Yeah, I agree the 44M settings are really good. I can't stop using the 66M AQ2 settings, but I can't give any decent reason as to why I don't just fall back to the 44M (apart from that one shot I took in a bar in lowlight; you know how it is, theres always that one shot) which are equally as good and have all the benefits you mentioned. In theory the 66M should render motion better, but yeah, how easily do you judge that empirically (I should try and get hold of a metronome). So I'm being irrational, my head says the 44M AQ4 and my gut says 66M AQ2. I think I'll end up with two settings in the end, I'll use the 44M most of the time, and switch to a 66M GOP 6 (if I can get it stable) occasionally.
@Stray 66M AQ4 is stable on my camera so far (in 24H mode). I do have the feeling that IQ is somewhat better compared to 44M with fast motion and high shutter speeds... but if so, it's negligible, that's probably right. The problem is you can't do real side by side comparisions... as long as you can't control the motion in the scene :-) However I have not done a lot of tests with the 66M settings by now ... as I am actually really happy with Chris' 44M setting. 44M is plenty (IMO), the camera is stable, in-camer playback is fine, files do span at 24L... and finally 50i in the 44M setting looks better than 50i in the 66M setting. So actually I am not yet sure whether or not I will use the 66M at all ... I will however use a 24H GOP3 setting for its motion look. But here again I haven't had the time to look deeper into the GOP3 settings ... other than some preliminary tests.
@towi I didn't think running 66Mbps at AQ4 was stable, which is why Chris took it back down to AQ2 (that and the fact it didn't actually improve the IQ in any dramatic worthwhile way). As bitrate increases AQ can go lower while IQ remains the same is my current understanding of things. Personally I had no problem running the original AQ4 settings, but I couldn't see any real noticeable difference between it (even in post) and 66Mbps running at AQ2.
Too, cbrandin's 66M settings modified = setc (supposed to be used at 24H and FSH/1080i50 only)
modifications: - NTSC-PAL switch checked, 30Min limit removal checked - 66M AQ4 - some settings from the original settings unchecked for troubelfree 50i recording
"Well put @stonebat. As you may have noticed @driftwood and I are approaching settings from opposite directions. We go at each other pretty good from time to time over some issues. It's public, and it's great. Speaking for myself, I've learned a lot from his efforts and our debates - even when we don't agree. Also, I acknowledge that for some applications his settings are exactly what is needed. There is no such thing as "best settings" - it's like saying f5.6 is better than f8, and leaving it at that." cbrandin
I Agree. We're all striving for the best possible solutions. There's always more than one approach. If I'm wrong I have no problems with it.
Hello. This is my first post. I'm sorry but I do not speak English. I use translator. So they can request funny linguistic anomalies.
I did test a strong color correction. I wanted to see if there is no breakdown of the material. Any noticeable changes in the compression. But it seems that it is very good. Tolerate working very well shot. Additionally, I used a 50% slowdown. I am happy with the result. I work on Avid Media Composer 5.5.
66mb/AQ2 settings I use. Below the source and after working (mp4)
Has anyone done any controlled, repeated tests that include color correction/grading in the process? The thing is, even stock GH2 stuff looked pretty dang good to my eye . . . until I started to manipulate it. Then it fell apart pretty quick. No big deal, I was just thinking that some testing that had grading in the process might make some of the differences more visually evident in the test footage.
P.S. @cbrandin thanks for your time. I'll be going through yours and @driftwood settings once my Sandisk cards arrive.
Chris, You are absolutely "on a roll" today man! You're skills, info and help are a great asset for all of us!
Chris>"I challenge anybody to show me where any settings can produce bigger I frames that my 44M settings. I also challenge anybody to explain how even equal IQ can be achieved with smaller I frames, irrespective of P and B frame size."
This is the kind of stuff I like to see! This is exactly the kind of tests to drive the best quality with reasonable bitrates.
My only concern is the comparison 66Mb/s AQ4 motion frame to HDMI uncompressed motion frame Ralph_B provided here. I realize 66Mb/s AQ4 static image creates nice quality (healthy I-frames), but 66mbps/AQ4 really loss more detail under Ralph_B's example than I would of expected. Ralph's 66Mb/s AQ2 motion comparison was better. There was still some visual loss in detail, but no where as bad motion compared to AQ4.
If we can just find the "magic" setting that offers the high I-frames for static IQ, but also still holds well for motion.
As you know, one of the greatest complaints from most all video cameras and their compression codecs is the complaint that the image goes soft more than normal when panning. Even the Sony EX series XDCAM had some users complaining of softness during pan. Granted, some of the motion issues are due to the viewing monitor. The lists goes on-and-on from there... I remember my old JVC HD100 - many had the same complaint about motion.
These damn compression formats can be a real bitch! LOL
@AK2 I'm not sure to understand the link between your issue with mc5 and the internal span issue with the gh2... By using your tip, can you record in one take until your card is full - or do a 30min continuous shot - using cbrandin setting (or any ptool 3.62 setting over 32mbps)?
@cbrandin I know what spannig does ;). But if I use the removal from the hack mc5 tries to import every mts clip I shot with te gh2 as if it is spanned. Even if the clip is way under 4gb mc5 imports it and than it starts with a spanned import again and I have to restart the program because it just keeps to show the import spanned clip window. Without the removal its just working fine.
@paglez Yes I got a eu version of the GH2 working fine if I do not use the 30min limit removal.
No, the spanning issue has to do with what happens when a file reaches 4GB - and that can happen in about 10 minutes at 44M. It has nothing to do with the EU 30 minute limit issue.
It seems we need to test many various settings instead of searching for best setting. That would increase the chance to discover new behaviors of the codec. Then VK and Chris will improve the codec in the future PTools.
Absolutely! There are things that simply can't be improved by changing current settings and we are working hard on those. Also, realize that we can't anticipate what settings will do at all times - that's why your testing is so important.
