GH2 Cake v2.3: reliability and spanning in 720p, HBR, 24p, and VMM at 2-2.5x stock bit rates
  • 609 Replies sorted by
  • Thanks for the testing and feedback, everyone.
    arvidtp, I think 2.3b1 should be stable. I set it the same way I did in all of the other modes, putting the max sustained bit rate low enough to never go into fallback mode. But the bit rate in 24P is too variable, making the typical bit rate much lower than I wanted or expected. I'm guessing the variability is because of the short GOP length, which is shorter than I set in all of the other modes. (The GOP length in HBR is actually 6, not 3, because the GH2's interlaced coding uses field pictures) Instead of using 2.3b1, I'd suggest using 2.3b3 in 24L mode. If that bit rate is still too high for you, you can try lowering the 24L bit rate 10 Mbps or so. But if you change anything, you're on your own. Be sure to test your changes.
    Short GOPs are less efficient than long GOPs, so they're not suited to low bit rates. The only reason to use short GOPs in the GH2 is to support spanning at higher bit rates. But since short GOPs are less efficient, if you use a short GOP with a low bit rate, the quality is lower. If you really need lower bit rates, I'd suggest using other settings like Cbrandin 44M or Sanity.
  • back up to ~58.5 Mbps in 24H with 2.3b3 here. Quality seems similar subjectively to 2.2.
    However, as long as 2.3b1 proves to be as stable as / spans as well as 2.2 (do you have any reason to believe it would not be?) it may very well be my setting of choice for shooting concerts since i calculate ~1:50 hours on a 32GB card using 24H (assuming 40Mbps), and ~2:08 with 24L (assuming 35 Mbps), which is just about a perfect quality/record time tradeoff for the concerts i tend to shoot, especially since the camera tends to sit on a tripod and is seldom moved, hence lower bitrate is usually OK.
    I can see 2.3b1 being relabeled as "cake lite", or maybe "cake, low fat" :) and posted along with standard cake, as long as it is as stable as the other versions.
  • @balazer thanks for the cake! great taste ;) i used cake 2.2 and was quite happy to see the great results with modest file sizes, thank you for your hard work on it! will load and go test 2.3b3 now.
  • I'd like people to try 2.3b3 and compare it to 2.0-2.2 in 24H. (2.0-2.2 are all the same in 24H)
  • So are we all meant to use beta3 now and report our findings? Is beta3 now the "best" cake to use?
  • arvidtp, I think I got it now. Please try this. These settings are just like Cake 2.2, except I've changed the fallback mode scaling matrices to be the same as the B-frame scaling matrices, same as I had done in previous versions of Cake. Now I'm seeing a nice pattern of regular frame sizes in fallback mode, and great quality, just above 60 Mbps in 24H. It's stable and spanning in 24H. If you want a slightly lower bit rate, use 24L.
    Edit: sorry, 2.3b3, not 2.3b2
    Cake2.3b2.zip
    976B
    Cake2.3b3.zip
    979B
  • @balazer don't worry! if that is expected behavior, its fine - just thought it might have been out of the ordinary to have a lower bitrate :) I actually like having a little lower bitrate myself, since i often shoot performances - gives more time on the card. And as i said - was very hard to pick out any real quality difference. Thank you once again for an awesome hack setting.
  • Ugh. I can't give you a higher bit rate and have it never go into fallback mode, while also making it span all of the time. Pick two. Everyone was perfectly happy with the quality, and then someone had to go looking for problems in Stream Parser.
  • i shot some interior shots today with cake 2.3b1 and they averaged only 38 to 41 Mbps on 24H. So i re-flashed with cake 2.2 and sure enough i was getting 61 Mbps again with the same scene. I feel like the quality was a little better on the cake 2.2 shots than the 2.3 shots (makes sense because 1.5x the bitrate) but it was pretty subjective and had trouble picking out any one thing that i thought was worse on those shots that i could screen capture and show here, especially since they were hand held.
  • my thought is that youtube's re-encoding is destructive, and not necessarily destructive in the same way as the encoding you do before uploading, so it's probably best if it starts with the best quality you're willing to wait for, within reason, because the things it degrades might not be exactly the same things your encoding degrades, therefore the losses of quality might potentially add, rather than just "overlapping", if you get my meaning. Have not really tested this though.
  • @Bueller Yes, it took a hell of a long time, but Youtube accepted it. According to what I've read, Youtube suggests 8 Mbps for 1080p (http://support.google.com/youtube/bin/static.py?hl=en&topic=1728588&guide=1728585&page=guide.cs) but also will accept higher.
    I checked the average download speed for Youtube for my area: http://www.youtube.com/my_speed shows an average download speed of 8 Mbps.
    Just for fun, I used the Firefox download helper to download the HBR version of my video, and checked the speed of the resulting MP4 file. The result was 257 MB in size, with a total bit rate of 6.1 Mbps.
    Bottom line: it's probably a waste of your time to upload any 1080p video to Youtube with more than 8 Mbps stream, and likely we're fooling ourselves that high bit rate makes a difference for Youtube playback -- but I could be wrong.
  • @ahbleza are you saying that you uploaded the 9 Gb file to youtube? It definitely looks much better than the first one, you can definitely tell in the trees above the water.
  • I'll be trying cake 2.3. Just loaded it, did a few clips so far and averaged 44mbps. Still seems sharp and of quality to me. I had been using mysteron but I feel like the 100mbps is wasteful for card space.
