GH4 - Best Video Settings
  • 753 Replies sorted by
  • Seems that someone are still using cineD although it has color accuracy issues compared to Standard or Natural. What are the real benefits? Normal profiles are quite flat with contrast -5 and even flatter with iDynamic in very high contrast sunny scenes but has better colors and less noise.
    Can you expose cineD more than normal profiles and get less noise by that? I have found that when I am using Natural contrast -5 I must often underexpose 1/3 ev. Otherwise image is too light or bright in midtones.
  • @filthy Yes that is correct regarding aerial. Additionally, the entire video is GH4 material with the exception of shot 0:43 (woman in blue - D3300) and shot 0:49 (marching band - a7s). I hope this helps and thanks for watching!
  • @CapionStudio - You mention in the Vimeo description that cameras used included A7s as well as D3300. Is it safe to assume that only the aerials were GH4 & 12mm combo?
  • @CapionStudio Yes sorry... typed the wrong name.
    Really nice work. I've had this camera for about a year now and every time I use it I'm still blown away by what it can produce with CineD and a little post TLC.
    Again, nice work and thanks for sharing.
  • @Maddog15 did you mean in reference to our video "Image & Color"? If so thanks a bunch man!
  • @nosignal I am glad you enjoyed it. We use these settings 90% of the time. I hope this helps!
    Photo Style: Cinelike D Contrast: -5 Sharpness: 0 Noise Reduction: 0 Saturation: -5 Hue: 0 Rec Format: MOV Exposure Mode: "M" manual AFS/AFF; AFS Cont. AF: Off Meter Mode: Center Weighted icon Highlight Shadows: default I. Dynamic: Off I.Resolution: Off Master Ped: 0 Luminance Level: 0-255
  • @CapionStudio your grading demo is awesome! I'm still trying to get a hold on which profile I want to use. I've been shooting Cinelike D for a while but I'm having some trouble with restoring accurate skin tones when grading without making the whole image seem dull. I definitely need to keep practicing. I've tried cinelike v with fairly good results and I'm wanting to try the portrait settings that @alienhead posted above!
  • Hey community! Take a look at the power of image and color utilizing the Panasonic GH4. The camera grades incredibly well, looking forward to V-Log.
  • For a project I need to film a night scene and I am thinking to try 'day for night' with the GH4. Has anyone got any experience with this? What would the best settings be?
  • @alexpj19 fuck a duck that's good.
  • @Alienhead
    I watched your sample video and it looks very clean. It has though a little "smoothed" or "plasticky" highlights to me and kind of dark black tones. I have tested a little this high contrast + HL darkening setup and while it gives very clean image I still prefer low contrast look with more noise.
    I watched my 4k recordings with a mid range Panasonic 55" 4k tv (AX630) and I saw very little noise in my low contrasts clips. The processing in 4k Tv is so good that the image is much cleaner than in computer monitor and there is less need to get the cleanest image in-camera.
  • Wow. Really nice work then. I also recognize that you did very good WB & exposure setup in-cam. That is HUGE with the "thin" data stream these mostly-8bit cams record into. I've watched so many complain of noise & artifacts with footage where it doesn't look like they've mastered the WB/exposure part of shooting. Your footage shows what happens when one does.
    Neil
  • Thanks guys. @rNeil there is only some white balancing and a little brightness/contrast adjustment in a couple of shots.
    I shot it in 4k and delivered in 1080, which gave me some flexibility to 'zoom in' on the timeline with a few shots.
  • @Alienhead My GH4 is with this profile for long time now. I like it a lot. Nice video by the way!
  • @Alienhead ...
    Nice work. In my testing with a GH3, this works with that one also. Didn't lose any dynamic range but skin tones and color feel are better. Especially considering the GH3's infamous magenta/plasticine skin. And grades quite well. I've loved seeing it with GH4 footage like yours.
    No grading, huh? Nice job ...
    Neil
  • @maxr thanks! @Vesku I'm interested how your test turns out. I should've tried grading it and seeing how that came out but I was happy enough with it. I'm not yet sure how it compares shooting Cine D with the dynamic range, but I did at least feel like I knew what was going to be blown out, even if I was blowing it out. But some of this footage would've been a challenge in any case as far as exposre, like the book signing, which was so dark that I was shooting 6400 ISO at f1.4.
  • @Alienhead
    That supertone setting is interesting. It darkens midtones and highlights so you can expose more and get strong signal and less noise. I must test it. i still fear that it ruins the GH4 exellent dyn range.
  • @Alienhead very very nice piece!! Love the freshness and how it's cut, working hard T. =)
  • I haven't been checking these posts in a while so I'm not sure if anyone else here has tried the "Megyesi" settings (http://www.supertone.dk/#!GH4-Optimal-Film-Setting-works-in-stills-too/c24o4/8E18836A-F271-4A14-AF0D-C575B9D5F4B6") This project I shot has I think great skin tones, using those settings with no other color correction.
  • problem solved
    3840 x 2160 - 2M
    3840 x 2160 - 2M
    3840 x 2160 - 2M
    3840 x 2160 - 2M
  • In-cam noise reduction is clearly still to be avoided. A smeared looking image just isn't usable at all. Noise is less objectionable than the smearing! And still is better worked on by full noise-control software in post.
    Neil
  • What do you think about GH4 noise reduction. I have an extreme example of the same clip with NR -5 and NR 0. Other settings were iso3200, natural contrast -5, color 0, sharpness 0. iDynamic was standard and there is heavy underexposing. I think NR-5 is much better.
    Image is 100% center crops of 4k frames
    1687 x 1572 - 576K
  • Looks amazing alex! What lenses were you using?
