GH2 Cake v2.3: reliability and spanning in 720p, HBR, 24p, and VMM at 2-2.5x stock bit rates
  • 609 Replies sorted by
  • Really nice, Stanley. Looks even better on Vimeo. https://vimeo.com/stanleyhsu
  • GH2 (Cake 2.3) + Voigtlander 25mm/F0.95 + SanDisk Extreme 32GB 45MB/s Class 10
    Thank you @balazer for your delicious cake.
  • my brother's wedding... cake 2.3 and gopro in this shortcut. thanks
  • I'm using a SanDisk Extreme 45MB/s 64GB with Cake2.3 in 24H mode. Never had a hick-up.
  • They also have Transcend 32GB Class 10 for EUR 25,00. I bought one about 2 weeks ago for ~40€ and benchmarked it writing at a solid 18MB/s.
  • @Mark Thanks for reply :) Its all i wanted to know. Ill post new video from tomorrow shooting if things goes well with 1/50 and 1/25 shutter speed . . I hope my camera don´t froze that much as last time did.
  • @Majlo Cool - I use original batteries. There are some good topic on this forum about batteries (and cards, as you've found out!). Basically NEVER flash your firmware with a non-original battery, because the camera won't accurately know how much charge is left in it, and if it allows you to flash the firmware and the battery dies before the flash is complete, it will brick the camera (and you will be able to use it only as an expensive paperweight).
    But do see other topics on this, as Vitaliy doesn't like it if the discussion gets too far off-topic!
  • @Mark Yep i noticed :) I was reading alot about it yesterday.. But still, im very happy for recommendation. I go for Sandisk extreme 45 mbps (as @gameb recommended). Although ill buy 62Gb later. And wtf is Panasonic SDcard co expensive? :X
    One more question, do you ppl use only original batteries?
  • @Majlo Good luck with the new card when it arrives. I never answered your previous comment - sorry - and I can see how it might have looked confusing. What I meant was, the Class 6 card I had always worked with Cake. So although it was marked Class 6 it was a better card than the one I have which is marked Class 10, which sometimes fails on Cake. The point being, you can't really tell by reading the labels, so it's best to get the ones people have recommended on this forum. The ultimate cards are the Sandisk 64GB 95mbps cards, but they are a LOT of money!
  • @gameb Thanks man, ill try ;) Ive ordered it now, so will c what happens :P
  • @Majlo you get sandisk extreme 32gb 45mbps on amazon germany for 26 Euros, thats a good card, fantastic price, never had any issues on cake in any modes with it (thanks @balazer)
  • @feha - Id like to :D but i dont want to buy some shitty filter, so im trying to save money for it :)
    @Mark - 16Gb 6 class on full HD clips? I thought its low class. Ive seen one pretty Panasonic SD, quite expensive 32GB but class 6. So i thought its low class and not enough for HDR recording. And Mark, hardly ever fail means never fail or it failed you? :)))
  • @Majlo , don't forget to use an ND filter :-)
  • @Majlo I think you're probably right - I would see if it works better with another card. You never really know how good cards are without trying them (unless you get one of the ones recommended on this forum). I have two 16GB cards, one marked class 6 and one class 10. The class 6 one is better, and hardly ever fails with Cake 2.3 The class 10 one is less reliable. Let us know how your experiment goes with shooting at 1/25!
  • @Mark_the_Harp Thanks for reply. I was shooting today on 1/50 childrens on playground. It wasnt perfect result (its not movie look which im looking forward to..someday :)), but on 1/50 quite reliable picture. Nextime ill try lower it on 1/25 as u say just to try it out. But there is a new problem. My GH2 frozen like 5 times in 2h (on Cake 2.0). I had to withdraw my battery (ON/OFF didnt work) Its most probably SD card fault. As i said, its 10 class (32GB), but not original Panasonic so i suggest low write speed on HDR. Or... any ideas? :) Thanks again for reply
  • @Majlo Unless I've missed you saying, what shutter speed were you using? The only way of getting very smooth motion is to use perhaps 1/25. But of course then you lose detail in anything that's moving. I mean, your clip looks OK to me - no major juddering at least. I think there's a rule somewhere that you should allow more than 7 seconds for an object to go from one side of frame to another, so you could slow down the pans. But 24p/25p will look different from interlaced video shot at PAL framerates. For many people, that's the attraction of the GH2 - it looks less like "video".
    If you are talking about something more than just the regular, frame-to-frame flickering as you pan over your scene in your video, then maybe your video looks different to you than it does to me - for example, maybe it's an issue with your player not handling the high bitrate? As I say, it doesn't look particularly bad to me.
    EDIT: I was looking at the video on my iPod as I didn't have the computer fired up. Just looked at the original YouTube, full-screen. Yes, I see what you mean. You also mention there that you use 1/50. So you could try lowering the shutter speed to 1/25 (at least, for this sort of shot). Some people say you should use 1/50 but personally I prefer the look of 1/25 for the stuff I do. And Cake is a great patch - it's the one I use all the time (thanks, @balazer)!
    Also, the youtube video does sometimes pause for a fraction of a second - probably a YouTube thing rather than anything you've done.
  • Feha, try playing back with VLC. Enable deinterlacing and set the deinterlacing mode to linear.
  • @balazer , I mean this is not the case in stock FW and not the case with FlowMotion, I want to be able to use Cake 2.3 as most stable settings also on 1080i 50. What i mean is it shows visible (interlaced) lines on playback ...
  • Btw i was thinking . . . i dont have original Panasonic SD card. It is some SD/class 10, but its not Panasonic. Do u think it is possible, that my SD is shitty one and thats why its not satisfying quality i look for?
  • Balazer I understand that, but ive seen posted videos from others with same setting and i have a feeling that their motion was better (smoother). Fast camera movements make buildings (objects) very jumpy. I was working with videocamera (Sony PMW EX3), so im new with GH2. Im little disappointed with this jumpy outcome while panning (dont know if PANning its right word-sry for my english) . I dont know how to shoot dynamic scenes, like running kids ect without that jumpy objects.. Stills are very nice..andy ideas? Or am I just an idiot. . :)
  • Majlo, that's just how 25p looks. If you want smoother video, you need to shoot 50p or 60p.
    Feha, I don't understand the question. 1080i50 shows interlacing in playback because it is interlaced. To play back interlaced footage correctly, it needs to be played back on an interlaced display, or de-interlaced.
  • @balazer , why 1080i50 mode shows interlaced in playback ?
  • @Ashun it is HBR. Im from CZE, so i record to 25/50 fps. That video was posted right from GH2, no edditing, just upload to Youtube.
    @Balazer Its recorded on 32GB/10 card. U think its SD card problem?
  • Cake v2.3 is stable. You might have been thinking about what I said about 2.3 beta. In any case, 2.2 and 2.3 are the same for 720p.
    I certainly don't recommend Cake if you're using a slow Patriot card that locks up the camera. If you really don't have time to mess around in the field, well, time is money. There are much better, inexpensive memory cards available.
