Zacuto EVF vs SmallHF DP-4
  • If you are contemplating on buying an EVF but don't want to invest your $800+ without (over) thinking it, vimeo user "niceladyproductions" has just posted the last chapter in her 3-part Zacuto EVF vs SmallHD DP4 comparison. That's more than half-an-hour of in depth comparison of the two products.
    Part 1:
    Part 2:
    Part 3:
    As for me, I am leaning towards the DP4: It seems to offer "more for less" (the 'flip' version is by default, switchable battery plates). Even though I haven't completely made up my mind.. yet.
    Any personal-view zacuto and/or smallhd users here with opinion/input/advice?
  • 27 Replies sorted by
  • @AmandaNL damn...I hope they can fix it somehow through a firmware update because I really want to keep it.
  • Nope, very bad colour on DP4 I sent mine back....
  • I like the DP4 as well, cuz focusing is a lot easier. I just can't get the colors right. Does anybody find good settings?
  • Bought the Edelkrone Monitor mount with the DP4 EVF and it's a joy to use (GH2) and 6 hours battery life from 2 cheapo LP-E6s from fleabay. I only have manual focus lenses currently, and the peaking is also terrific - silver instead of red - which for me, is much nicer in use. I love it !
  • @5thwall thanks, duly noted. as one say: practice is a way to expertise. I'll keep on trying.
  • @dream_beam all I can say is that it works for me. not sure what my settings are, to be honest. probably just stock. i made sure i was using the gh2 profile inside the EVF settings. also, it works best for me with the eyepiece attached, so no light is pouring in. my one complaint about the zacuto is that it's too small without the ocular on. the dp4 would be a nice companion to have when i don't want to press my eye to the eyecup. tradeoffs, i suppose, but it really hasn't been a problem in the field.
  • @5thwall QUOTE The EVF makes focusing a joy. UNQUOTE
    I've been using Zacuto EVF for about a month and still I've not got used to focus properly. The only way I can be sure about focusing is to switch to 1:1 scaling. The focus peaking assist feature of Zacuto EVF is useless to me. I tried every type of setting: 1, 2, 3 - it's a pain to get image focused. The only setting of focus assist of Zacuto EVF that I can live with is '1'. There is always some tolerance. Finally simple focusing by looking through standard viewfinder of GH2 provides faster and better results. Zacuto shows accurate color and exposure though the Zacuto EVF is useless for critical focusing. It may be that I'm doing something wrong. That is why my question to @5thwall is: what are your settings? How do you focus? May you please share your experience by making a video tutorial? I like everything about Zacuto EVF but focus assist. I wish to keep on using Zacuto EVF, please explain the best method to focus with it.
    P.S. I contacted Zacuto via Email this week and they were confirming that there were no plans to update Zacuto firmware for focus assist nearby MONTHS!
  • Good deal at $599-00
  • The SmallHD DP 4 EVF arrived on Friday and I've been playing around with it over the weekend. Here are my thoughts:
    Overall, it's a terrific product. I love the feel of it - enough weight for it not to feel fragile but at the same time light enough to not make the rig over the top. The features are easy to navigate through, it came with a ton of accessories (I got the bundled NAB mega deal and saved myself $350) although I can see the included 6" articulated arm could fail after a bit of use.
    To be honest, I hate the screw mounting of accessories like monitors or field recorders - a tiny bit of torque in the wrong direction and the thing is loose. Why the hell doesn't someone build some kind of simple, small but strong quick release system with a 1/4-20 screw in? It's fiddly spinning the monitor around and around onto the articulated arm when I could just snap it into place.
    The Small HD DP4 EVF is I would say about 95% perfect for my needs. I like the flexibility and feature set it offers whilst still allowing me to travel light. The focus peaking alone is going to radically change my shooting, everything else is icing on the cake.
    Small niggles:
    • The 1/4-20 hole on the bottom has no stainless steel threaded insert like the left and right holes do so this could be a problem in the future if I'm not careful screwing it in (see above re: "fiddly spinning"!).
    • You can't side mount the monitor on the 1/4-20 hole and use the included sunshade at the same time since the velcro straps go right by where the 1/4-20 hole is located.
    • It would be nice if the EVF had a plastic snap on cover for it when not in use to protect it from dirt and dust. I guess that's why we have cans of dust-off and rocket blowers, right?
    Other than that, this is a really well put together product and I highly recommend it. Definitely a huge improvement over the camera's LCD or the Trusmt viewfinder I was using and a helluva lot more reliable than the Lilliput 7" 5D-ii-o-p that I was initially excited about but in the end chose the Small HD - zero buyers remorse here.
  • @tommyboy thanks for the feedback dude. Glad to hear the colors are more true one way than another.
    Can I ask what your contrast/brightness settings are at?
  • @cafeteriacarlos Yes, the image is different on the EVF vs the LCD and I found that EVF colors are more true colors than LCD's. For some reason LCD colors are more pinkish in my case and I would love to know how to calibrate the camera's lcd screen instead of the EVF. I was actually going to take a pic and post it for people to recommend a solution.
