Official Low GOP topic
  • 1003 Replies sorted by
  • @stonebat I like your rig. What is it? Where did you get it? and How much was it?
  • 720p30 gop3. It didn't crash, but the bitrate looks funny. Rapid bitrate drop after first 30 frames.
    1284 x 682 - 136K
  • @kae
    Just applied your July 27 "65M extreme 1080 24 3 GOP settings WITH stable settings for the other modes"
    No problems shooting and playing back in camera using Transcend Class 10 SDHC card. Clips play perfectly off the card on my Panasonic DMP-BD35 Blu-Ray player's SD card slot too.
    Nice! I'll stick with these settings for now even though I don't use anything but 24p
  • I used GH17 w/ 100Mbps max latitude patch. It didn't last 5 secs.
    Then I used @kae's 1020p24gop3 on GH2. Rock solid.
    720p60gop6 on GH2 didn't crash either, but its i-frame bit size dropped from 390K to 290K after the first second.
    640 x 478 - 156K
    1284 x 682 - 219K
    1284 x 682 - 212K
  • @kae: just thought id add my 2 cents... when i use the preset you posted- i shot my monitor up close, causing very nice rainbows and pixel detail- this is the streamparser result, the image is awful...
    Have A PAL GH2 purchased from britain...
    1177 x 178 - 9K
  • @Aleksandr_Oleynik
    Original looks great. Thanks for the link!
  • @Aleksandr_Oleynik Thank you for making that available. Data on it is
    bit allocation max : 32 271 178
    avg : 30 666 510
    min : 15 024 923
    Looks fab - great to have the .mts to play with! The image can take a lot of colour / levels processing and still looks good.
  • @proaudio4
    'where do you see the strobing'
    I don't see strobing. I do see a pulsing sometimes if the auto-focus is on and it hunts and I do see aliasing which to my understanding is inherent in the camera regardless of setting. I would guess the higher the data rate, the higher the detail so you notice it more but that's a question for Vitaliy, Chris or lpowell.
  • @chauncy
    I'm so glad you made this test and posted, to me it's not off topic at all. Low GOP AVCHD always stresses the card more than other modes so there's no way to reliably test Vitaliy's patches if the cards can't keep up. I ran into this months ago with the GH1. A lot of folks were nervous about shooting a 3 or 6 GOP with 1080 24P N on the GH1, but I found it was very reliable with the "right" card. It's the same with these higher data rate Low GOP modes on the GH2. I'm convinced the Transcend cannot handle it. Your tests show that others can't either. In 65mb/s mode the data is reaching burst speeds of 97Mb/s so a card with a known write speed above that is a must. My Dane-Elect 32GB Proline 200N have always been reliable and fairly cheap.
  • Where is pappasart death testchart? TIA
  • @jfro
    'This stuff keeps getting more bazaar. I'm starting to wonder if there is something in the settings that caused the write errors.'
    Definitely, this has been the case. This has been my frustration with a lot of people on the board who are mixing the settings I test with their own settings and then coming back with the 'unstable' yell (not you). The mix of the 1080 24p settings combined with the 720P/1080i settings is very tricky. Screw one setting up and I have found they will throw the other modes off. The last settings I posted above are working stable for me in all modes. I had to go to a GOP12 for the other modes to do that. GOP6 for 720P (which I like better) was giving me problems. It's the nature of the beast while Vitaliy works all these things out. We're all shooting with this crazy mix of settings, subject matter and SD cards trying to make sense of it all. We'll get there :-)
  • @randolfo
    Aleksandr_Oleynik made this great color correction test video, not me. He posted that he used the 65Mb/s, I don't know whether they were the combo ones or just the 65mb/s 1080 24p by themselves. You could go over to vimeo and ask him.
    "You can put your attached the extreme stable? Thanks?"
    The extreme settings I've found that are stable are posted right above your question where Aleksandr's video is linked.
  • just thought I'd point out there is a massive difference between class 10 sdhc cards. Especially when it comes to write speeds, anything between 8mb/sec and 18mb/sec or even higher. Class 10 just means they are supposed to write at speeds around 10mbs, little lower or a lot higher.
    Normally, I would have said this is a non-issue that any good card is fast enough, but these bitrates and settings combined with however Panasonic is writing, efficently or not, to the card may be pushing it for some.
    I have four types of cards(all class 10) at the moment, here are the read and write tests I did with them through atto benchmark program.(read/write)
    Panasonic Adata Patriot LX P NY
    17.4/11/5 17.4/8.5 13.6/9.5 18/17
    I would also say that there are considerable differences between batch runs of card. It's not nearly as precise as people seem to believe. Even sandisk(who way too many people bleat that you should only use) has good and not so good runs. Just like any mass production.
    Before Mr. V. Closes this post as wrong place. For these GOP tests, try other cards. Even sandisk is cheaper these days, get 16mb cards to keep costs lower. PNY $25, sandisk $43 on new egg.
    If you're concerned about reliablilty, shoot with the card first to test it before any vital shoot. If the card is going to fail prematurely, the huge majority fail right away.
    off load to a laptop at first chance.
    Let's not get into a huge this card/that card thing. But these issues could well be the cards.
  • @ kae
    This stuff keeps getting more bazaar. I'm starting to wonder if there is something in the settings that caused the write errors. On occasion I've thought there were some left over settings from a previous version of the firmware, but many of the times I've found it was operator error (mine).
    Previously, your 24p only setting worked for me around 60mbs. No real issues on shooting on waterfront I got some great footage and high data rates 1 week ago today.
    Since that time when I try to add the 60p, 1080i, mess with GOP settings and higher avchd settings, I have stability problems over 58 mbs. And during my testing I've reset my camera 2=3 times during the last 6 days.
