My lordy lord. Best compact for m43 user ever made? Seems like it. There's no audio jack but who actually cares about that on a camera of this size for its intents and purposes.
Panasonic Lumix DMC-GX8 + 25mm lens for $898 + free 3 year warranty
https://www.bhphotovideo.com/c/product/1380166-REG/panasonic_lumix_dmc_gx8_mirrorless_micro.html
Panasonic LUMIX GX8 Mirrorless Micro Four Thirds Camera (Silver), G Vario 12-60mm f/3.5-5.6 ASPH. POWER O.I.S. Lens, Transcend 64 GB Card, Polaroid Tripod, Polaroid Battery, Charger + Accessory Bundle, $997
https://www.amazon.com/Panasonic-Mirrorless-Camera-12-60mm-Lens/dp/B01HSEQRPW/
After a few days of companionship the Panasonic Lumix GX8 had proved to be a very solid still camera. Its larger size will give you confidence to bring it everywhere on every circumstances even in bad weather.
http://photodanielm.blogspot.com/2016/08/the-panasonic-lumix-dmc-gx8-pro-still.html
I think this is a good footage in night low light situation. With images very clean.
On assignment, I like to work fast, but what I don’t like to do is fumble with a camera. As I began to really work with the GX8, I found that the size of the camera was an advantage, but for how I work, it needed a bit of help. If you ever worked with a GH4, you’ll notice how damned comfortable a camera it is for its small size. The grip on the GX8, however, is a bit sharp on edge where your fingers wrap around to the front of the body. I believe this choice is more form than function as it appears to be shaped for someone that might have their human hand replaced with a giant lego hand.
http://www.giuliosciorio.com/creators-path/2016/7/10/lumix-gx8-long-term-review
V2.2 firmware
New functions are added in Fn button. The option "Wireless Setup(Flash)" has been added to [Setting in REC mod] on the [Fn Button Set] of [Custom] menu.
The option "Wi-Fi" and "LVF/Monitor Switch" have been added to [Setting in PLAY mode] on the [Fn Button Set] of [Custom] menu.The phenomenon that rarely freeze at the time of tracking AF usage is improved
http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/index2.html
More from DPReview review
The GX85 is capable of 4K video capture at both 24 and 30p at up to 100Mbps and can make use of its 5-axis image stabilization (when using a Panasonic lens with IS) during capture. In use, we found the GX85 offers similar IS performance during video as the Olympus Pen-F, a class leader. However, the Olympus isn't capable of 4K capture like the GX85.
Adding to its appeal, the GX85 offers ample video tools like focus peaking, zebra pattern, audio level monitoring/adjustment and a wind filter. And users can shoot video in any of the manual exposure modes. Unfortunately, like the GX8, you can not use Auto ISO in manual mode during video capture along with exposure compensation, to adjust brightness.
Video quality looks excellent though, with good detail and color. And while the GX85 does have a built-in stereo microphone, it lacks sockets for an external microphone or headphones.
http://www.dpreview.com/reviews/panasonic-lumix-dmc-gx85-gx80
Ergonomically, from a functional handling standpoint, this is one of the best digital camera designs I've ever used.
http://theonlinephotographer.typepad.com/the_online_photographer/2016/06/panasonic-gx8-review.html
