@David_Cole and @others
Can the cheap intervalometers be set to do a one frame timelapse? And if they can be (I haven't gotten around to getting one) would that if you did a Y-split of the 4 pole function as a synchronised start when the camera is in movie mode? Or have I missed a point completely?
And is that the same type of switch replacement for circuitry youd need?
Kevin
Here's a simple diagram here that shows a basic, mechanically switched sync "controller". This device DOES work well with GH1/2s and manual lenses, but, may not be the ideal solution. One of its biggest faults is that the manual switches may "bounce" when closed which can cause sync problems. It does work for me. Your milage may vary! Builder beware!
Usage is simple:
1) turn GH1/2s on (with controller power off)
2) switch controller power on
3) press "shutter release" - cameras will begin recording
4) at end of take, press "shutter release" to stop recording
5) power both cameras off using the GH1/2 power switches (not the controller power)
Thanks for the info! It seems that .02<->.1ms is not that bad at all!
Can you post the diagram for the sync (dual switch) for power of the GH1/2? Here? Cheers, Alex
