is there an expected release date and price? Perhaps an intro price for personal=view persons!
Thanks David.
You will achieve MUCH better results if you use this controller or make your own to power the cameras up at the same time. This is a time-tested technique to achieve very tight initial sync (typically less than .05 ms). Your cameras will drift apart after startup, and there is currently no way to fix that. I find that I have very acceptable sync with both my GH1s and GH2s for 30 min or more after power-up sync. I purposely buy cameras with close serial numbers to increase the odds of success. Your results may vary.
Hi. Sometimes i use 2 Gh2 for live action3d with a genus mirror rig with similar lenses. I have one pixar remote with dual cable to start and end the record. The big problem is the Sync between both, Recording in 50p helps a lot and as a shutter upper 60. This card show the disparity of the signal of the cameras. My question is: Any possibility to conform the both signals with sync?
Very, very interesting! Thanks for sharing! Genlock on the gh3 would be immense...
+infinity for genlock !!!!!
+1 GH3 Genlock (or sync)
It is very, very good thing.
Thanks for info, David.
It could be really cool to have some genlock like think in GH3 for 3D.
great news, i was interested in something like : LANC for video cameras, but just for GH2, remote control type, as this press for focus, and record ...
but this one is much more advanced :-)
