i've been told it could be next week , that was last week, also the 25th of october, so by all accounts i'm looking at december or early 2016 really, i think i'll have the e1 camera before i see the bmmcc
November- December? Sigh...I was anxious to test the new sCMOS 2.0 sensor..
FWIW this is from a dealer in NJ that works with Blackmagic's US distributor down the street: "I just called the distributor... this camera may not show up till November or December."
wonder if we can plug single wires in, so we can control the shutter ect or just the power and video out, rather than using the chunky block of wires that comes with the camera, this would effect the gimbal as all those wires would not move so well...
Well could still be out next week. Then it just depends what quantity, and which shops get the first allocations.
wwwwwwwwwwwwwwhat early october:(.....for the micro camera boo hooo boo hooo, i was told it would be out this week, so i guess that was bull poo.....classic balckmagic
@ 9:25:
about two stops of DR dropped in global shutter modes across all BM cameras (as expected). So does the Micro have 15 stops in rolling shutter mode as speculated? (hope so, would not want drop to ~11 stops in GS).
Micro cin cam shipping 'early Oct'.
Cool.
i was talking to these guys http://www.digibroadcast.com/camcorders-c61/blackmagic-bmd-cinecammichdmft-micro-cinema-camera-p16203 and was told they will have stock next week.... he was told this by blackmagic at ibc...
Great if true. @woobirdy what's your source?
great news :)
should be out in the next few days
My seller (ProAV) is also now showing ETA Sep: http://www.proav.co.uk/blackmagic-design-micro-cinema-camera
if anyone is looking for a gimbal for the blackmagic micro this one from x-cam is really nice, the controller is poo, i'm using 32bit alexmos. the bmmcc will also fit:)
mid september or end of, even october you know how it go's....i brought a bmpcc of ebay just to get used to the settings ect...glad i did, coming from sony cameras its a lot to learn, also 14mm or more like 40mm on a quad with gimbal is a mofo :), still tuning the gimbal, use to use sonya5100 with nice big sel10-18 lens, this 16mm cropper is a real shocker, but the image is horny, i love it,,been iching since april for the new bm,,,ordered the 9mm lens and 12mm, also 12-32mm panasonic, have the 14mm at the moment its not to bad , but picks up ant slight wobb from the gimbore...hmmmmm....globle shutter will be interesting also 50p, and video out so no more hdmi convertor:), pwm is a :)..its all looking good
Go for some cctv or S16 lenses. 10mm, 12.5mm and 16mm are very easy to find and cheap as well.
I'm still looking for a wide that will work nicely with my Biotar and Biometar and there doesn't seem to be anything that vintage wider than the "Hollywood" 28mm that's not super soft.
:). Yeah I love the Pocket SBs on my Tokina 11-16mm's, though that combination does produce soft edges. The only other downside is the huge lenses and weight (I use a two-body 3D rig) compared to my old GH2 rig with the tiny Panny pancakes. OK much more flexible and more light, but I wish there were some ultra-wide DX pancakes.
And I'm hoping this is the case, because I'm looking forward to getting one and the BMPCC SB plus the standard MFT SB I have means every lens is like having three lenses on these little guys, which is pretty cool.
Yeah I know, and that's my thinking, it's very unlikely that they wouldn't make it backwards compatible as they stuck to the Pocket sensor size. I already have two for my Pockets.
There could be issues with non-sensor related clearance. The model-specific BMPCC versions of the SpeedBooster don't work with all MFT cameras. They were tailor designed for how much space was available in that camera that may or may not be available in any of the plethora of other MFT cameras, all with same exact distance from mount.
It's quite likely that there's just as much space in the Micro as the Pocket, but BMD could have designed it such that something occludes into what might have been empty space on the Pocket. It's very likely it will work but there's no guarantee until someone tests it.
@BurnetRhoades, explain? The BMPCC is the same sensor size, has to be the same distance from the mount (M43 standard after all). So what could be different?
It's not just about the sensor, it's about physical space.
I'm looking at it instead of a Pocket. The Micro rigged up with a SmallHD on my Velbon SP-1 will make for a fairly light and flexible kit.
