I've created the Best Settings thread, feel free to share your discoveries: http://www.personal-view.com/talks/discussion/10320/gx7-gm1-best-video-settings
@Manu4Vendetta The quality is better at similar bitrates to older cameras because Panasonic's latest video engines are using higher h264 profiles. Higher profiles activate more complex encoding processes within the h.264 specification. These require more complex hardware but give you better encoding performance.
@Vitaliy_Kiselev I searched but didn't find anything on whether GX7 has been hacked? I like the IBIS and with a hack this could be a cool combination. Thanks.
I recently obtained a GX7 and have to say Panasonic done a grand job with the camera. Video quality is excellent even the "low" bitrate its pretty robust in comparison to other "low" bitrate cameras ive used..certainly less video looking than the G6 and more natural skin tones...something ive always had an issue with the Pannys since the GH2.
@Manu4Vendetta It's not only a matter of bitrate, you know ;) GX7/GM1 video quality is suitable for festival projections as well as GH2/GH3 footage. I've tested a pair of shots last Friday on a cinema screen shot on the tiny GM1 by a fiend of a mine ...definition of GM1 (who shares the same sensor of GX7) was very very good, and the fine digital grain in high iso scenes (3200) gives the footage a nice cinematic grain without excessive loss of DR. A little remark on fast movements, perhaps, but it would be useful a more accurate test to verify it.
To my eye, GM1/GX7 looks very natural on the cinema screen, much better than G6 footage...but it is also a matter of taste ;)
Can be usable the GX7 viable as semipro camera for video? I explain my doubts.
The bitrate is very low, but in internet and the videos I downloaded on my monitor look great, along with the GH3 and the 5D MKIII, cameras with a bitrate several greatest, where is the trick?, has Panasonic some new technology that allows a low bitrate more information than the cameras wit a higher from two years ago?
This image quality in video look good only on internet and a medium monitor (I have a 14"), I can send send some footage to a festival without fear that after having lost the image quality?
This camaera dont let use the HDMI output while recording video, but if monitored via WIFI, can connect to some device in which the director see what we recorded via tablet, note, etc but mantening the controls in the camera?
@JBraddock, isnt my video, Im only sharing.
@Manu4Vendetta, do you use any sort of support for your setup? I have Kowa 8Z and I worry that the weight is too much for the lens mount. What do you think?
I shot this short clip today. Details are in the description.
A couple of underwater videos made with Panasonic Gx7 into a Nauticam Housing to some mantas in Maldives. Manual White balance , ambient light
@pizza4D, Oh, you are right, I forgot to check that. I wish it only had one mounting point and a bit of space at the top. I think I'll wait for the Honu cage for BMPCC. Looking at the preview image, it seems like a good option.
On a final note, has anyone managed to tether GX7 to a Mac? I've tried numerous times, but it cannot find the shared folder.
@JBraddock The difference of almost 5 mm in height is most likely a problem: http://camerasize.com/compare/#472,453
I am looking for a small form factor cage for GX7 and was wondering if it is possible to use a BMPCC cage? Other cages are too big or expensive. Varavon armor cage for example looks really good. As long as I can access the top dials, the rest is not really important. Any suggestion?
