Premiere CS6 - Slow render/export via Intra100 timeline
  • I've been editing hacked GH2 footage for sometime in Premiere, but only recently chose to try out an intra100 sequence for my footage. The project consisted of 2 hacked GH2's with Driftwoods Pictoris, and an FS100. The project edited as smoothly as if I used DSLR 1080p30 or AVCHD 1080p30, however, the render times and export times are insanely long! I always check maximum render quality on my exports and sequence settings, and it never takes this long. A 20 minute sequence is taking over 3 hours to export to a 1080p h264 for web. I use magic bullet looks and mojo as the most intense filters. But even on an edit I did last week with the same filters and same length, it only took an hour at most to export. I've actually exported sequences faster than realtime! What gives? I need to test the same sequence in AVCHD format and see if its quicker.
  • 1 Reply sorted by
  • Can you copy and paste the clips into a DSLR 1080p30 sequence and check the render time?
