The 105 and 135 DC Nikkors are my favorite portrait lenses on FX - gorgeous skin tones and unreal bokeh. Curious to see how they perform on GH2 and video in general.
Following up on @Brian202020's post, here is a list of video-friendly Nikkor AF-D primes from 85mm up to 300mm. In addition to possessing excellent optics, these lenses all employ internal focus designs with outer lens barrels that neither extend nor rotate. Unfortunately, this is not the case with Nikon AF-D lenses wider than 85mm - their lens barrels all extend when focusing on close objects. The lenses below all share the following properties:
Nikkor AF 85mm f/1.8 D Nikkor AF 85mm f/1.4 D Nikkor AF 105mm f/2 D Defocus Control Nikkor AF 135mm f/2 D Defocus Control Nikkor AF 180mm f/2.8 IF-ED Micro-Nikkor AF 200mm f/4 D ED Nikkor AF-S 300mm f/4 D IF-ED
Thanks for the info on the Nikon 85mm f1.8D, I wasn't aware of its internal focusing mechanism, which it shares with the Nikon 85mm f1.4D. As you indicated above, this means that its outer lens barrel neither extends nor rotates. However, like all Nikkor lenses, it does have proper focus ring rotation in the Nikon direction.
@last_SHIFT "Nikkor 50/1.8 AIS - $35 Declicked aperture in a local shop while I wait 5-10 minutes - $12 Generic Chinese adjustable focus ring (haven't glued it on so I can replace it when it breaks) - $5 Generic Chinese 52-77mm step up ring - $2
Total= $54, did all of this during a lunch break."
Dulcos Cine Mod = $250 (without lens, shipping, lead-time, etc).
This is probably the best choice I've ever made in lens gear, the step-less aperture is so fucking smooth. I'm also going to do the same thing with my Nikkor 28/2 AIS - not quite ready to do this on the Nokton 25/0.95 just yet :-)
Well..I cant use my 20mm pancake with my rig(I suppose follow focus to be precise) for sure...its just to close to the camera body and I don't have a reversible gear on my Fotga FF.
Personally I like using old M42 Lenses (screw mount) with the adapter. 1- They are cheap got a nice f/2.8 28mm on Ebay for 28 bucks... 2- They all reach out to the FF and have a focus stop point --yes they do move in and out but unlike the Panasonic lenses they use a mechanical focus so there is a clear end and beginning when you turn the ring. 3- There are fast lenses I've seen them ranging from 1.4 to 2.8 4- They look great, SUPER TAKUMAR 1:1.4/50 for example....
I don't understand why people are saying that the Voigtlander 25mm doesn't work with a rig. I just shot the better part of a feature with the lens (on a hacked GH2), using a follow-focus and 4x4 filters in a matte box with no ergonomic problems at all.
I am dreaming.... maybe just to see the result.... of the Carl Zeiss LWZ.2 leightweightzoom lens on the GH2.... would just right cover my needs.. and allowances for the next 10 years... ;-) anybody tryed out on GH2?... mft mount should be available soon!?
I understand that the Voigtlander doesn't work with a FF system?
I have the 14-140mm lens and am looking to buy 3 lenses. Which ones do you recommend that offer a consistent color range (different lens brands have different characteristics). Do the Olympus/Panasonic MFT lenses match?
@stonebat: The idea of a "cinevised" lens filter is something I've thought of for a long time! The only hard part is that each needs to be made for each model of lens (to fit them) and for the focus marks to match... For new lenses it's ok, but I'd love to see that for my Nikons!
@Vitaliy_Kiselev how much do those re-housed Zeiss lenses ,and what's the benefit over a mod by Duclos? (his look very good, but are not "re-housed". He adds Delrin focus gears, declicks, and standardizes the front thread.) http://www.ducloslenses.com/Duclos_Lenses/zf.html
@markussen @kazuo Contax Zeiss primes are superb still photography lenses, but as with Nikon AI-S, Canon FD, Pentax K, Minolta MD, and Konica AR primes, they are not really well-suited for use on a rig with follow focus and matte box. Image quality is not the issue here, it's primarily a matter of ergonomics, with cost a secondary factor. The lenses I listed above are all available new or used for less than $500.
@Vitaliy_Kiselev Thanks for posting the detailed images of the Zeiss CP.2 prime lenses. These are designed explicitly for video use and are ideal examples of the type of ergonomics that's required. They currently retail for bit less than $4000 each.
It should be relatively easy for lens makers to implement fixed length barrel.
e.g. Nokton 25mm 0.95 could have a "male" filter thread around outer barrel. Screw in a 77mm "female" housing. That housing should cover the max barrel length of the lens.
