ColorGHear TOOLKIT- color grading SYSTEM for AE
  • 1015 Replies sorted by
  • @artiswar @shian Thanx. Timing is everything.
  • @franklee it was $599 last week at B&H
  • @stonebat - Compared to? It's the 32bit floating color space. I started grading the video above accidentally in 8 bit color space and it looked AWFUL. Switched and I was a happy man.
    @franklee - http://www.bhphotovideo.com/c/product/736343-REG/Panasonic_DMC_GH2K_Lumix_DMC_GH2_Digital_Camera.html
    $699 here. It was $599, but maybe I just missed the linked.
  • I presume there's something special about the way AE handles color grading. It preserves details well.
  • @Shian Where did you see the GH2 for $599?
  • Most of it was Nostalgic. There were a few shots outside that we adjusted for the brightness by switching to Cinema (New Lomo lenses without step rings for my ND filter). All of this was mainly graded with Levels and Curves. Then mixing the opacity of the Minus Red, Minus Green, and Simply Cooler gears. Along with some Spectral Enhancer mixed in.
  • Did you shoot nostalgic on this?
  • @shian - Thanks! Huge assest, your tools. Very excited on the fledgling career.
  • @artiswar Dude, this looks awesome!!! Great job!!
  • Wedding graded in ColorGHears! Just a trailer, longer bit to come.
  • @AlexManta, no worries. I didn't take your comments as rude, I hope I didn't come across as rude either. This was my first two projects in AFX. I was pleased to find an effective workflow, and wanted to share it, but at the end remembered that my recent DIY PC build was probably faster than what most people use right now. I use both Macs and PC, and glad I went out on a limb and built my own PC. Not to get off topic, but I haven't had any kind of problem in the first year, not one crash, nothing.
  • Thanks Shian...I love Twilight.
  • New Tutorial on creating film stocks is now live on the site.
  • @islanders66 Sure Islanders66 i didn't mean to be rude or anything, it's just that i tried your way before but it seems my computer isn't good enough for so much processing, it's lagging all the time.
    @shian Thanks Man.
  • @johnnym: TYVM Johnny. I should look at LOTR more closely. I was just testing and wanting the footage to be more 'Cinematic'. I hate it when people say the GH2 is not 'cinematic' while the MkII is. I take it as a challenge. But, anyway, i'm closer to where i'm going. Will be going into the desert soon and will try to get LOTR brown. ;) The Punch presets are really awesome to help get that 'popped' look. http://photos.jamesthorpe.com/Other/Footage/22390839_mFrnGc#!i=1789818722&k=JdSp6Zf&lb=1&s=A
  • @AlexManta How to do dissolves in AE.
  • @pvjames omg man, you know how to get LOTR green! Great photography!
  • @AlexManta You can do it that way, or if you are only dissolving occasionally and not every time, you can do the same thing with the dissolves as you would with titles. Put all the dissolve transitions and their respective clips on their own layer, turn everything else off, and export them with alpha channel holes (Animation, PNG, TGA), and then that way you can bring that layer into AE and not have to worry so much about having to break up the master file into individual clips - which is a pain in the ass, I did it for years before Automatic Duck, and editing in AE is mind numbingly slow. In fact this workflow was what I did for everything before AD, but I sacrificed the time to get the quality.
    So in short:
    Move all dissolving layers onto own track. Turn them off, and Save PP proj.
    Import PP proj into AE.
    From PP, export just the dissolving clips with their respective dissolves with straight cut clips turned off into a file with an alpha channel.
    Bring that exported file into AE and lay it in over the top of your timeline.
    Grade accordingly.
    OR for more accurate grading results, and zero loss of quality:
    Learn to keyframe your opacities on clips in AE. AE should layer the clips the way they were dissolved in PP, and all you need to do is set an opacity keyframe in the top clip right at the point in the timeline where the lower clip begins, and then drop one in at the end of the first clip and set the value to 0. Boom: dissolve. (This is how I would do it. EDIT: see 2 posts down for tutorial)
  • The work flow I shared is just one alternative of Adobe round tripping. One advantage of their software. It works for me, so thought it might work for someone else. The concept is to share and test different workflows to find out which one is right for your project. If you don't have any workflow to After Effects than you should also put in some effort to research, watch basic tutorials that are free, and try them out. And if you have something that works and you want to share it with detailed instructions, that would be generous.
  • @shian Ok, first of all it seems like my stupid question, where i thought I was a total dummy is a problem for everyone trying to use PP CS5.5 with AE without dynamic link and/or Bridge...From now on i will work the way you suggested. It's actually how i work as a sfx designer/music composer. It makes every stage more decisive but at least i feel like i'm moving forward doing this and can concentrate on every step fully.
    Now about your knowledge and professionalism, i have to say that I'm actually amazed by how much you know about color grading, contrasts, compression etc....You're like a scientist/artist which is fu..ing rare in this world in my opinion. I know down to earth scientist and crazy artists, but both??? Maybe Jesus Christ??? :D
    So please keep on giving us these amazing tips and tutorials on ColorGHear.com.
    Now I just have one question...let's say i do my whole Editing in PP that i import the sound in it too, mixed in Logic. Can i export it in uncompressed animation fullHD and grade it finally in after effects without losing too much quality to finally do the 444 linear off???
    I'd rather do it like this because my cuts are really really detailed and i love to use film and cross dissolve as a part of the flow of my narration..I can't imagine doing this after like @islanders66 is suggesting...and doing this kind of editing in after effects doesn't seem like the right tool for the job.
    So I know you use FCP but do you think importing a full HD uncompressed .mov in after effects would be good enough for HD TV channels which is the media we are aiming for? Or do you have another compression setting possible??
  • @No_SuRReNDeR Thanks dude...very flattering, but I wouldn't throw me in with that lot just yet. Just tired of seeing good stories, told well, but getting swept under the rug due to poor production value that could have been had on the cheap, if only one knew where to look.
  • @itimjim As a time saver.... would just do CC/Grade in the NLE--- I used to create grades in FCP by duplicating clips on layers and using one as an adjustment layer by stacking the clips on top of each other use the 3 way CC and different blend modes....thats how I did these -- ITS QUICK no huge render wait....then export a H264 QT with proper settings....usually they have something on the info sheet...
    I think this a really QUICK way to basically do a similar thing to the AE method. Try it you may be surprised by the results....I dont know what NLE you are using but the concept is the same.
  • post removed
  • @itimjim I'm not a religious man, but....prayer???
    I have stayed away from such contests myself, only because I think they're a waste of time and energy, and a scam to make money perpetrated by the contest runners. I've never seen anything good come of one. I'm sure someone will point to somebody who won one and got a movie deal out of it...but I've never seen it happen.
  • @shian Quick question, I'm in an odd predicament.
    I'm shooting a 5 minute short over Saturday and Sunday this weekend as part of the Sci-Fi London 48hr Film Challenge. At Noon tomorrow (well, today now) we are given a title, a prop that we need to include and a line of dialog. We need to then write a script, plan photography, shoot, edit, effects, grade and deliver - by 12 noon Monday morning. We're not planning on sleeping.
    One thing that is making me a bit nervous is the unknown quantity of render times. What I'd like to do is is edit, grade and FX the first night, and then add the second day's shoot the night after. I'm just a bit worried that we end up with a 5 minute EDL to grade, FX and render out with only 8 hours to go, and it decides it's going to take 12.
    Any ideas on how to tackle something unique like this?