  • @tommyboy
    GH2 preset just affects the crop/zoom of the image doesn't it? I didn't think it affected colors.
    I get a significantly different image on the EVF than on than the LCD/Viewfinder. I'm having to expose differently for each one. Did you change brightness/contrast/chroma at all on yours or leave it stock? And is the image from the LCD/EVF very different?
  • @cafeteriacarlos
    There is a GH2 preset in Z-EVF. What else are you looking for?
  • I bought the SmallHD EVF, here's my thought.
    The good - handsome looking :) - the 4 inch screen can really double up as a monitor compared to Zacuto. - focusing with peaking is very easy to hit the mark - false color is good
    The Bad - monitor heats up fast - color accuracy is no good. It has a very warm/yellowish tone to it. No amount of tweaking in the color setting can get rid of the ugly yellow.
    IMO, if you need to look through the viewfinder all the time, the Zacuto will make sense. However, if you like to switch between using a monitor and viewfinder in a shoot, the smallHD bigger screen size does make a difference. This was a deciding factor for me, dual purpose.
  • FYI, The Record Mode gets disabled (grayed out) with Zacuto EVF plugged in.
  • Has anyone here successfully calibrated their Zacuto to the GH2? Seems like a case of close but no cigar with me.
  • Cineroid has already been launched awhile back. Probably was the first in the market. There's another player in the EVF market, Kinotehnik http://www.kinotehnik.com/products/electronic-viewfinder/overview Kinotehnik are the same people who make the LCDVF. Not sure whether this is also another vaporware as it's been listed as "available soon" on their website for the longest time.
  • Yeah, and Red Rock Micro's microEVF seems to be vaporware at this point, after they decided to go back to the drawing board with a lower price tag.
  • What's the latest on the Cineroid? Has it fallen by the wayside? Seemed like a nice product when it was released, a viable alternative to these two.
  • @PixelCanFly I know it does look a bit washed out :(. I e-mailed the support and asked them if they were planning on implementing a better picture control (RGB channels, better contrast and brightness) in a future firmware update, since I think that shouldn't be so hard to implement. We'll see what they respond.
    As for the GH2, they said that since it outputs 720p while recording by default the monitor didn't need to make any adjustments (all these presets do is actually blow the 480p output to 720p..!).
  • @fetzu From the review, the difference in exposure and color accuracy between the 2 EVF is quite drastic. I really want to like the SmallHD EVF, but well...
  • @PixCanFly I had also considered that option, but having an extra monitor also means more accessories (articulating arm, batteries) and more stuff to carry around.
    @5thwall thanks a lot for the very useful input. Unfortunately I don't live in the US, and the equivalent for craigslist here will probably never see a Zacuto EVF on sale ;). I assume you have the EVF-Pro ("flip" version) which would actually be the one I'd get if not for the $250 difference :x. As for the compatibility with the GH2 (custom settings and such), I'll mail SmallHD's support about it and keep you guys posted.
  • @EOSHD, I know right. I'm hopping that with all the HD 4.5 plus smartphone screens out there and more to come, someone will come out with a good app.
  • I want a really thin but tough lightweight monitor around the size of the DP4. I have the Zacuto and it is great but I prefer to use it as a small monitor.
  • I have the Zacuto EVF and I'm very happy with it. I recently had a shoot with a mix of natural light and practical light. Although I have not had a chance to fully calibrate it, I used the EVF to gauge color temp and I was very surprised to find how accurate it was. The EVF makes focusing a joy. My shots all came out very sharp. But I believe that could also be said of the DP4
    One nice feature of the Zacuto is that it has a GH2 screen-size mode built in. It is my understanding that the SmallHD does not, but that was a couple months ago so that might have changed.
    I find the form factor of the Zacuto to be quite nice and in line with the GH2. I also really like the eyecup and that you can change the diopter's distance. Not sure how much of an issue it is with the DP4 but I really like that Zacuto added an anti-fog filter to their EVF.
    My gripes are with the way in which you flip the diopter up. The clip is nice in that it keeps the diopter firmly in place, but I can't unhinge it with one hand easily when shooting with a shoulder rig. Also, it's very easy to pull the diopter off the EVF if you're not careful. The solution? Just be careful and slowly detach the diopter.
    It would be very nice if the Zacuto were 1" larger. But hey, it's great for what it is and I can always zoom in to see 1:1 detail on the image. Price being the ultimate factor in my decision, I lucked out and found a deal on Craigslist. So, if you find someone trustworthy and can check out the unit before purchasing (get a receipt, etc...) then I recommend buying one used.
    If I were buying one today and price was not an issue, my decision would be based on whether or not I wanted to use the diopter when shooting. If no diopter, then I would get the DP4 since you need the larger size. And if you like shooting with a diopter then I would get the Zacuto.
    Hope that helps!
