What is Intra Venus??? Apocalypse???
Apocalypse Now 444 IV: Game-changer? I expect so.
Q. What is the Matrix?
Those must be red pills and blue pills battling it out in the thumbnail!
can't wait. Anything that can simulate 444 on h264 will be most welcomed
NEW!!!
"TYPE-ZERO1" released previously was not good in other than 24p. And, previous TYPE-ZERO2 "Candidates1-5" are sometimes not good in IQ or stability. Therefore, I further improved C1 and made Candidate1.3. setting. Probably in this C1.3, the finest noise in candidates of TYPE-ZERO2 will be reproduced.
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.3 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Seta.ini - Released 25/09/2012
Latest Valkyrie is this. Please try this TYPE-ZERO2 Candidate1.3 first! :-)
http://personal-view.com/talks/discussion/comment/88237#Comment_88237
While improving, I am going to develop this in my thread so that it may not become the obstacle of Nick. :-)
bkmcwd Valkyrie 444 TYPE-ZERO1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' - Setc.ini - Released 06/09/2012
*I am sorry to make it get confused, because I was mistaken in the matrix. :-(
Since "TYPE-ZERO" released previously was not with an original matrix of Chris strictly, I remade another setting as "TYPE-ZERO1" with the pure original matrix of Chris anew.
Warning! : in this "TYPE-ZERO1" setting, all the modes of AVCHD other than 24p are experimental.
Please keep in mind that artifacts often appears in HBR, 1080i and 720p in spite of being very stable.
!!! The improved version is "TYPE-ZERO2" at upper link place. !!!
Superb-looking simulated 444 matrix from cbrandin
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for HBR/FSH & 720/50p modes (Experimental)
Upto 55M for 720/60p modes (Experimental)
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
bkmcwd Valkyrie 444 TYPE-ZERO 'Apocalypse Now' with cbrandin/driftwood 'Original 444 Matrix' - Setc.ini - Released 30/08/2012
bkmcwd Valkyrie 'Apocalypse Now' with cbrandin '444 Soft Matrix' - Setd.ini - Released 01/09/2012
Superb-looking simulated 444 matrix from cbrandin & driftwood
Upto 110M for Top Quality 1080p24 at Q16
Upto 75M for Top quality HBR/FSH & 720/50p modes
Upto 55M for Top quality 720/60p modes
Extremely reliable top performance in AVCHD 24H, HBR, FSH, FH, SH, H and MJPEG modes
Fully working iA and iDynamic modes if you require them at top settings
6 GOP in 720/50p and 9GOP in 720/60p also bringing short GOP style detail & movement-rendition
I am sorry! The 2nd is not the right setting although I have uploaded two "Valkyrie 'Apocalypse Now' with cbrandin '444 Soft Matrix'" accidentally. Please download the right zip files.
1st : Valkyrie 444 TYPE-ZERO
2nd : Wrong zip
3rd : Valkyrie 444 Soft Matrix
4th : Valkyrie 444 TYPE-ZERO1
                  reserved for up and coming footage and stuff...
Driftwood Tips of the Week
If by chance you can't seem to playback your Cluster files in-camera, switch off, switch back on, press the play button and everything should be back.
'My Apocalypse Now recordings won't playback in-camera?' For some hi-bitrate recordings what do you expect?! The decoder inside the GH2 is rather limited; inadequate memory, buffers, etc... and playing back these settings where recordings are hitting the settings' peaks will cause playback issues if it runs out of steam. Sometimes its a case of doing what is mentioned in the top tip. But better to bring along a decent specced laptop on set and copy over the sdcard's private folder over to the hard disk and watch the mts files playback thru a decent piece of software like 'Movist' on the Mac or WMP with 'k-lite codec' pack installed on the PC. The most important thing to remember is that there should be nothing wrong with your recordings.
Don't forget to record a small recording after a long recording on a 64Gb 95mb/s extreme pro card as sometimes its file name handling gets confused. Doing so will enable you to continue using the card for further recordings.
Q. What makes a matrix? Coming...
Q. How we constructed the Apocalypse Now Matrices for the GH2
Answers up soon!