  • @vstardust Your least case compression (1h compressed to 30s) when final outputed to 30fps still gives 10:1 frames of input:output, so it's all about efficiency. When you get back you'll still need to frame blend to get 360º shutter. Having said that and without doing the 1TB/n# of timelapses recordable math, I'd say very very very long GOP. I've searching but I can't find what was the maximum GOP I was able to achieve. Something tells me 96 or 72.
    I would take Cake 2.3 beta 1 and only change "1080i60 GOP Size" from 3 to 96 and see if it records/spans on your cards. I know what I said before about spanning, but we are talking about mega GOPs now with 3 seconds of video+audio. 7Mbps*3s = 21Mbps, it still shouldn't be an issue, but I would test it anyway...
    (edit) Apparently and according to some old tests ( http://www.personal-view.com/talks/discussion/comment/39717#Comment_39717 ) you can't go over GOP50. But at that time I was only testing on 24p, perhaps HBR30 can extend it a little further. Logic would be to try GOP60.
  • @duartix I have 16GB cards ~ about 6 hour max with 7Mbps. I still have to study timelapses and nature to figure out what I really need. What I do know is that I like long smooth timelapses of sunsets, wandering shadows and that kind of stuff - 1-3 hours shrinked to 15-30 secs. As I have said before I'm going to take about 5 month trip and because I want to travel light I'm not going to take a computer with me, but only one 1TB external hard drive. There ain't going to be fast internet access to where I'm going and that's why I want to keep the file sizes small. I'll get back to you if I have need for more tailored settings. Thanks though.
  • @all
    So far Cake 2.3b1 cadence (24h, HBR and FSH, with and w/o ex-tele) looks good to me.
  • @vstardust : I'm still struggling to figure out if you need some tailored settings. How big is your bigger card and how long do you need to record? How much x do you want to speed up the video?
  • @duartix I do need extra recording length. Recording sunsets from early on turning into dark nights is what I'm looking for. I don't have change to upload my clips anywhere but 1TB external hard drive. This going on for months (at least 5) and you really start to look for the best solution considering file sizes and quality. Actually @balazers new Cake 2.3 timelapser 1 seems pretty nice for both quality and file size efficiency.
    OK, so spanning is not a problem in shooting timelapse. Good to know.
    "Massive" file sizes are of course subjective, but about 7 Mbps would give 75min/4GB. That's what I'm looking for with great quality of course ;) I don't know the main principles of developing new hacks, but if it is possible to tweak the HBR30 2,5fps settings even further towards good quality and smaller file sizes I would be grateful...and I think I wouldn't be the only one. Anyways, thanks for your work so far, it has been great.
  • The quality difference between 24p and HBR depends on what you are shooting. Usually the difference in quality is not large. (i.e., they both have good quality)
  • @balazer
    Thanks, I was looking for that page. 24p is an absolute necessity for me; how much of a difference would you say there is between HBR and 24H quality wise?
  • @vstardust
    Your opinion, as well as other's willing to drop in, is highly appreciated.
    Personally, I also believe that HBR30 is the best option for timelapsing not only because it's more independent from 24p (HBR25 shares the same GOP) but mainly because it gives access to a great range of 360º shutter angles: http://www.personal-view.com/talks/discussion/2396/gh2-motion-fluidity-360%C2%BA-shutter-test-on-slow-shutter-speeds That is the reason why I endorse 2.5fps instead of 2fps.
    Plain vanilla Cake is already excellent at this and if you don't need the extra recording length, I recommend on using it as it is, because it's pretty well suited for 2.5fps, 5fps and 10fps. It just needs a few extra GOP tweaks to achieve longer Recording Length. Tweaking for 2.5fps would give ~30% of the current bitrate (~3.3x the recording length) and for 5fps it would give ~53% of the current bitrate (~1,9x the recording length). For vanilla Cake right now I'm predicting ~18m = 4GB @2.5fps.
    Now, addressing some of your questions:
    • Spanning problems and timelapsing don't make any sense when used in the same sentence.
    • Timelapsing @ 2.5fps uses 4x-8x less bitrate than normal footage with the same IQ. What do you call massive?
  • (duplicated post)
  • @balazer and @duartix thank you very much for your great work with Cake and Timelapser.
    Sorry for my non-scientific approach to this, but since it's not an option for me to develope Cake+timelapser further, I'd like to give my opinion on how I think it should work. HBR30p is the best option for timelapse-mode, because 24p is way too valuable to waste. 2fps would be better in a long run instead of 2,5fps if it saves space, but quality is more important. If 2,5fps works better I can deal with it. 60min to 90min / 4GB would be enough for file-size efficiency. Spanning with standard Sandisk Extreme Class 10 30MB/s is also vital for extreme timelapses.
    I'm not sure if it is possible to develope HBR30p-timelapse completely separated from 24p, but the quality of 24p shouldn't be not compromised. However the frame quality of timelapser should be as close to the quality of 24p as possible. Combining clips shot using both modes shouldn't cause too much variation in quality for the best viewing experience. Is it even possible to achieve timelapse-mode that is as good quality as 24p without massive file-sizes?
  • (edit) moved to separate topic http://personal-view.com/talks/discussion/2935/rescuing-bad-footage
    ...because I don't want to derail attention away from @balazer's fantastic work with Cake.
  • There is no HBR 24p. HBR is 25p or 30p. 24P Cinema is 24p. http://www.personal-view.com/faqs/gh2-usage/gh2-usage
