@Hunter5117 another thank you!
Damn, I just bought their original follow focus a month ago. Anyone wanna swap?
another thank you! please keep us updated if there are larger gears available or not.
Thank you for the review!
I just received my Fotga DP500 MkII follow focus unit today. Extremely happy. All aluminum or steel other than the gears. The gearbox tension adjustment works well, loosened off all the way the focus wheel turns very easily with just a bit of backlash (< 1mm) but tighten it up a bit and the wheel becomes very fluid feeling and the backlash virtually disappears.
One feature I really like is that the marking ring index pointer/hard stop can be moved to where you want, not locked at the top of the marker disk. If you are shooting alone with the camera on your shoulder or at head-height, you can rotate the index pointer 90deg to the back of the unit, in line with your eyes. Shooting below waist level, rotate it to the top, always in plain sight. Also has a magnetic marker disk that is cheap and easy to replace.
Ordered mine with the optional quick release rod clamp, still very solid but much faster to install and remove when you have a mattebox or other items on your rig that you can't easily slide off.
All in all, seems like extremely good value vs Lanparte and Tilta at half the price.
One note that I assume is not only for this unit. The gear is relatively small and when using the large diameter lenses the hard stops interfere with full close to infinity focus travel. On my Canon FD 35-105 zoom it come within about 2 degrees of full travel. Not that this is a big issue but I am going to ask if they offer any larger gears. Otherwise would need to remove stops which always presents problem of losing them.
How much is the Tilta one?
Have no idea, need to ask.
@Vitaliy_Kiselev: Good to know. How much is the Tilta one?
it is "under development" for long, long time.
@Vitaliy_Kiselev: I see TrusMT has one under development: http://www.trusmt.com/en/proview.asp?id=113
Please put up a review when you receive it. Gives me some time to gather the spare change in the couch together. :)
@RatLabProductions I was so impressed with the build on the Fotga rails I wanted to try the FF too. It looks like it's built just as well.
I had my eye on the D|focus but plastic for the price turned me off. This one looks pretty solid. Nice to see some reasonable priced FF.
D|Focus v2 is disappointing.
Non China manufacturers now compete only in studio FF range.
Full studio grade FF with double sides are still rare, only Tilta makes one as I know.
I wonder if they fixed that in this version?
You can ask them :-) I hope that they fixed it.
They have version without hard stops
http://www.personal-view.com/talks/discussion/562/special-deals-matteboxes-hoods-and-follow-focus
Ouch, that a progress within just one year.
