Hi digital amator, what about the 50mm FD? Have you testes it? Hace you improve your film look?
g6 + 14-42 kit test
Fair enough. LOL.
@LucidStrike if the G6 is hacked, I'll buy it too ;)
Eh. Preference.
Personally, I'd rather shoot at 60p and have more options, including going to 24p. Also, the cameras have the same resolving power and such (same sensor afterall), and the G6 handles low light and noise a bit better. It's just the compression that causes any issues. Even with those issues, the G6 is still AWESOME for video and BETTER than the GH2 for stills. It's not like stock G6 video is crappy.
In the end, the G6 could theoretically be hacked eventually, but the GH2 will NEVER be able to match the feature set of the G6.
@digitalamateur Sir, they should have bought a GH2. The GH2; Vitaliy hack with a patch of Nick is still the number 1 and film look (24p) at its finest
This is why oscillian said to turn off iDynamic: https://www.personal-view.com/talks/discussion/comment/132366#Comment_132366
hi again....so anybody test more g6 ? some coclusion about presets ? I tested mainly "natural" with all combinations of -5 to +5 and i think the best is -5,-5, 0(-2), -5 and the idynamicrange is very useful option.
...and oscillian...i bought canon fd 50mm 1.8...now i'm waiting for adapter and then i go test more. I must find "gold mean" with presets till september.
I just want buy panasonic 20mm 1.8 or olympus 18mm 1.7 but this canon looks great...but that not will be too tight ? 50mm x2 crop that will be 100mm..hmmm
Thx....i think this kit lens is shit. I use this same presets which some guys with Panas 20mm and they have amazing video and i have very very poor.
It's a very big subject :) For film look number one factor is location. Next up is lighting. Then lens choices and camera moves, followed by grading. Tom Antos has a couple of good tutorials that inspired me when I started out a while ago: http://www.youtube.com/playlist?list=PL3AF9B2B010B69D0C
ok i test 2 presets:
1) Let's call it "film look"
style: Natural presets: -5,0,0,-5 format: avchd, 24p exposure mode: M focus mode: AFC contiunuous AF: On Metring mode: Multi Metering i.Dynamic: OFF i.Resolution: OFF Aperature: try different value Shutter speed: 1/50 iso: I try all WB: I try different
2) Let's call it "clean HD" style: Standard presets: 0,0,0,0 format: avchd, 50p exposure mode: M focus mode: AFC contiunuous AF: On Metring mode: Multi Metering i.Dynamic: OFF i.Resolution: OFF Aperature: try different value Shutter speed: 1/100 iso: I try all WB: I try different
Outside and Inside: bad sharp, gradient, burned, not natural color...even not film look. That G6 cannot be so bad...so that must be my fault...but where is a problem ?
Oscillian and if I want clean 50p video (no film look) than what presets best to use ?
Thx man i try it after work.
Oh, film look :)
AVCHD 24p, Film profile: Natural -5,0,0,-5, Shutter speed 1/50th. Use a variable ND filter to set exposure, use aperture settings to taste (deep focus, shallow focus), manual white balance. Save to Custom memory C1!
Best result is probably with a Voigtlander 25mm f0.95 lens, but the 14-42 and 20 will do to begin with. Good luck!
Now i tested kit 14-42. In august i will buy pana 20mm...but now i must set up all and i have a problem with this.
i just try to sett alll to make good film look. I try set up different mode, saturate, contrast, shutter speed itp...and my video is poor
