@kholi "why wouldn't you do it during recording? Say a redundancy situation where you're still shooting to the card, and at the same time recording to 4:2:2 specifically for VFX/Keying work? Is there an issue with that?"
Boy, is there!
That's interesting... why wouldn't you do it during recording? Say a redundancy situation where you're still shooting to the card, and at the same time recording to 4:2:2 specifically for VFX/Keying work? Is there an issue with that?
I should test with a 4:2:2 external recorder just for this type of production. Would be another reason not to break 4K/5K out for extremely low budget situations... although if it's just green screen then it may be unnecessarily crippling.
If you desire for some reason, you COULD play the footage out of the camcorder into MXO2 using the HDMI cable, and then you would be capturing to the Matrox MPEG-2 I-Frame HD codec with 4:2:2 color. I have found this to give better results when doing green screen chroma keying, since the GH2 uses 4:2:0 color. Capturing as Matrox 4:2:2 does provide cleaner key edges.
@Swiss_Boy I puzzled over Vimeo exports a while before giving up and just enabling download of the original. In terms of streaming reliability, most of the time I'd rather watch YouTube 720p than Vimeo 1080p.
