1x the gh2 freezes in 720 mode, and i dont no why? .
all other times there was no problem................
300% record did not give any probs in H mode.
but higher then iso 1600 is a no go, that will say, for so far in what i tested.
there is a lot of noise/grain then..........
i did try to shoot 720p, hbr and 24p in exact the same shot....
lens was set 22mm to 55mm for the different shots..
I will edit the video, and see what happens then...
btw, all is done in the highest settings..
how is that posible, al pictures are placed random ????????????
and i mis 2 images??
Which card did you use? And is 720p modified from my setting by yourself?
@bkmcwd Camera is often freeze at SanDisk SDHC 32GB class 10 32mb/s . SDXC is no problem excellent!
Thanks for your report! :-)
Yes, also in my test, it often freezes with cards other than 95MB/s SDXC. It is normal for this setting.
However, since it may somewhat be too aggressive, I readjust slightly in 50p.
I did not change any off your setting.
it looks like the changes you did in goptable setting x2 did the trick.. ;-)
card used is a Sandisk Extreme Pro 32gb 95 mb/s.
Datarate.
720 +/- 65mb to 75mb (SH)
hbr +/- 45 to 65mb (H)
24p +/- 70 to 118mb  (H)
300% 75 to 90mb  (H)
@bkmcwd shot 36gb today with the TYPE-ZERO2 candidate2 setting. froze twice in HBR 25p, but that wasn't a big deal. ExTele worked without problems. I only looked at a couple of shots quickly and they look really good. Tomorrow we gonna import them into PP CS6 and have a closer look.
Maybe I'll try candidate3 tomorrow...
Many thanks for feedback! :-) About 50p, I will tweak a few. Just a moment...:-)
"TYPE-ZERO2 candidate2 setting"
Since it is a matrix slightly more aggressive than others in HBR of Candidate2, the matrix of Candidate1 has been inherited in Candidate3. I think that Candidate3 is better than C2 also in HBR.
Please feedback tomorrow! :-)
i forgot to say, tele2 works also....
i am render a clip now, 3:30min, it makes things perhaps more clear.
you did already change really a lot between Candidate 2 and Candidate 3 ...
"you did already change really a lot between Candidate 2 and Candidate 3"
Yes, however, it seems that the former GOP tables are better. :-(
I am changing back them now.
@bkmcwd cool, will try your next candidate then once you upload it (hopefully soon).
It has almost completed. I am just going to verify in both PAL and NTSC now. :-)
no grading or correction.
720, hbr and 24p on the same timeline, and renderd to 1080p 23.97fps
UPDATE(12/09/2012) Since mistake input was in the setting of Candidate4, what was corrected is set to "Candidate4.1".
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate4.1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setd.ini - Released 12/09/2012
"TYPE-ZERO1" released previously was not good in other than 24p. And, TYPE-ZERO2 "Candidate3" is too agressive in 720p mode. Therefore, I made experimental 4th candidate setting **for HBR mode and 720p.
*In 720p, Candidate4.1 is safer than C3.
I reduced artifacts in HBR and 720p, following the pure original matrix of Chris as much as possible.
Please try this. And I am very glad if feedback can be got.
Special thanks to @har_k and @syoushow! :-)
Of course, thanks to @cbrandin and KING @driftwood!
Superb-looking simulated 444 matrix from cbrandin
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i modes.
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes
Upto 70M for Top Quality 720/50p modes
Upto 55M for Top Quality 720/60p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
*Please DL 2nd ini file! 1st one is not good.
                  @mozes Many thanks for feedbacks from you and beautiful sample footage! :-)
@Shishboombah Thanks for testing Valkyrie! How did you feel? :-)
@bkmcwd I think its very good !,looks great..gonna try the new patch you just posted.
@Shishboombah Thanks! Please tell me comment again. :-)
@bkmcwd We like reliable high quality setting of Japan. I expect the team of you and Japan thanks always!!
While I know there are newer versions, here's a little vid of the GOP3ZILLA Beta 3 shot with a macro lens and combination of shot at 24p and slo-mo 60p, with most shots in ex-tele mode, which works fine in iso160 and a bit noisy as 320. Only light grading done.
Welcome!
In this forum, a year ago, although the camera was made in Japan, I was almost the only Japanese. As for me, it is glad that the Japanese who can arrange a setting other than me have increased in number recently... Many thanks. :-)
Thanks for very good footage with GOP3ZILLA! The countenance like Philosopher of a lizard and the beauty in nature are wonderful. :-)
Now, I am tweaking in order to improve TYPE-ZERO2_C4 slightly. Probably I am going to release C5 during this evening. :-)
NEW!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate5 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setb.ini - Released 12/09/2012
"TYPE-ZERO1" released previously was not good in other than 24p. And, TYPE-ZERO2 "Candidate3" is too agressive in 720p mode. Therefore, I made experimental 4th candidate setting **for HBR mode and 720p. Furthermore, I release "Candidate5" which changed in the Deblocking tables of C4 slightly and was retuned up.
*In 720p, Candidate5 is safer and better quality than C4.
                  @bkmcwd Does C5 only improve 720p?
