If anyone is interested, this was shot mainly in 1080i. It had some 1080p moments and one 720p moment in it. Mostly 1080i though. I think Flow Motion 2.0 held up well even in this mode.
@driftwood Thanks for the suggestion. I uploaded a comparison between Cluster v4 and Flow Motion v2 in 1080p 24H mode in the first post on this page.
@LongJohnSilver The left edge of the frame looks like it's illuminated in bright sunlight, which narrows its contrast. That makes it look less detailed that the darker areas of water. At the distance this video was shot, the water surface ripples are tiny, making them look more like random noise than genuine image details. Perhaps this scene would look more cinematic with a diffusion filter?
Hi Lee, I understand but if you look the video you can clearly see the same problems in the left lower corner. Do you see it?
Thanks
@LongJohnSilver Your second video is not as intensely detailed as the first, and FM2 recorded it in its standard 100Mbps mode. Both Stream Parser and Elecard StreamEye Slim reports look flawless, indicating that the encoder was operating at optimal quality levels as intended. (The target QP level for Flow Motion v2 is 17 for both I-frames and B-frames.) With an all-Intra patch, you'd need a bitrate of over 175Mbps to maintain comparable encoding quality in each of its I-frames.
Do not rely on Vimeo for this. As I wrote Vimeo doesn't like high bit rate avchd files. it accepts them but the resulting quality is terrible also if the shot is perfect.
From what I see on vimeo, its not only the water in the bottom of the frame, but also the distant water in the middle. There is rain/insects hitting the surface randomly producing small circular waves. If you look close enough you can see that the footage jumps in time in that area (about 1/2 second).
(I hope its not the vimeo compression/playback thats fooling me here;-)
@cbrandin actually on the first video the water covers the entire frame. Anyway given that I shot a lot of scenes with water, since the GH1 I always noticed a strange "strobe like" effect on water movement.
Before I go there for a third time... my question is with the current settings development how I could shot this scene with the maximum quality? Not to offend Lee :) Should I use an Intra setting or a FS700? :)
Following up on Driftwood's recommendation below, I shot a test comparison of his Cluster v4 patch with Flow Motion v2. For this shot I used a handheld Leicasonic 14-50mm f2.8-3.5 OIS lens in 1080p 24H mode. Here are links to each video, which include downloadable original MTS files:
Cluster v4 in 1080p 24H mode:
Flow Motion v2 in 1080p 24H mode:
Cluster v4 is indeed a high-quality long-GOP patch, with peak bitrates up to 100Mbps. However, its P and B-frames are encoded with average quantization levels that are coarser than the B-frames in Flow Motion v2.
Using Elecard StreamEye to examine the original MTS files, average QP level of the macroblocks in each Cluster B-frame is about 28. If we combine this factor with the average of the first four entries in Cluster's B-frame Quantization Table, we can calculate a good estimate of the average quantization quality used to encode the frame. For Cluster v4, this averaged table value is 8 and combining it with an average QP level of 28 produces an effective quantizer of about 8.1 (lower values produce finer quantization quality).
In the Flow Motion v2 case, the average QP level of macroblocks in each B-frame is 20. The average of the first four entries in the FM2 B-frame Quantization Table is 11. Combining these factors produces an effective quantizer of about 4.3. These figures indicate that Flow Motion v2 B-frames are encoded at a quantization quality nearly twice as fine as Cluster v4 B-frames. OTOH, the FM2 MTS file is nearly twice as large as the Cluster v4 file.
Here is an unfiltered frame grab from the above videos displayed at 200% magnification. The Cluster v4 frame at the top looks very good, with no visible macroblock artifacts. However, its limited bitrate was not able to capture quite as much flowing water detail as the Flow Motion v2 frame below it.
@cbrandin Yes, I've examined videos where the encoder appears to underestimate the bitrate needed to complete each frame. With Elecard Streameye, you can see where the QP level for individual macroblocks becomes noticeably coarser toward the bottom of the frame. When this occurs, the QP range may also increase dramatically. From what I've seen this tends to happen more often in patches that fix the bitrate at a nearly constant level, mimicking the behavior of a CBR encoder.
I checked out the video uploaded above by @LongJohnSilver and found that it does maintain consistent QP levels from top to bottom of each frame, with no skipped macroblocks. In all cases I've been able to test, Flow Motion v2 has not suffered from this syndrome.
