M6 Sports Settings [gop 2]
  • GOP 3
    Ad first, it was never meant to be released.
    Many REAL good settings are already done, Driftwood, LPowell, cbrandin, Ralph_B, balazer, bkmcwd.
    why then nevertheless released, well i think it have some settings that works different.
    But it needs testing, i just have 1 gh2, 1 lens and just one batterie!!!!!!!!!!!
    And it takes so much time, its a full-time job really............
    M6 Sports (vbr) v1.0d.
    Needs PTool v3.65d (280312)
    Patch is based on::
    Driftwood 'Aquamotion' AQ2 for Slow Motion Work in EX TELE mode -
    Audio: thepalalias team pasadena-pulse-audio-v2-beta-2.
    Scaling Tables: Driftwood Settings
    Sedna AQ1. (Max Detail) ..
    Mjpeg settings also from Driftwood.
    HD = 1920x1080 and WVGA = 1280x720. (30p).
    Tested with:
    Olympus M.ZUIKO Digital ED 14-150mm f/4-5.6
    And a Sandisk Extreme Video HD 30mb/s. card.
    Bitrates: VBR: is between 35 and 100 mb/s. (all modes).
    Average is between 50 and 70 mb/s.
    MB/s depents on details in the shot.and also for spanning
    When testing spanning, these where my average results... (tested on 1080 H and 720 SH setting).
    720p pal is spanning. 3.99 gb 10:33min. and then starts next recording.
    720p tele pal spans. 3.99 gb 09:13min. and then starts next recording'..(sometimes it doesn't span).
    720p ntsc is spanning. 3.99 gb 10:33min. and then starts next recording.
    720p tele ntsc is spanning. 3.99 gb 09:11min. and then starts next recording.
    HBR pal is spanning. 3.99 gb 10:33min. and then starts next recording.
    HBR tele pal doesn't span. 3.99gb and 09:27 min..(sometimes it does span).
    HBR ntsc is spanning. 3.99 gb 10:33min. and then starts next recording.(sometimes it doesn't span).
    HBR tele ntsc doesn't span. 3.99gb and 09:13 min
    24p is spanning. 3.99 gb 12:43min. and then starts next recording
    24p tele doesn't span. 3.99gb and 09:11 min. ..(sometimes it does span).
    300% is spanning. 3.99 gb 11:28min. and then starts next recording
    If it doesn't span, then the record will be saved, no lost footage..
    Files can be played back on camera.
    ps, last picture (dog) is HBR!!!!
    Update M6 Sports (vbr) v1.0e give some tighter image...
  • 77 Replies sorted by
  • i am sorry.. but no.... not by me...
  • I like to shoot in 720p50 using GF2. However, since GF2 cannot playback B-frame on 720p mode, then your GOP2 I-P frame is a good GOP option for GF2 owner who needs playback. Any chance that it will be developed further with new matrix found in Driftwood Moon T8? Thanks.
  • ptools
    Patches for testers
    and then the scaling tables
    bitrate will be lower, but if it will be stable????
    On the other hand, if you dont now how ptools works.
    you perhaps better dont mess with it
    And try this setting
    Its sports with Boom 2 scaling tables, and cluster 4 deblocking tables
    Its around 60mb............
    setf.zip
    2K
    746 x 412 - 144K
    654 x 1023 - 56K
  • where are the scaling tables, i don't know how can do that, if you can I suggest a stable bit rate that is close to 50mbs, whether a little more or a little less
  • i cant get it stable with a bitrate around 50mb/s
    But if you use the default scaling tables, the bitrate drops to around the 25/35 mb/s.....
  • sorry, but I want to know if I can lower the bit rate of this patch and if I have to make some additional adjustments. I was thinking of a 50mbs. the cases where I use my GH2 with 14-42mm is varied. Please help me, and thanks so much
  • The updated quantizers did the job.
    So who wants to try 720p pal all intra with the cbrandin pure 444 matrix, can give it a go.
    24p is also oke, but HBR and 720 NTSC is a NO GO!!!!
    1280 x 720 - 859K
    746 x 412 - 137K
    671 x 995 - 76K
  • different profiles. clips are done in 720 - 24 and HBR. in all modes, included the photo modes and iA....
    But HBR is not good...................!! 720p NTSC NOT GOOD!!!!!!!!!!!!
    Settings works for PAL ONLY!!!!!!!
    UPDATE!!
    Use the second zip with updated Quantizers
    Still only for Pal....
    667 x 995 - 70K
    746 x 412 - 125K
    687 x 995 - 72K
    746 x 412 - 140K
    735 x 992 - 77K
    746 x 412 - 130K
    sete.zip
    1K
    sete updated quantizers.zip
    1K
    1229 x 993 - 149K
    746 x 412 - 153K
  • Good question .. Latest version all i for 720 is for pal only.... !!!!!!!!!!!!!!!!!!!!!!!!!!! ntsc is is totaly wrong
    It can be fixt in the gop table and encoder setting, but then is the 720p pal not good :(
    572 x 812 - 214K
    746 x 412 - 148K
  • @mozes I am sending you a some data from a field test I did of Sports 10 settings A bitrates relative to other settings in 720 60P. So far is the newest variation looking similar in bitrate?
