I had the Zeiss 85/1.4 and Nikon 85/1.4 on my Kodak SLR/n and I like the Nikon. In my film days, I had the Zeiss 85/1.4 on Rollei 3003 and the Canon 85/1.2 on F1N. The Canon L has the lowest contrast.
The Samyang 85mm on the 5D is very sharp. CA is present if shooting against high contrast backgrounds from F/1.4, reduced @ 2.0 and mostly gone by 2.8. Again this becomes apparent depending on the nature of your shooting. I would say it is ideal for follow focus work as the focus ring is really dampened and smooth - hard to pull quickly. I haven't had the pleasure to own a zeiss yet but I'm sure it's optically better.
Personally, I find traditional focal lengths on M4/3 sensor awkward, you have to work around the FoV to compose what you want. Generally it feels I need an extra 4-7mm's wider. Moving back is usually the solution but effects compression of BG.
