Still using 1.1 and still having the wrong lens in the wrong place.
This was apparently a shooting just before I got there and I had my Samyang 7.5 on and I didn't have a camera light with me. (We had just gone to the movies)
Part of this was ISO 1600 and went up from there. Standard -2
@Tobsen OK, I got it. But they are very helpful. Thanks! :-)
@bkmcwd I hope it will help you. But this time, it is totally different kind of footage - more ENG style.
In 720p of NTSC, I think that 45M is common. If stability is ignored, it can set to the higher bit rate, but I do not regard it as good.
@bkmcwd first files are up. Forgot to mention what I used: 14-140mm, wide shot with Oly 12mm smooth -2-2-2-2 Sandisk Extreme Pro 95mbs Iso 160 - 400
Caution with skintones. Lighting was horrible there - typical tech-fair where every stand has different lighting.
@bkmwcd. I use NTSC
@bkmcwd I'm impressed with 1.1. I covered a planning commission meeting tonight. It was a very tense meeting and the press areas were used for seating. I locked the AC160 down and scooted around on my hands and knees with the gh2. I hadn't planned on using it tonight and had the 14-140 on it. That was the wrong lens, The lighting was horrible and the lens wanted to hunt. WB changed with the part of the room I was in...so on. 1.1 in 1080-24 did a fine job especially considering the circumstances. If this does half as well in 720, you hit the jackpot.
ISO is 1600 Thanks!
"In that for 24p its the same matrix as ZERO-1 ?"
Yes, it is same as TYPE-ZERO1 in 24p. :-)
The modified matrices are used in 1080i and 720p. However, there are 2 different matrics.
@bkmcwd. I did a quick test of the C1.1 using Panasonic 14-140 and Sandisk 64GB 95mbs. 24p and HBR worked fine and very good quality. FSH locked in zooming to 140mm. SH looks good but lower bitrates 45MB.
@bkmcwd reporting back from the front. C1.1 is more stable in HBR, didn't shoot 720p50 today. Only once in the beginning, the cam locked due to "exceeded buffer...so on" .
Really exhausted now. will send you some files for analysis tomorrow.
@bkmcwd Sorry, I'm confused. Is this new type ZERO-2 candidate 1.1 a modified matrix from the original Cbrandin AN only with regards to HBR/1080i and 720p, In that for 24p its the same matrix as ZERO-1 ?
Probably I think that C4.2 has too strong the Deblocking effect. Therefore, I am going to improve C5 to the next of this C1.1. :-)
NEW!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setc.ini - Released 20/09/2012
"TYPE-ZERO1" released previously was not good in other than 24p. And, previous TYPE-ZERO2 "Candidates1-5" are sometimes not good in IQ or stability. Therefore, I further improved C1 and made Candidate1.1. setting. Probably in this C1.1, the finest noise in candidates of TYPE-ZERO2 will be reproduced.
I reduced artifacts in HBR and 720p, following the pure original matrix of Chris as much as possible.
Please try this. And I am very glad if feedback can be got.
Special thanks to @har_k and @syoushow! :-)
Of course, thanks to @cbrandin and KING @driftwood!
Superb-looking simulated 444 matrix from cbrandin
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes.
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes
Upto 75M for Top Quality 720/50p modes
Upto 55M for Top Quality 720/60p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
Sorry! At all, since the contents of the setting were the SAME, they were SATISFACTORY, but what does not have an excessive description in a comment field was reuploaded.
Please download the 2nd zip file! :-)
                  @bkmcwd I saw it :) thanks a lot!
@Tobsen I sent PM to you. Please check. Good night :-)
I need it within the next 12 hours (but then, I won't be able to really test it, but take it straight to a paid job). It only makes sense though, if it is much more stable. If it will be a very experimental candidate, I will stick to soemthing safer. Don't worry, take your time. I can also test it at a different point.
Not my boss, but Panny's boss. LOL
I do not think that I can get before official release. Because, Panny is prudent especially in Japan, I think.
Of course, my boss is my wife as you know.
@bkmcwd I asked a friend who will stop by Japan on the way to US. He would buy Gh3 for me. By the end of September, will GH3 be available in Japan yet? I wondered if your boss is your wife as my friend call his.
@Tobsen Nice timing! :-)
We Japan team was just going to test by narrowing down the next candidate now. Since our town is midnight now, the last check is a schedule for tomorrow/Thursday. Within how many hours do you need it in the back?
@bkmwcd I just got a call that I might have to go shoot some impressions of a wind energy fair tomorrow/Friday. Any chance you got another more stable version ready to be tested?
@tinbeo I do not think so. Although it is natural, since their boss does not like Hack. ;-)
bkmcwd is also busy to find out all real facts of gh3 like hdmi uncompressed peaking.... Isn't he among the first people in Japan be able to get the GH3 before us :;)
@bkmcwd sounds great. Take your time, I am excited :)
