I think it's appropriate to start a new thread here and not to add it to the main BMPCC thread. Might apply to other S-16 alike cameras too in the future…
First the Lumix 7-14mm 4.0 zoom, since so many of you are hunting down a wide angle covering that sensor with it's massive crop factor (2.88 compared to photographic FF). The question was: what do we have to expect without in-camera corrections? Well, at 7mm we have massive barrel distortion, good sharpness "wide" open and minor CA in the corners. Distortion improves considerably at 10mm and is gone at 14mm. CA disappears too. Please excuse the bad lighting, but our studio is busy and so this was very improvised (camera goes to the next reviewer tomorrow).
BMPCC + Sigma 18-35mm. Creative lighting test:
Slow motion test with the BMPCC. Nikon 28mm prime with generic speedbooster and WA adapter:
No, they are vintage and can only be found in second hand sources.
I can´t find them in B&H... and I live in argentina... :( . Anyway thank you!!
If you want the camera to be very unobtrusive, why not try and find some of those Pentax Cosmical lenses? Take acre to get versions made for 1" sensors, since 2/3" versions don't cover the BMPCC.
They are cheap, light and small, with decent optical and mechanical quality. I have a 12.5, 16 and 25 – all of them f 1.4 or 1.8. They Voigt is in a different class for sure, but WO it's softer than those Cosmicars and 17.5 is often not wide enough for interiors. It acts like a 50mm plus on that small sensor, while the 12.5 is like a mild wide angle.
Hi! I´m buying a bmpcc, and I want two lenses. Thinking in voigtlander 17.5 mm and srl magic 12. I´m shooting a documentary that needs to keep small, i don´t want the camera to be very notorious. What do you think about the lenses choice? Thanks a lot
This is a really nice topic! I was wondering if somebody did test out the Cooke SK4's: 6mm, 9mm and the 12mm. I would love to know if those are covering the BMPCC (Blackmagic Pocket Cinema Camera) sensor. if somebody could share some footage that would be amazing.
I tried a canon B4 zoom video lens (2/3") on the Bmpcc and, as I expected, the vignetting is almost absent. I get black corners only on wide angle, so I assume it is usable if you do a small cropping in post. The overall quality seems better than using such a lens on m43 with Ex tele conv (2x), and the zoom factor is smaller. I will try it better, and post some samples. Did any of you make such a test?
@eddy_warhole: I can't tell, only tested the 12.5mm.
I am interested in the Olympus or Panasonic 14-42 pancake lenses for this cam - can anyone speak to the functionality of these lenses? Obviously they're slow, but I'm wondering about the ability to retract lens when cam is off since the lenses wont be on manufacturer body... Also, the Panasonic has a lever for focus instead of a ring - what is that like to use, anyone with experience with either of these lenses. Oly seems better but no IS...
Hey I got one question.
Is there a difference in sensor coverage and rendering of MIR 11m 12,5mm vs MIR 11m 12mm?
Thanks in advance
Now to Russian lenses for the Kiev-16U camera, finally I received the thin, black adapter from rafcamera. He's a very nice guy, BTW, keeping up good communication. I didn't buy my lenses from him, but I would trust him for lenses too.
The adapter fits very well on the BMPCC, a bit tight on the GH2 (which I used for test shots). The only complaint I have that you don't have any grip on the ring, it's just flat and difficult to turn back from a tight fit. It looks really good on the BMPCC with such lenses, though.
MIR-11 12.5mm f2 It covers S-16 indeed, but the corners have massive CA and lack sharpness WO. Plus, there is quite some barrel distortion, it nearly looks a bit "fish-eye". Center is really sharp from the start, contrast aint't bad either, but even at f4 the corners lack sharpness and are still darker. Very long focus throw for a wide, about 270 degrees, with a MFD of 20cm.
VEGA-7-1 20mm f2 Covers well, but corners are soft even at 4, less CA than the 12.5 (but still some) and nearly free of distortion. Long focus throw and MFD of 40cm.
TAIR-41 50mm f2 Covers even MFT with corners a bit darker, shows mild pincushion. Low contrast WO, but pretty sharp into the comers and no CA, better at 2.8 and getting nice and sharp at 4. Focus throw might even be longer than the others, MFD is 70cm.
BTW, while the wider ones have a six-bladed aperture with a sawblade look like some Cookes when stopped down, the Tair has so many that i don't like to count them and stays round whatever you do.
They all have click-stops (which surprises me on Russian lenses) and there is considerable sample variation in centering and color (which doesn't surprise me, my samples are from '67 to '71). While the adapter seems to be high precision, the lenses are not. Flange distance is all over the place and they may need some shimming.
Don't expect modern performance from these lenses, the two wider ones never get really great in the corners on the BMPCC, but they have a very vintage look and nice flares, which would not be so easy to mimic in post. I can imagine quite few situations where I'll like them. The only alternative are the Zeiss (Eastern) Tevidons if you want this look.
These and a BMPCC are much cheaper than a Digital "Bolex" for going vintage ;-)
Quick test of Nikon AIS 50mm F1.8
@nomad No problems with the 20mm so far. I did have some when I first got the pocket in November, but I did the Panasonic firmware upgrade for the lens on my GH3 and I think that fixed it, but I'll do more test to make sure.
Did you experience any problems with the 20mm, like sudden changes of aperture or focus?
I haven't seen any videos with the 14mm and wide angle adapter making it 11mm so here is some quick graded shots. The other video is a test with the 20mm.
I received my pocket cam in November but have not been able to play with it until now. This is basically a test of the Lumix 14-45mm as a walk around hand held lens. Very rough/simple grade and edit. I am usually pretty shaky with handheld and wanted to see if I could pull it off with the OIS. It turned out ok as long as I am stationary, but panning is still jittery, plus I think Vimeo compression is adding some too.(just checked definitely less jitter on download) If I practice more I think it might be usable in certain stealth situations, however I anticipate much more shoulder rig and tripod use. I also tested the internal audio with the Zoom H1 as mic, with internal audio set at 60 and Zoom on auto. It was just for picking up ambient sound but I think it works fairly well. I got this lens for $100 bucks, and I love it (for the price). I'll be doing more cinematic grades with it and my Nikons later.
@nachelsoul the stepup rings you can for example find here: http://www.ebay.com/itm/Pro-Step-Up-Rings-30-30-5-34-37-40-5-43-46-49-52-55-58-62-67-72-77-82-95-mm-/181236205147?
@nachelsoul The SK 25mm 1.9 thread size is indeed a bit odd, it is 30.5, a size rarely found, however it is available and is also used for some of the good old Pentax 110 lenses...
@nachelsoul no problem whatsoever with the mistake, thanks a lot for showing us your video. I just wanted other people to be able to find this very nice lens on Ebay and other places.... one warning: it does fully cover a 4/3" (or m4/3 camera) sensor, however be careful to screw filters on its front because in that case it easily starts vignetting.
@Nieuw you are right is 1.9, and also right this is not a rare lens, although there a few copies around. It is Ernostar design not a very common formula. Sorry for the mistake.
@nachelsoul are you sure it is 1.8 and not 1.9?.... 5 bucks is indeed extremely cheap, however the lens is not that rare, quite nice and also fully covers 4/3" sensors....
A very RARE lens. Schneider Xenoplan 25mm f/1.8 C-mount. Incredible sharpness all around the frame and in all aperture range. And cost me 5 bucks :D
Edit: Not so rare