I've always wondered whether this water rendering problem is inherent to water or because water is nearly always toward the bottom of the frame. Sometimes the encoder mis-estimates the base Q value to encode busy scenes. What happens is that there ends up being a lot of "skipped" macroblocks toward the bottom of frames because the encoder has run out of bandwidth.
An interesting test would be to record the same subject with the camera upside down. This would tell us whether the codec is failing because the scene is too busy, or whether it fails because water is typically lower contrast than grass or trees and the codec "sacrifices" lower contrast detail in favor of higher contrast detail.
@LongJohnSilver Yes, with this much variation in frame-to-frame detail, bitrate is the limiting factor. The unhacked AVCHD encoder will simply smear the details or plunge into Fallback Mode. I uploaded an example of this syndrome in the fourth post in the first page of this thread.
I don't know I was there for real shooting not for testing. It's the second time I fail...
@LongJohnSilver, do you get the same problem while shooting this scene in 24H mode, or not?
Hi Lee,
thank you for checking my shot. I see your point. On your FM samples the river bottom was of nude rocks and the water was flowing much faster.
Are you shure it's a problem of bitrate? On stream parser I see 119 Mbps (I'm a noob) but I uploaded another shot where the water is only in the lower partof the frame (about 88Mbps) and still the gentle water circles are rendered in a artificial way. Could it be a weak point of the encoder? Does it mean that with the current GH2 these kind of shots cannot be made? Am I the only one filming nature subjects like these?
The problem shooting in 24p above water and 30p underwater is mixing the clips on the timeline...
I would be curious to see an unhacked GH2 on this subject or another canon camera :)
Thanks a lot
PS
After the bush of death now we have the lake of death :)
Here it is: the water is still frying....
@LongJohnSilver Thanks for making the video available. You've found one of the most challenging types of subject matter for an AVCHD encoder - a combination of high-detail foliage beneath a sheer, nearly transparent water surface. If the water were more turbulent, it would obscure the details of the ferns and reduce the required bitrate. But with just a bit of surface shimmer, the foliage details are refracted in myriads of subtle specular highlights that the encoder must track as individual variations in frame-to-frame details.
With this much detail in VMM 80% Slow-Motion, FM2 is working in turbo mode at 140Mbps peak, and you've hit the limit of what the encoder can handle with that amount of bitrate. I'd recommend either widening your aperture (to lower the bitrate on distant details in the upper part of the frame), or switching to standard 24H mode, which requires 20% less bandwidth than 80% Slow-Motion mode.
I'll retest with FM2 this week. I've been meaning to give it a go anyway :)
@jrd @sam_stickland I did not notice any difference among various settings on the timeline. I'm using Edius 6 which is incredibly fast and responsive working with AVCHD files on the timeline.
Best
@jrd I haven't tested with FlowMotion2 but when I did my last round of tests back in February I found that I had considerably less timeline responsiveness with FlowMotion compared to Cake and Sanity (using PPro 5.5). It was enough on a problem that I went with Cake for the event I was filming.
I didn't have time to fully diagnose the problem and I haven't tried with FM2. YMMV. I didn't report this at the time because I didn't feel I'd investigated it enough.
@Lpowell sorry. Vimeo is starting to pissing me with their options. It doesn't have the unlisted video option.
It should be ok now.
Thank you indeed
@LongJohnSilver All I can see is the embedded video, and I can't really spot the issue. Can you make the original MTS file available for download on your Vimeo page?
here again with a problematic clip. :( it seems that water is the worst enemy of our beloved camera...
I uploaded to vimeo a clip from yesterday session. It's shot using VMM 24p 80%. On some shots the bubbling water moves in a completely unnatural/artificial way. It's like having subtle artifacts and the water moves like under a strobe light. I tried playing this clip with VLC, WMP and importing it in Edius. Actually once I conform it to 30p problems are further enhanced.
Maybe it's me or my pc. Please give me your opinion on the original mts file. Vimeo is terrible converting mts files.
PS I came back to the same place where I got completely useless shots on Sedna 30p. I'm starting to believe it's the place...
Thank you in advance
@LPowell ok thanks. I use Edius, I got it just editing the file properties :)
