DVX200 vx Canon EOS 600D
DVX200 Master Class
Panasonic DVX200 vs Lumix GH4
Going down now
Available for $3849 - $400 rebate
https://www.rebate-rewards.com/pnaenduser/docs/AG-DVX200-400.pdf
at
https://www.amazon.com/Panasonic-AG-DVX200-4K-Handheld-Camcorder/dp/B016043JWA
New firmware 1.83
- The camera may freeze if you perform a Zoom operation while other menu settings are set after Focus Transition is set up.
 - “Focus Transition function”. A function to enable the Focus to shift to a pre-registered focus position It is assigned to a USER button before it is used, and can be cancelled by operating the Zoom.
 - Indicated remaining storage capacity is not correct in VFR recording Error is corrected in calculation method for remaining capacity in VFR recording. Especially, when the slow motion effect is set and REC Frame rate is greater than Playback Frame rate, the camera has a symptom where the remaining time of the storage media is shorter than indicated.
- REC FORMAT (FR in playback) < FR in recording
 - FHD 1080/59.94p 50M (59.94) < 62 - 120 fps
 - FHD 1080/29.97p 50M (29.97) < 32 - 120 fps
 - FHD 1080/23.98p 50M (23.98) < 26 - 120 fps
 - FHD 1080/50.00p 50M (50.00) < 52 - 120 fps
 - FHD 1080/25.00p 50M (25.00) < 27 - 120 fps
 - Improvement of SDI Audio
SDI Output (3G-SDI, HD-SDI, SD-SDI) Problems such as ‘the status of Audio CH2 not indicated’ are fixed. SD-SDI Audio If the camera is alternately put into Recording Mode and Playback Mode, there may be a difference of a few samples in phase between CH1 and CH2 on rare occasions. This problem is fixed.
http://eww.pass.panasonic.co.jp/pro-av/support/content/download/EN/ep2main/soft/upgdvx200_e.htm
New firmware, version 1.84
Improvements
- On rare occasions, the operation of REC button on the unit or a wired remote control may no longer have any effect. This problem is fixed.
 - If the card is ejected from the main slot during the simultaneous recording, the recording in the sub-slot stops 10 hours after the start of recording. The indication shows the same as during recording, and the operations of REC button are refused. This problem is fixed.
 - LCD may not show anything when the camera is booted up. This problem is fixed.
 - A very few SD cards may have a write error. This problem is fixed.
 - If the network address is changed when WIRELESS SETUP is set to [DIRECT] and DHCP is set to [SERVER], it sometimes made the camera impossible to connect to the iPad. This problem is fixed.
 - If SET button is operated on AG-ROP app, the count number of “Jog Dial” item of Hour Meter is increased. This problem is fixed.
 - When 480i squeeze output is carried out, an image quality may be the slight deterioration. This problem is fixed. (Recording signals do not have any problem, only output signals have this problem.)
Conditions:SDI/AVOUT output of playback on MOV/MP4/AVCHD
Input: 1920x1080i/1440x1080i/720x480i
Output: Squeeze output of 720x480i (down-conversion)
