Hi all,
Can you tell me your sony vegas rendering settings for vimeo I don't get to get my footage come out nice. It drives me crazy!
This is what I do: sony vegas pro 10 and render as sony AVC picture Video format: AVC profile: high 1920x1080 Entropy coding: CABAC Framerate: 23,976 Field order: None (Progressive) Pixel aspect ratio: 1.000 Bit rate(bsp) 20.000.000
Hope you can help me out!
And what's about the target bitrate? Vimeo states 5M for 720p and 10M for 1080p
Do you use these settings or you use a higher bitrate?
clear
Thank you eyesoul! that was very helpfull! Everybody agreed with these settings?
@rockhunter it's best to just render out as 720p & upload as 720p for vimeo.
On the MainConsept grab where it says maximum (bps) & average (bps) you will notice it's 24,000,000 maximum & 16,000,000 average,this is for my 1080p renders..For my 720p renders I usually go 16,000,000 max & 8,000,000 average.everything else remains the same.
ok I just tackled this issue today. At first I thought Sony AVC was the best option until I tested it again against MainConsept AVC/AAC. It seems my renders came out better with MainConept,but I could have swore that I had better results with Sony AVC previously.When in doubt I go between the two settings.
Here are screen grabs of both my settings.
I too wonder about the settings for Vimeo to get the best final result on Vimeo. No matter what I upload, Vimeo converts it to 1280 x 720. Later, I can go into the settings and tell Vimeo to convert my video to 1080. So I wonder if it makes any sense to upload 1920 x 1080. Wouldn't it be better to record 720, render 720 and to upload 1280 x 720?
