@bkmcwd Hey mate! A friend and I founded a small young production company and - of course! - we are using the GH2 loaded with your Valkyrie C1.5b as well. While we are working on our first client projects, we uploaded some fun shots with the GH2 and FS700 as a little teaser for the upcoming showreel. The lowlight shots are all shot with GH2 and your settings ;) Thanks for all the hard work! Cheers!
https://www.facebook.com/WheresMyElephantFilmGmbh
EDIT: the macro shot of the bee was shot with the 14-140mm and macro extension tubes ;)
awesome.
@flaschus Thanks!
@bkmcwd Can't wait for Valkyrie Cinema Smooth to be released.
So coooool mate! Thank YOU for using my Valkyrie. :-)
Although I cannot open to the public yet because of a promise "I release after Nick releases", I will send it to you by PM. Please feed back the tried result. :-)
@bkmcwd i will be happy to test your cinema preset too!
@zsound Thanks! Since I am out now, I will send PM later. :-)
@bkmcwd Release yours, I'll finalise mine over the next few days.
Thanks Nick! OK, I will release today. :-)
@zsound I am still out now. Since I will release later, please try it then. Thanks! :-)
No problem @bkmcwd, there's no rush, you can send me it next week if you want. I couldn't use it this weekend cause it will be raining all the weekend on the french riviera... ( i like natural light)
NEW!
bkmcwd Valkyrie Cinema Smooth TYPE-ZERO1_BETA 'Apocalypse Now' with cbrandin 'Pure Original Cinema Smooth Matrix' - setd.ini - Released 10/11/2012
This is Valkyrie which adopted 'Pure Cinema Smooth matrix' of Chris.
About the concept of CS matrix, I think that it will be later explained from @cbrandin or @driftwood officially.
Warning! : in this "TYPE-ZERO1" setting, all the modes of AVCHD are experimental.
Please keep in mind that artifacts often appears in HBR, 1080i and 720p in spite of being very stable. Please try it! And I am very glad if I can get any feedbacks.
*If this is also still unstable, I will further adjust.
*Special thanks to @cbrandin and KING @driftwood!
Superb-looking Cinema Smooth matrix from cbrandin
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes(Experimental)
Upto 75M for Top Quality 720/50p modes(Experimental)
Upto 55M for Top Quality 720/60p modes(Experimental)
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
Please DL original raw data to look the REAL IQ. *This video is only sample for image quality.
Please download 2nd zip file! 1st one is wrong in the name of Matrix, although the contents of setting is correct.
                  Artifacts appear around the edges of objects that are in focus. I tested on multiple subjects and the outcome has been the same with these artifacts around the edges.
Many thanks for your feedback by PM! I will check it and am going to tweak the matrix later for "TYPE-ZERO2". :-)
Hello!
After loading your Cinema Smooth, I did not recieve any errors while shooting, I did, however recieve an interesting problem, not sure what causes this to happen; when windows explorer reads some of the 24h footage shot, the bitrate displays as "256kbps" the file plays back fine, but is this a sign of the patch? attached a screenshot from the bottom of windows explorer....
@flaschus Hi mate! Many thanks for your report. Since the improved version is released soon, please try. :-)
I have also experienced many same issues until now. Since I was experiencing also not only in my settings but in other persons' settings, I did not care at all. Is there any detailed person some?
@ GOLGOP3-13 lovers :-)
"GOLGOP3-13-A2_BETA" and "GOLGOP3-13-MAX2_BETA"
I release the new "GOLGOP3-13-A2" and "GOLGOP3-13-MAX2" settings.
All of these matrices are the same as V1s. The main changed parts are having realized Freeze-les and high-bitrate in HBR and 720p. Especially in 60p, the highest bit rate goes up to 65M from 55M, and is upgraded from 9GOP to 6GOP.
Please try them! And many thanks for your feedbacks!
Special thanks to @Mrhechang and @syoushow! :-)
NOTE:
*Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 110M in 24p, about 75M in HBR.)
*'MAX' versin and 'A' version are completely the same except 24p.
*The original matrix is adopted in the newest GOLGOP3-13s. It is the middle of a Sedna matrix and a stock character. If it says plainly, it will be the Sedna matrix optimized in 3GOP structure.
*24H and 24L are high quality 3GOP setting with mega size I-frames in GOLGOP3-13-A.
*24H and 24L are high quality 3GOP setting with super mega size I-frames in GOLGOP3-13-MAX.
*24p80%(30p) is available in 24H & 24L both.
*60i, 50i, HBR30p and HBR25p are also high quality and stable 3GOP settings.
*720/50p and 720/60p are 6GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
*In camera playback is available in all rec mode except 24p in GOLGOP3-13-MAX, at least available after reboot the camera.(Not tested full yet, but probably)
*EX Tele, iA mode work.(Not tested full yet, but probably)
*Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. In other rec mode, need test.
                  I am also working on improving Valkyries.
The improved versions of Valkyrie 444_TYPE-ZERO2 and CS_TYPE-ZERO1 are due to be released soon! :-)
??? Even if I check in windows explorer, audio is displayed as 256kbps. Although I have seen the file as which only an audio is displayed occasionally before, since there was no problem in contents, I do not care. Although I do not know to be a file with which setting, it has seen in the high-bitrate setting several times.
NEW!
bkmcwd Valkyrie Cinema Smooth TYPE-ZERO1_BETA2 'Apocalypse Now' with cbrandin 'Pure Original Cinema Smooth Matrix' - setd.ini - Released 14/11/2012
All of these matrices are the same as previous BETA vesion. The main changed parts are having realized Freeze-les and high-bitrate in HBR and 720p. Especially in 60p, the highest bit rate goes up to 65M from 55M, and is upgraded from 9GOP to 6GOP like GOLGOP3-13s.
Please keep in mind that artifacts may often appears in HBR, 1080i and 720p in spite of being very stable.
*24p is completely the same as a former setting.
Upto 65M for Top Quality 720/60p modes(Experimental)
                  @bkmcwd I will test and let you know how everything goes.
hey could it be that I noticed some drops in the framerate with Valkyrie 444? I'm using a 45MB/s card ... setting was HBR 25fps
@abraham1307 Many thanks always mate! :-)
@2many Thanks for your report! :-)
About the drops of the framerate, it was heard for the first time. Is it in what kind of situation concretely? Could you present the data itself or StreamParser results?
EDIT: Would you tell also about the exact edition of 444?
Since verification finished mostly, I am going to release Valkyrie 444 TYPE-ZERO2 C1.5e today. :-)
I was using hybrid C1.
It's odd though, now that I play the footage; where I thought I noticed a slight drop in frames, it appears to be normal again! I could have sworn that I saw something strange yesterday, as if a few frames got skipped..
I still do notice the kind of 'choppyness' in the movements of faces in screen. But I'm guessing this isn't settings related but camera sensor related and thus not fixable; footage looks great already anyway.
Thanks! :)
