Specifications:
Available at:
Previews and reviews:
http://www.focus-numerique.com/panasonic-lumix-lx7-compact-expert-450-8364-news-3468.html
http://www.trustedreviews.com/panasonic-lumix-lx7_Digital-Camera_review
Samples:
Well, I think you can get Samsung lenses for cheap now :-) And with pancakes or power zoom it is small.
but it isn't as small or as cheap (especially once you factor in lens cost)
hmmm.. which to pick, which to pick
NX500 during sale or used :-)
Hmmm... it is now back up to US$279, but that is still a crazy good price for a new high end premium compact. Kinda tempted by it, though the old secondhand RX100 mk1 models are starting to drop down to be nearly as cheap! hmmm.. which to pick, which to pick
Panasonic Lumix DMC-LX7 Digital Camera for $247 http://www.bhphotovideo.com/c/product/880960-REG/Panasonic_dmc_lx7k_Lumix_LX7_Digital_Camera.html
LX7 60fps 60frames burst mode 3,5M +50% twixtor, playback at 30fps = 4x slow motion, weird transitions due to twixtor, actually the original frames from the burst mode are only half as sharp as single photo 3,5M jpeg, probably due processor limitations
Hello, Yesterday i bought LX7. Just for test, for checking by myself how it's really works. Works ok. So im 100% decided to buy LX8 and FZ1000 when they'll be available.
No FlipLCD and no HDMI Live - it's shame for LX7, especially when using low angle shots ;)
here is link to first vidtest no custom setting, just factory settings (audio not from LX7)
LX8 is coming in July
Is is possible to read out and save the existing firmware from the LX7?
Thanks, -dennis
I'm having alot of fun with the video of this little camera. I really love the stills also. Here is a short video I made with the camera. Some of the footage is from my little HX7V and you will probably notice. Fun stuff
May be, but you'll need to make some very high quality custom cable.
I'm wondering if the EVF could be connected through a small cable (~30-50cm) so I could put the EVF somehow on my glass (a la Google Glass) so the camera position would be completely independent. It would be very useful for filming with a very low/high POV.
Earlier in this thread, it was mentioned that we need an official firmware upgrade before there can be a hack, so we need to look for issues that may make Panasonic release an upgrade. Here's 2 things I have noticed:
There is thus an overexposure issue with the camera, and the means to compensate or detect this situation enough to work around it is also broken. I know the issue is less than 1/3 stop, but it has ruined a lot of my shots through overexposure. In fact, until I realised it was poor default exposure, I assumed it was low sensor dynamic range, because the camera seemed so prone to overexposed pixels in highlights!
If enough people complain about this we may get our firmware upgrade...
Electronic connection
@jojoen: "trigger connection" Is it an electronic/electric connection or something mechanic?
I have actually repaired the lens ND filter of the first one I had. And I also made a trigger connection since I fly multicopters and need trigger from my transmiter. Yes it is not for anybody... But I am used to and dares to fiddle with it as long as it might be repaired. For sure I will need some damaged or cheap parts as I see LX7 popping up on ebay for under 300usd now and then. Luckily a local shop fairly close had a camera on stock so I could replace it quick. The prices in Norway on LX7 have fallen by 100% this summer luckily but only a few shops have them. Strange since it so good. But ok by me as very few other multicopter pilots can offer the same performance...
This looks like a total loss. Possibly it could be repaired but the cost will likely exceed the purchase of a new one.
The service manual will get you part numbers for the camera. At the minimum you will need the lens unit, pn VXW1506, at a cost of $164. There may also be damage to the aperture ring, the sensor, and anything else that was broken.
You can find the parts costs in the US here: http://www.pasc.panasonic.com/Epartr/PartsListChoice.asp
Once you have the lens unit it has to be installed. That will include removing the MOS imaging sensor from the old unit. Unless it it also damaged in that case you have to buy another expensive part. Aligning and calibrating everything after the parts replacement requires special tools and software.
There was a post that the website shopping cart didn't work but they called and completed a transaction over the phone.
You can try ebay for a LX7 with broken viewscreen. Usually cameras for parts on ebay have unrealisticlly high asking prices. An LX7 with only a broken viewscreen can be repaired pretty easilly. The above website shows the display unit cost at $154.72.
As you can see the economics of repair is pretty poor. Despite having a service manual I do not think Panasonic ever repairs these cameras.
Glad he was not seriously hurt in the accident.!
Anyone know of source for LX7 parts or broken cameras? This one felt a rock while in the pocket of my son. Luckily the camera took the blame and not his head...
jojoen,
Good point about i.Dynamic being not grayed out in M mode. I just checked my camera with the dial set to M; the i.Dynamic was NOT grayed out but it was off. However, I should have mentioned that customized my M mode to C2-2. I just left the dial at C2 and never need to change it to anywhere because I set C2-1 to A mode, C2-2 to M mode, and C2-3 to manul video mode. However, when I am in C2-2 (M), the i.Dynamic is grayed out but shows "off". I will look into it some more.
Thanks.
Interresting. I just bought a brand new LX7 after my last one was crushed by a stone (my 3rd LX7 now). This is a PAL version bought in Norway and in the menu it says firmware 1.0. From before I have had both PAL and NTSC versions.
In M mode the i.Dynamic is not greyed out. If i put anything but off I can get what you describe. But off is still iso80.
I can not check the older cameras as one is given away and one is crushed
I need to alert every LX7 owner. There is a MAJOR bug in photo mode on LX7. Please see my post here http://www.personal-view.com/talks/discussion/8244/panasonic-lx7-photo-topic#Item_4
@stevens - I don't think they care how many complaints there are. Maybe if they think it will affect sales.
@jojoen : "X909 low light". Hi, I've put a link into the desc. (watch on YT page) of the "Shining Shadows" video to the orig. norm.speed version which was made at the same time with X909. You can check the IQ if interesting I tell you my manual settings.
The thing is Panasonic might not release newer firmware. I tried already by email them complaint about 30 min, about noisy audio .... They asked my camera model serial # without answer my question of newer firmware -:)
