Is it possible to get the above in 1920x1080 at 24p?
Hello, anyone with luck to donwload the patch? Im in 2015 and I have a struggle to hack my gh1.
@CFreak I am using 32GB Sandisk Extreme 95Mb/s and I get flawless spanning until the card is full. But I think also 30Mb/s would do fine.
@yskunto maybe it would be best if you try yourself few settings and decide which suits your needs best way. I was using Blackout until I've developed "Varigop" which gives me even better overall image quality and less noise in the shadows under 24p. The biggest problem of the GH1 is its SD card slot, which is a data bottleneck and major problem for high bitrates. If I remember well, it was also @LPowell's biggest anger with the GH1 amd the reason to drop the development.
I must admit that "Varigop" covers now perfectly fine all my needs, especially since I have recently discovered that runing chkdsk in cmd can repair the file system of the corrupted AVCHD files if the camera got frozen. Howewer, it is essentially important to press "rec" button again after the error gets displayed (like you would stop recording) so that the AVCHD file gets saved in the form with slightly corrupted file system that easily can be repaired, at least under Windows.
I could not get freezing under full control without reducing the recording quality. The biggest problem is if major part of the sensor gets covered by tack sharp subject. Plenty of details will rapidly boost the bitrate and slow SD card writer can not write it. When RAM gets overfilled, camera will freeze. This happens however also with Blackout. It is a GH1's weak point, otherwise it is until today my favourite GHx camera for recording under good lighting.
@tetakpatak I read also your thread on "Varigop". You mention that the "max latitude" and "blackout" patch tend to break in "on focus wide-angle green-grass" scenario. Do you find the way to stabilize it?
@tetakpatak and @lpowell I think what I want from GH1 patch is a native 24p/25p for full HD and 50/60p for HD, the bitrate should be at least 50Mbps, short enough GOP for smooth motion, video can be playback in the camera, and rock stable. Does this "LPowell-Blackout" patch can answer my needs?@tetakpatak what patch and memory cards are you using for uninterruppted long recordings?
I believe I used v1 of this patch but recording would fail after a certain point. I bought the GH2 before I ever got to the bottom of it.
@yskunto I can understand that. I love the GH1, I have four GH1 bodies for I need them for long recordings (concerts in full length).
@tetakpatak thank you. It makes me easier to consider an old GH1 as an addition to my gear.
@yskunto yes, AMAIK
Does the GH1with lpowell blackout v2 patch able to playback the video in the camera? Thanks.