Cluster v7 'Apocalypse Now' 12/15 GOP (DREWnet) with cbrandin '444 Soft Matrix' setf.ini - Released 28/08/2012
Includes;-
Superb looking simulated 444 soft matrix from cbrandin for sharp lenses
Upto 80+M for Top Quality 1080p24 at Q15
Upto 40/56M for quality HBR/FSH & 720p modes at Q15
Extremely reliable top performance in AVCHD 24H, HBR, FSH, SH, and MJPEG modes
iA and iDynamic modes should work at top settings
Conservative yet powerful 12/15 classic Long GOP structure for most good SD cards
smooth de-macroblocking - ie Flowing water looks superb and Night stuff looks great
In-camera playback
Spanniing should work
Tested by upto 20 'AN' beta testers
Cluster v7 'Apocalypse Now' 12/15 GOP (DREWnet) with cbrandin/driftwood '444 Sharp2 Matrix' setc.ini - Released 28/08/2012
As above setting except employing a sharpened 444 matrix as adjusted by Driftwood targetted for soft/manual lenses.
                  Cluster v7 'Apocalypse Now' - 6 GOP Nebula with cbrandin/driftwood '444 Sharp2' matrix- Seti.ini - Released 28/08/2012
A balanced matrix aimed at both manual and sharp Pany lenses (ie a combination of 'cbrandin 444 Soft' Matrix meets Driftwood's Sharper-tuned matrix).
Superb-looking simulated 444 sharper matrix from cbrandin & driftwood
Upto 90M for Top Quality 1080p24 at Q16
Upto 50/60M for Top quality HBR/FSH & 720p modes
Beautiful 6 GOP bringing short GOP style detail & movement-rendition with the benefits of lower bandwidth-consuming Long GOP (ie it sits in the middle!)
smooth de-macroblocking - ie Flowing water looks magnificent., Night stuff looks great.
In-camera playback
Tested by upto 20 'AN' beta testers.
Spanning - As ever, sometimes it will/sometimes it won't.
Driftwood Cluster v7 'Apocalypse Now' - 6 GOP Nebula '444 Soft' matrix - Setd.ini - Released 28/08/2012
Setting details are as above except this is the original soft 'cbrandin 444 Soft' Matrix version targetted at Pany lenses.
                  1. Apocalypse Now 'Intravenus' v1 Settings
Another experimental setting. Intra on GH2 for those who require 24/25/30 keyframes per second. The GH2 is just about strong enough for decent Intra quality mid to closeup style shots using matrices based on Chris Brandin's matrices - the 24p is the 444 soft matrix as seen in Custer v7s. The HBR/1080i matrix is an adapted variation of my own, the 720p mode is a slighty stronger weighted version of Cluster v7s 6 GOP 720 using cb's matrix 444 soft. Some of the work ideas gone into Intravenus will appear in Cluster v8 flavours coming soon whereby using a mid to longer GOP users will achieve better Q.
With 1080i/HBR REC modes, Intra's consummation of max memory limits Intra prediction of the lower field together with its insistence of using part 16x16 macroblocks for horizontal lines under hi frequencies in the lower field (most of it is P mode encoded) - its very difficult to get under control and once again I confer that matrix design is a black art. The matrix has to be compensated for this to stop mosquito / contour artefacts. The first version of Intravenus looks at this compensation but drives the bitrate upto around 117M in certain scenes. Subsequently, analysis of the hi frequency range has led to better looking Intra 25p/30p than in past Intra settings - but it's still not exceptional - indeed I am yet to see ANY setting that blows me away for HBR modes. The GH3 with its 8x8 macrobocks alongside 4x4s will improve the problem considerably.
2. Apocalypse Now 'Boom!' - Intra GOP1 24p Flat 4 matrix experiment. Works very well for Mid Shots/Close Ups. Out now for trial 24p REC Mode - this setting has NOT been setup for HBR/FSH or 720p despite what patch adjustments you find inside.
FYI This is a completely different matrix than Chris Brandins. Instead, lets see how far we can push the GH2 and its matrix sharpening. Lets reverse the 'Soft machine' and take a look at how a Flat 4 (All 4s in the matrix) records on a GH2. This has been tested at close-up skintones and mid to tight shots and is very very sharp on a typical soft lens like a Nokton 25mm f0.95. I would probably not recommend this for wider shots or for pany lenses. More notes when I get home from vacation.
