Try resetting the cam's native mode to factory default (NTSC, PAL, Cinema whatever it came with) and then formatting the card again. Re-copy the firmware bin file over and turn cam off. Insert card turn on, wait for the status rundown to complete, and hit the play button. Hopefully that will work. It worked for a friend having the same problem.
You are having the same problem I had at first. The reason I think is because you probably downloaded the AH4_V11.zip when you actually need the GH4_V11.zip which you can get here:
you could probably rename the AH4_V11.zip to GH4_V11.zip but I just downloaded from the site above and everything works.
See if this helps.
@bleach551 Nah I wish I did make that mistake but I have the GH4 file. Thanks for trying though. I appreciate it.
That was what happened to me I kept trying over and over again , until I actually looked at the zip file I downloaded from Panasonic and it was the AH4_V11.zip. Double check if you don't mind me asking. This is what You get when you download from the Panasonic Website I saw linked to the update I think, Correct me if I'm wrong.
@bleach551 I double checked and its the right one. I'm gunna try it on my pc instead of my mac to see if that makes a difference.
Most usual reason - battery is not fully charged.
