PR
Fujifilm Corporation is proud to announce that a new FUJINON XF90mmF2 R LM WR will be added to the X-Series interchangeable lens line-up in July 2015. Offering a focal length equivalent to 137mm*1 and a maximum aperture of F2.0, this short telephoto optic is ideal for portrait and sports photography.
The FUJINON XF90mmF2 R LM WR is a fast-aperture prime lens that delivers ultra-sharp images with rich bokeh even at the maximum aperture setting. The optical construction of 11 elements in 8 groups (including three ED glass elements) minimizes vignetting and creates beautiful bokeh thanks to the rounded diaphragm, which makes it perfect for portraiture as well as other applications.
Despite having a large maximum aperture, the FUJINON XF90mmF2 R LM WR is both compact and, at 540g, lightweight while the minimum working distance of 60cm delivers a wide shooting range. A newly-developed Quad Linear Motor delivers fast, accurate autofocus, plus the lens also features a weather- and dust-resistant structure that can work in temperatures down to -10°C.
Along with the popular XF56mm F1.2 R, this is a must-have lens for portrait photography fans that favor fast aperture prime lenses. The focal length allows you to shoot at a distance that won’t intimidate subjects, leading to more natural, candid results.
Main Features:
Ultra-sharp images even at the maximum aperture
The optical construction comprises 11 elements in 8 groups, including three ED (extra low-dispersion) elements, which reduces chromatic aberrations to deliver sharp, rich images even at the widest aperture of F2.0.
Beautiful bokeh
The rounded aperture blades combined with an optical construction designed to minimise vignetting creates beautiful circular bokeh right to the edge of the image. In addition, stunning depth is possible in images thanks to the differentiation between the razor-sharp subject and the bokeh in front and behind it.
High-speed autofocus as fast as 0.14sec*2 thanks to a newly-developed Quad Linear Motor
A linear motor is fast, quiet and accurate, but here four magnets are used for higher torque. The high-speed autofocus provides a more versatile shooting experience, allowing users to quickly react to subtle changes in a subject’s facial expression.
Close focusing to 60cm and 0.3x magnification (35mm format equivalent)
The close focusing capabilities of the FUJINON XF90mmF2 R LM WR allow you to isolate key parts of a subject so you can shoot dramatic portraits or close-ups of flowers and insects.
Weather, Dust, and Freeze Resistance
The lens features a weather- and dust-resistant structure with seven seals on the lens barrel. It can also work in temperatures as low as -10°C. This keeps the lens protected from rain, dust and splashes of water when shooting outdoors.
Lightweight and compact
The lens weighs approx 540g, and is compact too, with a filter thread measuring just 62mm. The combined weight with the XF56mm F1.2 R is less than 1kg – great news for portrait photographers who want to travel light and still shoot with prime lenses for sharp images and strong bokeh.
XF 90mm performs very well across the frame and at every aperture, including wide-open. Meanwhile at the other end of the aperture scale, Fujifilm's Lens Modulation Optimiser ensures the results still look great at f11 and only suffer from a little reduction in sharpness and contrast at f16.
http://www.cameralabs.com/reviews/Fujifilm_Fujinon_XF_90mm_f2_R_LM_WR/
As far as we’ve tested, the 90mm f2 is incredibly sharp, in fact, we believe it to be Fujifilm’s sharpest to date. While I’m personally in love with the 35mm f1.4 and the 50-140mm f2.8, this lens is sharper than both. We even believe it to be sharper than the 56mm f1.2.
http://www.thephoblographer.com/2015/09/10/review-fujifilm-90mm-f2-r-lm-wr-x-mount/
