Can the MJPEG frame size @ 30 FPS be increased? Is 1920x1080 achievable? I'm looking at "MJPEG Size Adjustments" in PTool v.3.61d, and that's what it says. But does it just do upscaling, which should probably be left to editing, or are the individual frames shot by the camera actually that size? I'd appreciate any input you guys might have. Have been reading lots of discussions here with great interest. Thanks!
In most details, all three images look very similar, indicating that the GH2's optical resolution at 1080p isn't much higher than 720p to begin with. In addition, I spotted evidence of sensor sampling artifacts present in the upscaled 720p shot that are not present in the two 1080p shots.
In the lower middle section of the test chart, there's a row of diagonal line patterns labeled 1 3 5 7 9 10 8 6 4 2. In the upscaled MJPEG 720p shot there is a clearly visible vertical thickening of the diagonal lines in the middle of the pattern labeled "7". This is a sensor sampling artifact that can also be discerned in patterns 9, 10, 8, and 6.
If the MJPEG 1080p shot was in fact upscaled in-camera from a 720p frame, it should show the same type of sensor sampling artifacts as the 720p shot. In this case, the upscaled MJPEG 720p sampling artifacts in patterns 7, 9, 10, 8, and 6 are NOT present in the MJPEG 1080p shot.
Under detailed examination, the 1 3 5 7 9 10 8 6 4 2 diagonal line patterns in the MJPEG 1080p shot exhibit the identical sensor sampling artifacts as the AVCHD 1080p shot. This indicates that both MJPEG and AVCHD 1080p shots were most likely downsampled from the same high-resolution source (the 16-megapixel image sensor).
At low bitrates, the rectangular edges of the MJPEG macroblocks can become visible under magnification. At 90-100Mbps, the encoder appears to have enough bitrate to eliminate this problem.
@lpowell: the first thing i saw when testing the patch on gh2 (1920 mjpeg) is that its not nearly as sharp as avchd 24p. Maybe I can do a test shot, im sure you did see that too? were there no test charts done with this to compare?
@Vitaliy: So highest goal would be to combine gh2 sensor mode from 24p with mjpeg encoder, right?
@LPowell Encoder can be patched, same as in GH1. But it is video setup that not allows us to have smooth and good 24p. This think is fuckingly complicated with values moved to structures, then to other structures, then to other structures, then processed, then moved to other structures, etc. :-) Big fucking fun.
On the GH1, GF1, and G2, I was never able to find 1920x1080 settings for MJPEG that would record reliably in all circumstances. Narrower frame sizes, such as 1440x1080, produce distorted videos that appear stretched horizontally. Unfortunately, this is the opposite type of distortion than you want to use with anamorphic lenses. For that purpose, I found anamorphic 1.33X 1920x810 and 1.5x 1920x720 frame sizes to be ideal.
The 30p -> 24p MJPEG patch has never worked properly. It records at 30p and simply discards every fifth frame, producing choppy motion. As far as I can tell, 30p is hard-wired into the MJPEG encoder.
Michael Pappas (PappasArts) seems to have achieved 1440x1080 with his MJPEG 70mbits+ settings, which would be a bit bigger than 1536x864 albeit anamorphic. Don't you need special lenses for that sort of thing?
The 100Mbps Low Light MJPEG Patch works only on the GH2. For the GH1, the largest frame size I was able to produce was 1536x864. You can find that patch here:
While numerous posters have speculated that patched MJPEG frame sizes are actually upscaled from a 1280x720 frame, I have yet to see any tangible proof of this claim. My recommendation is to try it yourself and see what you think.
