Great news ... for YAGH users.
Version 2.1 will be released to enhance the performance and controllability with upgraded functions of HDMI output, which will be highly valued in professional video production.
- Time code and RSS(Recording Start/Stop) signal can be embedded to the HDMI output signal. Available when DMC-GH4 or DMW-YAGH are connected with the products of Atomos Global Pty. Ltd. or the products complying with the extended specifications of Atomos Global Pty. Ltd..
 - FHD at 30p/25p native output via HDMI is available while recording video in FHD at 30p/25p.
 - FHD at 30PsF(Over 60i) / 25PsF(Over 50i) output via SDI is available while recording video in FHD at 30p/25p.
http://av.jpn.support.panasonic.com/support/global/cs/dsc/info/update_gh4_yagh.html
We tested it with the camera gain at the lowest setting of -12dB with the limiter off. It has excellent low THD+N and a very high signal to noise ratio of 78dB at the maximum -29dBu input level. What is even more impressive is the frequency response of 70Hz to 20kHz (-3dB down points). This is where most DSLR cameras suffer – usually dropping off at 140Hz or so. The limiter works remarkably well at avoiding clipping with hot inputs. With the limiter on the S/N ratio drops a bit to 72dB but is still excellent. However, the frequency response improves to 30Hz to 20kHz which is remarkable for a DSLR camera.
Grade test with the trustworthy Voigtlander 25mm
Here is my first go with the GH4 time lapse features.
@azza_act In "1-Area" AF mode, I still see the box when switching to MF on the GH4, however the aspect of the box changes from a square to a rectangle that has slightly more width than height.
Thanks guys, do you still have that box in manual mode too? With my gh3 you don't. When you guys have you gh4 in manual mode do you have the box on the screen all the time like mine?
I have mine set for a small + and like it that way. During Video recording, I have my GH4 set for touch screen. The + is the main focus point. It also effects the light metering. When I touch the screen a small set of squares or one larger one will show temporarily. Then they fade away leaving only the + where I moved it. Without that showing, I would not remember to move it when my main subject moves. i.e. The Pastor at our Church often moves from next to the Projector Screen to next to a Chart on an easel. When next to the bright Screen, he will become very dark unless I move the focal point and sometimes I need to move it to the unlit Chart to make it easier to read.
I think you can alter the "box" by changing the AF mode from "1-Area" AF to something else. For example, you can turn the "box" shape into a "+" shape if you change the AF mode to "Pinpoint." But that is using a functional change in camera operation to achieve a change in the display. I'm not sure if you want to do that?
I would guess that the closest you can come to a similar AF function with a different display is the "Custom Multi" AF function and set a similar area to the "1-Area" AF mode.
I hope this was helpful.
@caveport Looked in the manual... No luck. This box is in every mode too, I understand this is a focus function but I don't won't it on my screen all the time. Tried every setting in the cam to try to turn if off. Has been on right out of the box. Never had this with other GH cams. Thanks
Maybe switch to manual focus mode? Or you could use the GH4 operation manual to find the answer. The box is showing the focus area used on the lcd touchscreen.
@v10tdi how to turn off the auto focus function so as not to get this 'box' showing all the time. Thanks!
Do you mean switch off the autofocus function? Or something else?
Total noob question here but does anyone know have to switch this off? Some sort of auto focus thing (circled in red) Cheers
Music video with gh4, cinelike D and some Luts.
@izash What fps did you film your anamorph videos in? I'm waiting on Panasonic to unlock the new aspect ratios in 24fps. I haven't even updated the firmware yet until I hear more news
My 3rd anamorphic test.
This afternoon I took my unfinished contraption (still waiting for the proper clamp) on the road, straight into the Tel Aviv Saturday evening traffic.
Shot in Tel Aviv, Oct. 25th, 2014 using a Panasonic GH4 in 4K Photo Mode, 3:2 aspect ratio, Cine D.
Lenses: Helios 44/2 58mm, Rectimascop 48/2x anamorphic.
Music by Jimi Hendrix.
Edited and graded with FCPX.
Shot on Lumix GH4 at 96p (closup's) and 1080p50 mode (longshots)
CinelikeV preset (Sharpness -5, NR -5), no colors changed at post.
Lenses used: Lumix 7-14, Lumix 12-35, Nokton 42.5 0.95, Nokton 25 0.95, Nokton 17.5 0.95.
Rabbit shot with 35-100 2.8 with ExTele mode.
@fahrenheit, @MRfanny, @caveport Thank you all. Ordered from Gerry Gibbs today. I'll try to make the next big decision by myself - sell the GH2 or G6.
@jp47 Yes and shooting in Australia too.
@artardi i'd get that 42.5mm BUT I already have the GH4 lol. My early xmas present to myself that lens =)
there is no limit in australia for mov never has been. its only EU that has it
