Cheap and powerful studio light with softbox
  • Quite interesting and cheap light ($149 only)
    Features:
    ◦ LED quantity: 306
    ◦ Max output(Watt): 18 w LED (270 w incandescent equivalent)
    ◦ Beam angle: 60°
    ◦ Photo Luminance Factor: 220
    ◦ Color rendering index(Ra): ≥85
    ◦ Color temperature: 5600K
    ◦ LED longevity: >10000h
    ◦ Power input: AA Battery×10 & DC12V/2A
    ◦ Housing size (mm): 250×145×85
    ◦ Weight (g): 380
    Includes:
    (1) Lamphead
    (1) Reflector
    (1) 24" Softbox
    eBay: http://shop.ebay.com/i.html?_from=R40&_trksid=m570&_nkw=ProMaster++VL306+
    You can find it in many other locations, actually.
    For example, 2x kit can be abtained for around $400
  • 5 Replies sorted by
  • See the cables looping their way down the stands ??? With AA battery power, what are the cables to be used for ??? Maybe a quickie photoshopping job ??? :-)
  • >See the cables looping their way down the stands ??? With AA battery power, what are the cables to be used for ??? Maybe a quickie photoshopping job ??? :-)
    Can you list any reason of this comment rather than pure bad humour?
    AC is used as one of the powering options.
    Use rechargable set of NiMg batteries for rest.
  • Not seeing any reference to AC anywhere in this list. All I see is DC either battery or 12V.
  • > Not seeing any reference to AC anywhere in this list. All I see is DC either battery or 12V.
    Looking at provided link I see AC (120 volt AC). So, no problem with this
  • Thanks Vitaliy--that may keep the room a bit cooler!
