@vicharris no problem, I try to keep a good attitude on these types of forums
@Vitaliy_Kiselev Did you change the topic name? Funny :)
@peterosinski Thanks for the non condescending answer! :)
@goanna Wow, great job missing the point there. Nobody on a real set says "Give me a 50mm equiv" I'm so confused by all of your responses.
here's the deal. Cinematographers know what a lens looks like for any format, and if they don't they will figure out what will give them the FOV they want.
All this talk of crop factor now, and 35mm equiv listed in video camera specs is to help consumers and people that aren't as knowledgeable have a frame of reference when switching between formats.
( if you look at this link they don't even give you the focal length, they ONLY give you the 35mm equiv http://www.bhphotovideo.com/c/product/672423-REG/Sony_HXR_NX5U_HXR_NX5U_NXCAM_Professional_Camcorder.html)
Just wondering why I never hear it on sets then? I guess I'm just tired of hearing people ask what's the crop compared to the sea of 5D's everyone uses.
OK, would you like to suggest a new lens nomenclature to replace the old "50mm equiv?"
Like FI (fish eye wide) VVVW, (very very very wide) right up to XXXXXL?
I'll continue to go with the crowd and industry. When the Camera operator calls out to the assistant, "gimme a (50)!" it can be called anything you like but we've all got to use the same words.
Well I think its pretty standard because most of us on a budget aren't using cine lenses that cover 35mm film size sensor but instead still lenses that cover the full frame photographic 35mm. And so our crop is calculated based on the lens coverage area in relation to our sensor size is capturing out of that projected image circle. I agree with Vitaliy, its tradition ;)
Since long time ago.
35mm equivalent is very handy as it allows you instantly understand available angles of view.
@peterosinski Really? Was 35mm film the standard in movies as well?
@Vitaliy_Kiselev Tradition since when? The 5d? @goanna Yes I am. The motion picture industry is not built around FF cameras.
this is nothing new. I remember back when I was choosing between prosumer video cameras back in 2004 (gl2, dvc30, vx2100). All of the video cameras on BH Photo's website had the 35mm equivalent listed within the specifications of the lens. This is half a decade before the 5d or any HDslr came out.
Because it is tradition.
Let me get this right: are you objecting to, say, specifications being listed for a 16mm camera's lens which might say,
25mm (50mm equiv) lens included
I which case, are you saying you'd prefer them to say,
25mm (normal) lens included
or just
25mm lens included
And let us work out the FOV?
I'm with you, it's frustrating, especially when you try to explain to someone that your sensor isn't "cropped", it's just a different format. I've met extremely knowledgeable and accomplished cinematographers that deride cameras like the 7D and the GH2 due to their "crop", while heaping praise onto the beautiful "full frame" 5D.
I think a lot of the misleading vocabulary came from the legions of loud-mouthed photographers that fancied themselves cinematographers when the 5D mark II came out. They needed a way to explain why the lenses designed for their 35mm sensors (or film) looked different on cameras with smaller sensors, which is a legitimate concern. The fallacy was to assume that 35mm sensors were somehow the Platonic ideal form, and everything else had to be understood in relation to them.
I'm guilty of it too, though. I instinctually think of FOV in terms of focal length on a 35mm camera, and have to make the calculations in my head based on sensor size ratios.
