps
If HD_Speed shows writes consistently above 17 MB/s in your PC using a non-UHS card reader, then you can assume the card will be capable of at least that when recording video in your GH2.
Speed testing on your PC doesn't generalize to say if the card will be stable or span with aggressive hack settings.
Check only "Запись seq", "Линейная запись" (Linear/sequental write).
I think people test cards that they have.
One more fast cards test including Lexar this time
MicroSD cards
