For over a year, there have been contrasting reports. Can @Vitaliy_kesselev give a final answer ? Is the GH2 HDMI output a YCbCr 8bit 4:2:0 or a YCbCr 8bit 4:2:2 with timing and cadence issues ?
On every thread, the opinions seem to change between 4:2:0 and 4:2:2.
If no one can tell, what's point to know it ?
Because its worth picking up a recorder and testing it if its definitely 4:2:2. The dude at Marvels film is sure its 4:2:2 and that there is additional shadow detail.
Its a big effort to test it, so I am making sure I am not reinventing the wheel.
The difference will show up during grading, and greenscreening. Especially in greenscreening with reduced color bleed.
I read this part earlier.
IS THE HDMI OUTPUT 4.2.2 ?
The question of whether the HDMI output is 4.2.2 constantly comes up. The fact is, nobody knows because the chroma is so mangled up. What we know for certain is that after applying the Chroma Fix, we have a clean, uncompressed 4.2.0 picture. As a practical matter, this is the best way to think of it.
However, the 4:2:2 reference still keeps on turning up. Here is Marvels film blog. http://marvelsfilm.wordpress.com/2011/04/19/panny-gh2-hdmi-recorder-bingo/
The HDMI signal from the has been described by Barry Green as “screwed up 4:2:0″, but other tests by Jorgen Escher shows that it’s really 4:2:2 that has been deliberately crippled by Panasonic to make the camera less interesting for professional vido use. This “cripple” mainly exists of timing disturbances, applied to both the video timing (“field cadence”) as well as the timing of the separate chroma channels. Despite everything, HDMI recording eclipses the AVCHD recording in many ways, such as:
How come you guys are so sure that it is YCbCr and not RGB? I've read the whole topic but can't find any information on that (see this other thread)
Because any kind of chroma subsampling on the signal means it's not in RGB color space. It can be converted to RGB color space with more or less losses depending on the subsampling scheme, but it's still not RGB to begin with.
And most if not all external video recorder won't accept a signal who is not in YCbCr space (like a computer monitor output for instance).
@zcream Do you have a device to record the HDMI signal? If you do, you can run your own tests. If not, it's probably not worth the effort and expense to get one. The hacked patches bring the quality so close, it just doesn't make any difference. If you think there's some advantage to using HDMI for greenscreen work, forget it. I have done extensive tests with this. First, if you don't process the HDMI footage with Avisynth and use the Chroma fix, the HDMI picture will key WORSE than the onboard footage. If you apply the Chroma fix, then it will key the same as the onboard footage. In no case, will it ever key better.
@duch most recorders (like Atomos Ninja) do support HDMI RGB input, as of specs all HDMI devices must support the sRGB color space at 8 bits per component (source: HDMI specs).
I am with you on the part that chroma subsampling has for sure been done, but why are you so sure that converting to RGB is not done by the HDMI output-unit of the GH2 itself?
I'm pretty sure the chroma subsampled signal is not converted back to RGB as it won't make any sense (and I don't know if the GH2 has enough processing power to do a double conversion).
On the other hand, digital still camera are RGB pieces of hardware to begin with, so it might make sense to send non chroma subsampled signal to the HDMI out.
Regarding recorders, AJA Ki Pro and Ki Pro Mini do not support RGB over HDMI. Tried and confirmed by AJA themselves. As those recorders reads the HDMI out from the GH2 juste fine, it is my understanding that the signal on this output is not RGB.
Vitaliy_Kiselev
13862
stonebat
3610
driftwood
3029