    Early this am, I tried you settings from today/last night, reset my camera, went through just about every menu settings to check and tweak, and low and behold, no write errors so far and I'm getting your insanely high data rates.
    We are going out and will be in the car so I'm going to throw a couple cards in my pocket and let the camera loose with your settings again.
    I've only done about 8 clips and on 60p and 24p, but so far so good. Keeping me fingers crossed.
  • @ kae
    Where are you seeing the stobing? I've seen it myself, but at that time I was sure it was due to fluorescent lighting and my chosen shutter speed.
  • @ kae
    I am also clueless.
    So much testing, hard to remember everything. But....
    I have a USA Camera. I live in upstate NY.
    My settings are similar to yours, but capped at 58mbs and gop 6 on the 60p which I'm liking.
    It's possible that the 4 class 10 cards I have can't handle 65 mbs, but the transcend class 10 cards have kept up with everything else.
    I'm heading out on a family outing to the lake, but am taking my laptop and camera and will probably get some time to fool around today. I'm going to try and gradually up my setting on the top end. I'll also try your settings and work them down from 65000000. Maybe I'll learn something.
    Later in the week, I'll grab another brand of card.
    One thing that's possible is the size of the clusters on the 32gb cards maybe more efficient in writing than the cluster size on the 16gb cards.
    I will report back my findings later today or tomorrow.
    I agree with you on the quality of the GH2 footage from driving. It's outstanding, even at my 48000000 mbs.
    My only concern with the camera & I'm spending some testing it is a little strobing effect under certain conditions. It maybe a monitor issue, but others are seeing the same thing and I haven't isolated it yet. Until figured out, it's a little concerning. But that's another story, just taking time to chase it down.
  • @Kae
  • @Kae
    The settings are just above the extreme with which you made ​​this video?
  • @jfro
    re: 65Mb/s Extreme Settings stable as far as I'm concerned --
    I haven't shot with your settings above but I was intrigued with your 'drive' test so I did one of my own today using my 65Mb/s extreme 1080 24P 3 GOP settings and I haven't a clue why you get write errors, it completely baffles me! I drove 15 minutes at high speed shooting into a canyon with plenty of trees, my 14-140 was in auto focus mode + OIS + it was 2500iso just to give the codec a lot of noise to deal with. I laid down an average bitrate of 58Mb/s (and these settings will only give you 64 Mb/s on the death chart) without a write error and the file SPANNED after the first 4 gigs were written. I had NO trouble playing back this file in the camera or desktop.
    I am clueless why you, Butt and others have errors in this mode, and I am not saying you aren't, I just don't know how to help at this point. I'm using a Dane-elect 32GB class 10 card, freshly formatted.
    I'm a bit reluctant to keep testing others 1080 24p settings at this point as the 65Mb/s have been bulletproof for me, especially with the death chart and I have yet to find real world situations that stress the codec as much. There's one thing I can't test --
    Could it be possible a NATIVE PAL camera does not handle the bitrates as well as a NATIVE NTSC camera? Is there any hardware difference between the NTSC/PAL cams at all? Vitaliy???
    UPDATE: Just did a 30 minute drive test with the 65mb/s settings in heavy traffic, 14-140 set to wide, blue sky, lots of trees on each side of freeway, camera angled a bit down to record every groove, divet and pothole, OIS on, Dynamic mode with every setting at 0, 320iso, ND6, F 6.3, auto shutter, GH2 was hot in direct sunlight mounted on the dash of a SMART on the I5, the bumpiest freeway in California and the file spanned perfectly, never glitched. Playbacked perfect in USB slot of Sony Blu-ray BDP-BX57 to HDTV and on desktop and in-cam. Indistinguishable from film for me at these settings, could shoot driving plates for process with these settings for a feature in a heartbeat.
    I'm convinced now if you are getting write errors with this 1080 24p setting it's your card. Posting combo settings again below.
    If you want a set of less extreme settings to work within the same patch just change:
    'Video Bitrate 24L=' to anything under 54m (i.e. 54, 52, 50, 45, 42, etc) and just switch to 24L when you want that lower rate -- have the best of both worlds.
    Aleksandr_Oleynik did a great job with a color correction test of these 65mb/s settings here. Really worth watch his video:
    EDIT: There's an issue with the 24L settings in this patch. It will look ok but it records funny as Streamparser will show. I never use 24L only 24H which is the 65Mb/s mode, but if you need 24L you may need to adjust the patch.
    1273 x 667 - 166K
    KAE65M1080_24P_3GOPand42M720_1080i_12GOP.zip
    511B
  • @v10tdi
    > My Viera HDTV also had problems with playback of higher bit rate AVCHD material.
    Thanks, good to have one less thing to check on.
    My TH-L42U20A is only 6 months old and has the current firmware.
  • If it helps, Panasonic did release firmware update for of the Viera HDTV's. I am sure I have it somewhere. PM me if you want it.
    FWIW - My Viera HDTV also had problems with playback of higher bit rate AVCHD material.
  • @kae
    I tried on 2 of my 4 computers here, the mts files do play back a little better than on the Viera TV.
    I would expect faster computers to get better results. However, the camera's smooth playback intrigues me,
    My Viera TV (42" TH-L42U20A) is a B.T. (Big Thing) for me; I bought it along with the GH2 for quick replay and it has sped up my shot analyses. I don't know if any of these Vieras have special processing (eg Venus Engine) but I would love to see the Panasonic TVs hacked along with the cameras!). Maybe that deserves its own topic.
  • @Roberto
    Will the clips play back on a computer? A lot of times the sd readers on tvs are meant for photos and the data rate isn't there for video.
  • @kae
    KAE 24P Extreme results:
    playback fine in-camera
    will not play back on Panasonic Viera with SD card inserted into TV: serious jitters.
