AVCHD: Extreme settings
  • 278 Replies sorted by
  • @ivan858
    "i had the bitrate drop off at 88mbs as well, so i jacked up the bitrate. 132mbs handles the death chart fine, i stopped it at 20 seconds. 154mb overloads the codec at 8 seconds."
    Hey, this is great, that death chart screen grab looks like a real breakthrough!!! Can you post you settings file? I really want to try it on a "drive of death" through this tree-lined highway I use to try and crash the codec.
  • am using 85m gop3 Ai4 buffer x36k 14-140 lens and its holding indoor and outdoor shoot with an average bitrate of 82. realy awsome!
  • Well I never thought the GH2 could go that high, what card are you using and how long can you record before the card gets full??
  • My last attempt at 3gop/max bitrate til the next release. goodbye for now..
  • @kae I believe it is here:
    http://personal-view.com/talks/discussion/699/avchd-maximum-image-quality-settings-and-testing#Item_120
    I'm no tester, but I've been reading. from what I understand, it is not PTools problem, but GH2 firmware problem, and VK is aware and will work towards fixing it. Nothing super specific, just low GOP stuff is messy right now.
  • I've been using the 20, so I'll experiment with the zoom too.
  • @Cosimo_bullo what lens are you using? my 14-140mm is preforming better than my 20mm
  • @astraban no you're right. thanks for looking out for other members. =)
  • Yeah and maybe you're right ivan! Just trying to clarify the situation for kae who wasn't here. I barely understand all thoses technical stuff (-->end user ;) )
  • Wow, you're having better luck with 132mbps than I with AQ4 on high detail. We're maxing out at 88.
  • @cosimo_bullo 4AQ, Transcend 10
  • @kae there isn't any special topic on the issue (yet) Vitaliy and chris just said that he was working to solve that "well documented" problem in the next rlz. Until then tweeking low gop appears like a funny but useless quest. Maybe better to stick w/ your last one or (heresia!) try long gop as requested by vk to find better improvement of the quality regardless the motion aspect (for the moment).
    Ps : just a noob who s trying to follow the news... To each his own :)
  • @ivan858 - What AQ are you using? What card?
  • @kae i had the bitrate drop off at 88mbs as well, so i jacked up the bitrate. 132mbs handles the death chart fine, i stopped it at 20 seconds. 154mb overloads the codec at 8 seconds.
    1276 x 647 - 322K
    1280 x 800 - 400K
  • @kae note, there are known issues with GOP stuff at the moment.
    Ahh, thanks. Can you point me to the discussion of that?
  • @ivan858
    "Can you give me your input on the IQ of the settings i'm using?"
    The stuff looks awfully nice but I can never judge motion when it's encoded by vimeo. Vimeo sucks big time with motion. Also, your shots are pretty static, so you're really not stressing the codec. A good test is: Try slapping on the 14-140 widen to 14, turn focus to infinity, OIS on, then safely mount the GH2 on your dash facing forward and drive down a heavily tree-lined street in traffic for 20 minutes so the clips have to span. This test is probably as brutal as the death chart but at least you can see real world images on playback and judge quality. If this test doesn't break your settings they will probably safely shoot anything.
  • @kae am i supposed to print it first? lol totally blew the codec
    Ok. Thanks so much. I was using @awaterman's 66mb settings for the streamparser grab I posted. Do you have any luck with your 66 or 88 24H 3 GOP and this chart???
    I find the chart to be the best test for stability in the end. Motion shots outside with detail will always vary but I don't think there's anything that will beat up the codec more than pappas's chart. 65mbs 3 gop with 3.61 and the chart was stable but there was that annoying 10 frame glitch which gratefully is gone with 3.62. I'm hoping for stable high data rate 3 gop with 3.62.
  • @ivan858
    lol. Actually my laptop lcd is only 1280x800 rez, so it would probably get really hammered at the native 1920x1080 rez of the chart.
  • @kae am i supposed to print it first? lol totally blew the codec. Can you give me your input on the IQ of the settings i'm using?
    1279 x 658 - 296K
  • @ivan858 & @awaterman
    Great work you guys are doing! Could you test your high bitrate 3 gop 24H settings with the attached death chart for 2-4 minutes and post the stream parser file? When I try with your 3 gop settings on the death chart the bit rate is hammered (attached) and I am trying to figure out what is wrong.
    Thanks!
    1278 x 665 - 157K
    1920 x 1224 - 2M
  • @coimo_bullo
    @towi
    I using a setting of 66mbps for 24H with the same settings as you except AQ3 & gop original. I have 720p at 44mbps AQ1 at 3x FBS & frame limit 3x only on 60fps & 50fps.
    I was over exposed by 3 stops then I stop down for a better exposure on a scene of green rosemary everything looked great in camera. Trans coded in FCP file& transfer. The shots I over exposed and brought back are micro blocking very badly not good. The ones where I exposed correctly no problem looks Great. 720 rocks. This only happened with 24H I'm hoping to keep my bit rate down. Have you tried over exposing with your 88Mbps. Oh I used 35mm Nikon FD. Did not try my 14-42 panny yet wanted to get to you first.
    Thanks
    Luke
  • @awaterman i think you have the best approach, not changing the buffer setting. I bumped the I frames from 8 to 9.2 but the video turns into mush..without the buffer patches checked it the I frames go up to 8.08 and looks great. I have the transcend class 10 also. I can film a detailed scene for 3 seconds and a simple scenes longer at 172mbs with it.
    1278 x 645 - 275K
  • @cosimo_bullo: Thank you very much!
  • @cosimo_bullo
    many thanks!
    So with regard to 24H we are using the exact same settings.
    How do you transcode the MTS files? I am asking because Avid won't import the MTS files directly and ClipWrap's export exhibits weird artefacts. 5DtoRGB and "Media Converter" transcode the files without issues.
    I am running Streamparser on Windows XP through Fusion VMWare on my Mac.
