Nebula 4200 - strange monster
  • 221 Replies sorted by
  • Nebula4200 5-Axis unboxing video by Russian user
  • Well it's without the spring arm, that should stabilizes the vertical movement. So it's jut the standard 3-axis-version in the video above.
  • Still see vertical bobbing during walking shots.
  • Nebula4200 and BMPCC Combination Test
  • Nebula4200 and GH4 Combination Test
  • @Burning_Pictures If you need help, you can send email to our after-sale support(Server upgrade, mailbox will recover in a couple of days). Nebula4000 is our product, you could search in google.
  • The hardest part of the nebula 4200 is getting one - and one thats actually works. At least thats my impression. I was pretty hyped and ordered one 10 days ago - despite it was risky, because the support is known to be practically non-existing. So no help if troubles accure and now I till haven't heard a thing from filmpower...I'm getting nervous.
  • Photo from the famous photographer Benjamin Wong, looking forward to his more wonderful videos.
    918 x 518 - 102K
  • @Ralph_B Battery turn with gimbal suit. You can use a flex arm to support your monitor anywhere.
  • That's nice for low shooting, but what about when the camera is reversed in the high shooting position? Is there any place to attach a monitor? A logical place for a 1/4 inch hole would be on top of the battery pack.
  • The Nebula Spring Arm has a 1/4 screw hole. We could connect the monitor in the middle of the spring. Which is very convenient to watch the image when we are shooting.
    1441 x 1920 - 307K
  • This thing looks nice. Does anyone know if this can do Dutch angles?
  • Nebula 4200 + Sony A7r-ii test
  • Nebula4200 5-Axis shooting at Golden Gate Bridge. Camera: Canon 5D2 Lens: 24-105 Lens Stabilizer OFF
  • First look of Nebula 4200 5-AXIS DSLR Gimbal. Open Box Quick Balance about 2mins Weight 5-AXIS 1989g Lite 1407g full Box 3068g
  • @hoangwilson The shooting effect is very good.
  • some actual footage.
  • Five-axis stabilizer - a revolutionary breakthrough
    Handheld 3-axis stabilizer is a revolutionary product to the film industry. It is so light-weighted and user-friendly and creates more possibilities for photographers during film making and at mean time provides smooth videos. Among those 3-axis stabilizers on the market, the Film Power Nebula series is the most advanced, well-built products but will not make any consumer bankrupt.
    However, the 3-axis designs that control tilt, roll and pan cannot address the very crucial part: the vertical axis. We can notice bounces in videos created by 3-axis stabilizers caused by photographers’ steps. To solve this problem, the cutting-edge Nebula 4200 5-axis stabilizer has arrived.
    The two spring arms of 4200 can absorb any vibrations and bounces under payload. They are just like the vehicle suspension system which isolates road noise, bumps, and vibrations.
    Besides vertical axis, by using different spring tension, the two spring arms are also able to filter part of the vibrations in horizontal axis.
    On the construction side, thanks to the high quality material, the highly integrated Nebula 4200 is light weighted but extremely rigid and tough. Even with 2 spring arms which have 20 ball bearings, the Nebula 4200 only weighs less than 2kg (4.4lb), much lighter than most of the 3-axis stabilizers.
    1920 x 1080 - 113K
    1920 x 1080 - 115K
  • a lot more bouncing up and down than I would have liked :/
  • It looks like operator forgot to turn it on.
  • Probably the reason why they are not releasing test videos.
  • I agree with paglez. Very bad video :-(
  • Awful video!!! This video is a very bad advertising for Filmpower
