'Apocalypse Now' Experimental Series 1 Thread - BOOM, Intravenus - cbrandin/driftwood AN Soft/Cinema
  • 1089 Replies sorted by
  • @johnnym @botha Thank you guys! I always try to do more than my best :)
  • @ValentinDeluy: nice one ...he he ;-)
  • yeah well done. Those guys seem to really mean it.
  • Done with Cluster v6 'DREWnet' 12-15GOP
  • @Lambo Many thanks for more feedbacks! :-)
  • @blaisejadoul 24p spans as well with DREWnet 444 sharp.
  • I forgot to say that I shoot 25fps in HBR, but I tried also 1080i FSH... Both stop at 4.29GB. I didn't try 24p !
  • @bkmcwd many thanks for the great patch, I do more tests.
  • @Driftwood and @blaisejadoul with Nebular 444 sharp I found that it is more likely to span in 24p, while HBR usually doesn't (3 tests, once it spanned over two files and stopped then). My recent 24p test ran for about 31min and created three files that worked perfectly in Premiere CS6. DREWnet doesn't span in HBR (based on 2 tests). 24p spanning test is running now...
    EDIT: 24p spans as well in DREWnet 444 sharp.
    @Driftwood the Apocalypse Now settings look really nice! Would be great to be able to use them on interviews as well. Have a good trip!
  • @Lambo Thanks for feedback! :-) Since it is meaningless if it may be unable to use, I am giving top priority to stability.
  • @bkmcwd very awesome, I'm using at the moment the 16gb 45mb/s and is very stable.
  • Hi @driftwood ! First of all, thanks a lot for your awesome work regarding the hacked GH2 ! I have the same concern as @Tobsen. I shoot interviews and many of them last for a veeeery long time. Is there any chance that your powerful hacks span with a Sandisk Extreme Pro SDXC 64GB 95MB/s ? I tried both Apocalypse Now Nebular and Drewnet soft, without success. The GH2 just stops recording which it reaches the limit of 4.29GB... Enjoy your trip in France !
  • @mrbill Thanks for your indication. :-) I corrected instantly. Do you understand now?
    1st : Valkyrie 444 TYPE-ZERO
    2nd : Wrong zip
    3rd : Valkyrie 444 Soft Matrix
  • @bkmcwd - your post at the top of the thread is a bit confusing - is the correct version of your patch the one in the middle, or the one on the right?
  • Hi @shon im at airport getting a flight. Answers when i touchdown and get lappie out
  • @driftwood You have not answered my question. I delete a video from youtube?
  • @lpowell Welcome to the thread. The original matrix is the Soft variation.
  • @driftwood I'm not seeing cubing on my computer...? I'm doing a digital zoom program "sony vegas" that you can see these artifacts. I have good vision, I would not have seen all the cubes in the fifteenth frame. I do not know how to prove to you that this is not just my imagination,flash memory in this also is not to blame, the bitrate at drewnet v6 and v7 in the same place, but different results.
    It will be better than youtube http://www.onlinedisk.ru/file/936971/
    Thanks a lot! Check the new version (sharp2) these artifacts disappeared :) I remove videos from youtube?
  • @exilenorth just testing the new settings. Driftwood said it may span or not, so I tested. Got an interview to shoot on Tuesday and wanted to use the GH2 so I care about spanning.
    Maybe the "Drewnet 444" Version spans. IF not, back to older hacks.
  • Sedna sedna sedna sedna
    Any love for this good `ol patch :) Will the 444 apply to this as well?
  • @driftwood
    I released the 444 soft matrix version of Valkyrie now. I am also waiting excitedly about the release of your IntraVenus. :-)
    @all
    http://www.personal-view.com/talks/discussion/comment/81033#Comment_81033
    The 2nd is not the right setting although I have uploaded two "Valkyrie 'Apocalypse Now' with cbrandin '444 Soft Matrix'" accidentally.
    Please download the 3rd right zip file.
    2nd : Wrong zip
    @Lambo
    Many thanks for testing 444 TYPE-ZERO! :-)
  • @lpowell you are right. i was looking at the sharp file. soft file has quantizer set at 15.
