Sony FDR-AX100, 4K camcorder for the masses
  • 163 Replies sorted by
  • Need some advice from FDR-AX100 folks. I need a good B cam that will match the Sony FDR-AX100 which will be used as A cam for upcoming shoot. I need the B cam to basically match image type/style/colors etc. Hoping it would be reasonably priced for a B cam. Any ideas? Might be dumb question, but can I shoot FDR-AX100 at 4K and shoot B cam at 1080P and expect a reasonable match in terms of editing images together? Thanks!
  • Wow--amazing that it did so well against the EOS M. I was just looking at that cam since it is sometimes available for cheap.
  • your videos are great for someone like me starting out and learning how to shoot. thanks!
  • The 12X zoom on the AX100 is smooth, flicker-free with no re-focus and the 4K brings out the detail at the far end. You cannot have this capability on a DSLR.
    This short video demonstrates the zoom, focusing in on a scene miles away from a great height:
  • This is what the main concourse really looks like midday (not like that photoshopped jpeg) - an unretouched 4K video frame grab:
    http://i849.photobucket.com/albums/ab56/markr041/GCTDark_zpsb549cbcc.jpg
    There is a narrow channel of light, almost a hot spot, from the big window, but it hardly illuminates the room as in that phony-looking picture.
    And the key point is that the main concourse is only one room in the complex; the rest have no windows. The hallways are dark, the basement big room is dark, the train passageways are dark. Even the Apple store part of the main concourse, as you can see in the video, is very dark - lit by individual lamps. Contrast that with their standard stores, which are bright and airy.
    At f2.8, average gain needed in that big room was something like 9db. The telephoto close-up of the girl on the phone rose to something like 18db of gain (because the aperture was closed down at the telephoto end).
    You can compare how the big sensor EOS-M did with an f2.0 lens in that same place - it struggled:
    Or the BMPCC with an f1.7 lens:
    That place is a real challenge for video. The AX100 did fine.
  • Go there all the time when I play at Carnegie Hall :) This photo shows the giant windows at the end of the hall, and the smaller windows in Beaux Arts style that flow along the long walls. You can see in this photo, light pooling on the main floor. http://www.nyc-architecture.com/MID/MID031A-07.jpg
  • @DrDave: Been there? The lights are pinpoints in the high ceiling, and those windows do little to illuminate the main floor. Most train stations have glass ceilings precisely because side windows cannot illuminate a vast space. This one has a solid ceiling with tiny lights. In any case, that's just one room. Most of the terminal action is below that floor - no windows - or around the room - tiny or no windows.
  • Certainly not one of the dimmest public spaces with those overhead lights and giant clerestory windows.
  • The AX100 in dim light - Grand Central Terminal, one of the dimmest public spaces in the world.
  • 2000-year old tomb museum, historical exam-cramming academy, drumming instruction, and modern icons.
  • Mastercard advertisement:
    Sony AX100 4K Handycam: 2K
    Dragonfly facial expression captured with AX100: Priceless
  • Folks, is there any means to adjust/lower Contrast on the FDR AX100 ?
  • Autofocus test:
  • @markr041: Is also the overall AF performance better now (with the new firmware)?
  • Here is a video testing the focus tracking performance of the AX100, with the new firmware. No human I know wants to be tracked, so we will have to settle for these pretty tests. I have done this before, and I can say that other cameras have failed the same tests. (e.g., those Sony NEX cameras):
  • Thanks.
    And, a bonus - Sony AX100 firmware update today (at least in the US)!
    This utility updates the system firmware and provides the following benefits:
    • Adds Direct Copy for XAVC S format support
    • Adds the following auto focus performance improvements:
    • Focusing accuracy for main subject
      • Focus tracking performance on a person
      • Adds the 1/50 shutter speed
    • Improves zoom speed during movie recording"
    http://esupport.sony.com/US/p/model-home.pl?mdl=FDRAX100&template_id=1&region_id=1&tab=download#/downloadTab
