You can check out a video that I recently posted, comparing Panasonic's v1.1 firmware with Intravenus IV2. Moire reduction is very apparent @ 720p. The image quality is so improved over factory firmware that I'm more motivated to use 720p to gain the improved frame rate of 59.94fps.
They should use better glass on the GH2, not that shitty one.
GH2 stock and hacked against canon t4i and NEX-6 - side by sinde:
they would go with the t4i ...
From their blog post:
Panasonic GH2 with Flowmotion Hack:
The Panasonic is pretty plain and simple: It is the sharpest. In fact I think it's the sharpest camera under $10,000. I think this camera is the clearest proof that the manufacturers are holding-out on us, and releasing cameras that aren't as aggressively great as they could be, because they want to segment their market and control the upgrade timeline. I was actually surprised as how sharp the camera is right out of the box, sans hack. The hack really comes into play when you have a lot of motion in the scene. On the stock version, the compression falls apart into jpeg-y blocks, on the hacked version it's clean throughout. Sadly, the camera lost (sometimes emphatically) on every other test. So even though it's the cheapest and sharpest by some margin, I can't give it my whole-hearted recommendation.
So I applied the hack and adjusted just the 1080p24H & L sections to 42K & 32K respectively. I noticed that my record time on the card & remaining time on the card don't match up. Starts off with 1h39m remaining card time, and after 20min of recording, I still have over 1h26min....??? Is this normal? Anyone else getting this discrepancy?
