I think any modern >=128Gb SSD will do.
From: http://www.blackmagic-design.com/support/detail/faqs/?sid=3960&pid=3968
HFS+ for Windows® 9.0
Experience total communication between Mac & Windows with the industry’s highest performing file system technology
Paragon HFS+ for Windows is the only solution that provides full read-write access to HFS+/HFSX partitions on any type of disks (APM, GPT, MBR) under most of Windows versions! Access Mac-formatted partitions in Windows systems with the fastest and most stable HFS driver on the market.
http://www.paragon-software.com/home/hfs-windows/ , cost $20
JHFSPlus
Quite weird Java thing (and read only). But free.
http://sourceforge.net/projects/jhfsplus/
MacDrive
Seamless access to files on virtually any Mac-formatted disk from Windows.
http://www.mediafour.com/products/macdrive
TransMac
Commercial toold supporting all operations, including formatting.
HFS Explorer
HFS Explorer is a Windows file browser that allows you to access your Mac hard disks and disk partitions through a program window. HFS Explorer can't mount Mac drives in Windows Explorer or do anything particularly fancy, but it works great if you just need an easy way to read and write to your Mac drives in Windows. Most importantly, HFS Explorer is free. It hasn't been updated since 2008, but the HFS+ format hasn't really changed since then, so compatibility isn't an issue
It’s time for the new Drobos that you proactively and explicitly helped us design. And it’s time for all the Drobo goodness AND much higher performance.
Preorder:
+1 for MacDrive. It's the only one that's worked consistently for me. It works great.
This thing can be useful for 2.5" SSDs that you'll use with BM camera
http://www.personal-view.com/talks/discussion/3674/2x2.5-hdd-internal-rack-with-raid
In Hperdecks, I have been using the 'OCZ Vertex 3' (mine are 120G) .. 3 of them working faultless
I have a Corsair Force 3 256GB SSD and it should handle 24p @ 2.5k - It has a sustained 128MB/s write speed. 30fps will be a no go.
I use MacDrive .. I have one licence .. I deactivate it on my workstation and activate on my notebook when I go on set.
I was unsuccessful with HFS+ 6 months ago .. I debugged for ages suspecting some hardware compatibility was causing system crashes .. when I contacted Paragoon, they acknowledged isses with Win 7 and refunded me. They may have fixed issues. Apart from the system crashes .. it does/did not format under windows 7. Read and write worked .. crashes were mostly on shutdown of system and when open close NLE
