See this. Someone tested out Lumix 14mm after the firmware update. Almost stepless aperture change on GF3. GH2 shows some stepping. Hopefully the upcoming new firmware improves it.
@Rambo I did some tests and swear the jumps in aperture are less noticable than they were in auto/shutter priority on the 14-42. It's still quite noticable though, definitely not stepless.
@Sam_stickland I updated the 14-42 with a hacked GH2, worked fine for me.
Just checked, the 45 - 200 was already updated some time back, this update is only bringing the others up to scratch. This makes 7 lenes in all with step less aperture and improved ois
Question: How can I determine the current lens firmware versions on camera?
From what I gather by reading the instructions is to go through the steps and if you do net get the option to upgrade, then you have either the same or newer lens version in camera. Is this fucking correct? Is there any easier way to view current installed lens firmware?
Are lens firmware updates independent of the body firmware? Or are they one and the same?
UPDATE: So it's clear from the file names and sizes the lens firmware is just that. Should we expect any strange interactions between new lens firmware and hacked GH2 firmware?