  • Modified Driftwood 'AQuarius' ver2 INTRA
    All intra incl 720 pal (NOT for 720 NTSC)
    'AQuarius' ver2 is merged with BOOM flat 4s.........
    I did not yet a field test, just some indoor shots..........
    So far its tested here it did not lock, on some rare moment the card speed was to slow (Sandisk EP 32gb 95mb/s
    No need to pull the power, the file will be saved!!!
    But it need a lot off testing..
    1100 x 989 - 139K
    746 x 412 - 152K
    1281 x 719 - 91K
    sete.zip
    1K
  • 03:25
    Driftwood did already have some very good 50p all i frame...
    for example Quantum v9c
    INTRA 1080i = peaks quality is around 100M
    INTRA 720p50 = peaks around 100M
    720p60 now on GOP2, peaks around 100M.
    Or Driftwood 'AQuarius' ver2 INTRA for ptools 3.63d
    Video Bitrate 24H=170000000
    Video Bitrate 24L=154000000
    Video Bitrate FSH/SH=124000000
    Video Bitrate FH/H=100000000
    Auto Quantizer for 1080 modes=3 - Most to details
    Auto Quantizer for 720 modes=3 - Most to details
    720p50 GOP Size=1
    1080i50 and 1080p24 GOP Size=1
    1080i60 GOP Size=1
    here is one picture, the same as you see ad first in the video..
    2246 x 1825 - 3M
  • Where are the still pictures? I admit I don´t looked until the end because mi internet is slow very SLOW!! The colour grading is very pushed (the colours holds up very well). Now @driftwood will try the GH3 settings on the GH2 will be interesting to see if the 50p all-I works.
  • A Gop 6 experimental setting.
    the still pictures are photo's taken while filming!!!
    colors are pushed in post.
  • 720, 24p and hbr (Pal) Profile standard, all -2 Auto WB
    Ad least that strange color shift between the different modes (720, 24 and hbr) is gone..
    Its just the 25p, it keeps having sharp edges, but not constant, thats why there are 2 screen-shots from.
    1278 x 928 - 1M
    1287 x 957 - 1M
    1279 x 900 - 1M
    1278 x 973 - 1M
  • Raw unedited or corrected screens from 720p gop2 pal.
    cinema -2 -2 0 -2
    iso 160
    F4 to F22
    SS up to 1/4000
    WB 5400k
    Before i never liked the cinema profile.
    Now i prefer it above vibrant...
    I cant believe that i did NOT!!!!! shoot in HBR or 24P ..........................
    1280 x 720 - 1M
    1280 x 720 - 443K
    1280 x 720 - 1M
    1280 x 720 - 1M
    1280 x 720 - 791K
    1280 x 720 - 982K
    1280 x 720 - 4M
    1280 x 720 - 942K
    1280 x 720 - 845K
    1280 x 720 - 1M
  • @Kihlian,There is not much different.
    Sports is based on driftwood settings.
    Its just the 720p witch is in gop2, so the encoder, gop table, frame limit, and the quantizer settings is basically the only differenced.
    By the way, thx for testing next to the real patches/settings, i did that never myself, cool to see how it holds up.
  • The new 444c4 matrix (cbrandin-driftwood), still a lot off testing to do.
    Cinema -2 -2 0 -2
    iso 200
    F22
    SS 100
    WB 5600k
    720p 50fps
    1280 x 720 - 4M
    542 x 923 - 220K
    746 x 412 - 168K
    1280 x 720 - 944K
    1280 x 720 - 950K
  • there is no color corection done.
    Its vibrant/cinema and smooth all set to -2, and with kelvin set to 5600
  • Setting A with some small updates...
    Just a encoder setting changed, and AQ set all to details...
    In the clip (720p 50fps) first clip normal speed, next part extreme slow down with twixtor.
    Its a long slow down...
    Orgiginal .mts file, so you can check it.
    http://www.speedyshare.com/y9CEx/download/00008.MTS
    Sports 10 setting a.zip
    2K
    746 x 412 - 140K
  • Setting E, HBR 25P (gop1)
    Some shots in the backyard, my back is still shit, i cant go out to do some more serious shots.
    Profile: Vibrant all -2
    Exposure +1
    Shot in Aperture mode (almost all in f8).
    SS from 25 up to the max 4000
    Iso = 200
    Edited in vegas pro 10e, only added the levels plugin.
    746 x 412 - 148K
    746 x 412 - 171K
    1920 x 1080 - 2M
  • The screen shots looks good. Will try H in the next days.
